looks like an early Renault engined Europa, not that that maters if he's building a new chassis, air scoop on the side is an interesting modification not sure what purpose it was intended to serve with the radiator being at the front! Indeed Kevin’s, it’s originally a non crossflow Renault 16 engine. As for the scoops, I think they look curse word, but you do see a few race Europas with the scoops. Probably to reduce engine bay temperatures.
No progress on anything old as I’ve been rebuilding the front and rear suspension on the Avensis due to 4 rotten suspension arms, 3 snapped springs and 3 seized calipers. I got sent a lhs caliper 3 times before a rhs finally turned up - Ebay. But I did see these pics on FB this week of the Fiat my brother converted to an Abarth replica and did the paint work also. The owner has been putting it back together himself. It’s looking the part.
looks like an early Renault engined Europa, not that that maters if he's building a new chassis, air scoop on the side is an interesting modification not sure what purpose it was intended to serve with the radiator being at the front! I assume that the scoops are in homage to the Lotus 47 Europa Race car.
Mar 13, 2021 16:16:08 GMT
That is cool^^^^^ Escort.... not really touched it. I did drive it out the garage last week and the brakes were jammed on. I jacked it up today to see if it was just the one caliper sticking and both rear wheels were free?? A job for another day. Cortina..... I’ve got a week off work next week so I thought today I’d finally remove the gearbox to see why it’s constantly jumping out of 4th gear. So I put it up in the air on the 2 post lift and in no time at all the gearbox was on the floor. I did get Jones Junior (The Elder) to come and give me a hand just to slide the box off the engine and balance it on the transmission jack so that it didn’t hit the floor. Next I removed the 2 top plates to check the selector mechanisms. This is called a 3 rail box. You can see why. So when I move the gear stick there is about 4mm play in the selector fork before the hub that engages 3rd and 4th moves. When I select 4th on the stick, I can push the hub about 4mm further forward. You can see the difference in these 2 photos My thinking is that 4th gear isn’t being fully engaged and is the reason it keeps jumping out. I’ve sent a video of it to a gearbox guru from the Cortina fb page to see if it’s something missing, a worn selector fork that need replacing/building up, or can it be adjusted out. I await his reply.
Have I worked on the van and used it loads? No. Escort. Took it for an Mot as it didn’t get one last year. Passed and brakes have been great too. The brakes binding has solved itself after a few miles of driving. It could have just been the remote servo causing the binding as it does do that if not used for a while and I was probably reading more in to it. I’ve adjusted the handbrake right up and it will lock the rear wheels even on grippy (private?) roads, do I’m really happy with that. It seems to lock better on the cables than it does on the hydraulic only handbrake. I’m going to call it mission accomplished. Cortina. I sent the gearbox off to a guy in Derbyshire who specialises in these boxes. It turns out that when the guy I know went through the box, he left out a Needle roller that ruined the the gear cluster and made all the needles magnetic. The guy said he’d never seen this before. So, this might not have been the cause of the jumping out of gear but it did ruin the box. The selector fork had worn with me holding it in gear so I bought a new one and sent it off with the box. I managed to score a NOS gear cluster for £200. That broke my heart. And when the wax was cleaned off there was a little surface rust on some of it but the guy cleaned it up. This was a bit worrying. Anyway, it then had another new front bearing, new needle bearings, a sleeve added to one of the bearing surfaces, new 4th gear synchro, new seals and gaskets again and a new main shaft. So by the time it was shipped there and back the best part of £800 has been spent on this box (frightening). But it turned up on Thursday so I picked up from my brother’s while I was in work. I wasn’t due in work until the pm yesterday. With Jones Junior (the elder) again on trans jack duties, after an hour and 10 mins it was all back in. What I forgot was to get some bl00dy oil. So a quick call to my younger brother oil was ordered and picked up this morning. After months in the garage the car was filthy. So after a trip to IKEA in Cardiff I filled the box and took it for a drive. There was no whines, noises, crunches, vibrations. Nothing. It’s absolutely spot on really. After about a 20 mile round trip with Jones Junior (the younger) the only thing ruining the experience is the carbs need rejetting ( to be sorted soon) and the lack of interior ( this could take a bit longer as I need to spend some money on the Escort first). So tomorrow I’m taking it to a breakfast meet followed by a drive over the Black Mountain where Car SOS usually try out cars as it only down the road from the meet. But the car was filthy. Especially as it was raining when I got home and the garage dust and grinding dust had turned to a mud coating. So I gave it a quick wash in the rain and then put it away.
Jun 24, 2021 21:31:22 GMT
Jun 24, 2021 21:58:01 GMT
Lovely.
Jun 28, 2021 19:10:36 GMT
So I took the Cortina to the show and in total we did about 100 miles that week end. Was it trouble free motoring? Not quite. Whilst on the way to the show the gearbox stuck in 4 the gear for a couple of seconds. But came out with a bit of a shove. At the same time there was a short, quiet squeal (could have been coincidence or paranoia I’m not sure). But it behaved impeccably after that. I spoke to the gearbox rebuild man and he gave a few pointers. He has said before I refitted the box to change the spigot bearing from a needle roller to a oilite bush as there was a mark on the input shaft that could have been caused by a damaged bearing. I had not done this. My mind was now convincing me that the spigot bearing may have collapsed so about an hour or so after returning from the show, the gearbox was back on the floor again. Gearstick is a NOS item and the ball had not split. It is also the right type as some have a larger hole in the steel dome so have a special washer that some times gets left out. I took both gearbox lids off and nothing looks out of place. No bits flailing about as if something has grenaded in there. Spigot shaft not chewed but there is some sort of wear marks on there now that weren’t there when I fitted it. Spigot bearing was complete but there could be wear in it. So I opted to change it. I bought an oilite bush to the dimensions the gearbox builder gave me, but I also bought a new needle bearing incase there was a fitment issue. I tried the bush on the shaft and it slid on ‘nice’. I removed the old spigot using the grease an old input shaft and hammer method and this worked a treat. I hammered the new bush into the crank using the old input shaft and it worked good- no binding on the shaft. One thing I did notice on the clutch cover was that there were marks on it as if it wasn’t flat. There were some gouges on it too. This wasn’t a new clutch when I rebuilt the car so I don’t know it’s history. I don’t think the marks were on there when I fitted it, but I did think I would need to replace it at some point. I don’t know if the disc or the cover is warped, it wasn’t slipping, but I chose to replace all the clutch components as the ‘box was still on the floor. I bought an AP kit from a guy selling classic car parts. They are old stock so probably filled with asbestos, but the one I pulled off was old too so same difference. I put it all back together about a week ago but didn’t get a chance to try it until yesterday. When I started it and first put it in gear the clutch pedal needed very little effort to press. Great, it’s either lost fluid or something in the bellhousing is not right. But I tried putting it in reverse and it fell in. For some reason the clutch pedal is now a lot lighter! Anyway, I took it for a 10 mile trip and everything was fine. No noises, no slipping and no sticking in gear. Another thing the gearbox guy did say is that he normally fitted NOS synchros but he can no longer get them so he’s fitted an aftermarket item for the first time. Could it have been this bedding in?? Time will tell. Another ‘incident’ on the way to the show was whilst driving along one of the lanes, one of the cars in front kicked out a large stone into the road and with my car being so low it hit the bottom of the car.😩. It put a dent in one of the chassis rails, scratched the floor, gouged my shiny stainless exhaust dented the fuel tank and dented the rear valance. That really pi55ed me off. Especially the dented chassis rail. I hate dented chassis rails😡. I’ve mixed some paint straightened the valance and touched up the witness marks. While the car was on the ramp I also swapped the rear spring eye bushes as I just fitted old used soft rubber ones when I built it due to a change of springs. I’ve had new ones for months but never got round to fitting them. All poly bushed up now though.
Jun 28, 2021 20:33:25 GMT
Frustrating about the damage. I had a van fling a stone up that hit the bonnet and screen of my wife’s new daily a week after collecting it, with a resultant gouge in the bonnet and a big chip in the screen. 😕
Jun 28, 2021 21:31:28 GMT
looks like an early Renault engined Europa, not that that maters if he's building a new chassis, air scoop on the side is an interesting modification not sure what purpose it was intended to serve with the radiator being at the front! I'm pretty sure that is the carb side on the Renault engine it came with. So cold air to the carb, probably.
Jun 28, 2021 21:56:57 GMT
Frustrating about the damage. I had a van fling a stone up that hit the bonnet and screen of my wife’s new daily a week after collecting it, with a resultant gouge in the bonnet and a big chip in the screen. 😕 It’s a bummer Glen. I’d have been even more upset if the bonnet had taken a hit like like your good wife’s daily. I did contemplate cutting the section out and welding in a new bit at the time, but time heals all wounds and I probably won’t bother. I just won’t look at it.
Jul 11, 2021 17:13:30 GMT
Last time I drove the Cortina it drove really well. This was after I changed 2 of the spark plugs. This morning I was going to take it to Pendine sands to watch the hot Rod racing on the beach. It started after a couple of tries but today it felt like it’s was running on 3.5 cylinders. I took it anyway. I really need to get it on a dyno to sort the carbs. I’m currently changing spark plugs more often than going to the petrol station. But before we hit the beach we made a detour to Llandeilo. Since replacing the rear brakes on the Escort I now need to replace the front discs and pads as the pads only have a few mm left on them. The racing pads chew through the discs so they’ll need replacing too. This is going to cost me well over £100 as I planned to upgrade the pads too. While I was spending this much money my man maths was suggesting that I may as well upgrade the calipers and discs too.😁 A popular upgrade on Escorts is to fit Austin Princess calipers. These get a spacer fitted between the 2 halves so you can fit vented discs. The discs on an escort are 247mm diameter but when fitting the Princess calipers they need to be 260mm. The way to get these is to buy BMW e30 front discs and redrill the pcd to fit the Ford hub, but some motorsport outlets do sell them ready done for some more ££££’s. You can know buy new Princess calipers on ebay. You can even buy them as a kit with discs and pads for the best part of £200 but for some reason the discs are only 240mm diameter this means the edge of the pad isn’t used so they’re no good to me. Then last night my mate messaged me to say there was a pair of calipers, correct pads, bolts/washers, a new dad of fast road pads and a set of part used race pads also, available for £100 and only about 12 miles from my house. The guy selling them had removed them from his Toyota Starlet rally car with 4age engine as he’d upgraded to alloy calipers. I may have to fit a bigger master cylinder but I’ll try with the one on there first. So after collecting the bits we drove down to Pendine (where it was raining), had an icecream and looked at some old cars. No racing happened though. Not really sure why but a guy I spoke to said that track was to wet at the far end 😩.
Jul 11, 2021 18:26:41 GMT
While I was spending this much money my man maths was suggesting that I may as well upgrade the calipers and discs too.😁 A popular upgrade on Escorts is to fit Austin Princess calipers. These get a spacer fitted between the 2 halves so you can fit vented discs. The discs on an escort are 247mm diameter but when fitting the Princess calipers they need to be 260mm. The way to get these is to buy BMW e30 front discs and redrill the pcd to fit the Ford hub, but some motorsport outlets do sell them ready done for some more ££££’s. You can know buy new Princess calipers on ebay. You can even buy them as a kit with discs and pads for the best part of £200 but for some reason the discs are only 240mm diameter this means the edge of the pad isn’t used so they’re no good to me. Then last night my mate messaged me to say there was a pair of calipers, correct pads, bolts/washers, a new dad of fast road pads and a set of part used race pads also, available for £100 and only about 12 miles from my house. Be very careful if you're using those under 13" alloys. I've had genuine Princess calipers on Sunbeams and Capris, and they needed the tops of the caliper ground down to get the wheel(Lotus Sunbeam, and 5.5"/7" RS 4 spokes) over them. The castings aren't particularly accurate, and one of them failed during a heavy stop. That's failed in the sense that the sealing O-ring burst through what was left of the caliper! We all quickly reverted to M16s(we had chamfered the outer edges of the pads for the stock 247 diameter discs) and none of the calipers had much metal left when we stripped them. These days, there are much better methods of fitting bigger and better brakes instead of M16 or 'Princess' calipers
Jul 11, 2021 18:31:52 GMT
Thanks Nick. I run Revolution Minators which have huge inner hoops so i shouldn’t need to grind the caliper (hopefully), but I’ll keep an eye on them. You never know what quality kit your getting these days.
Jul 17, 2021 18:02:07 GMT
I was up early this morning to mow the grass so o could spend some time doing more important things. I’ve not done it for 4 weeks due to work/other commitments/lazy. It took me 3 hours!! Once complete I took a look at the Escort’s new brakes. First I unbolted one of the m16 calipers to try on the new one and check wheel clearance. All good there. I think the big hoops on the Revolution wheels and the fact the alloy hubs are Group 4 which are machined to put the wheel 10mm further out has helped. Off with the old disc and on with the new. The new ones are 13mm larger diameter than the Capri ones. I refitted the hub and caliper and out in the DS3000 full race pads. They were very loose in the caliper and the outer pad was rubbing on the centre of the disc. I put the locating pins back in and the pad was free to move around by about 3mm. Also the pad was running about 6mm too far in so not making full use of the bigger discs. This seemed a bit of a pointless swap as the pad size is the same as the Capri caliper and the total piston volume is the same too. The performance gain comes from the pad being further out. If you look at the witness marks on the disc you can see the outer edge is not being used. So out with the welder and a couple of welds added to the edge of the pads. Grinding back the welds until the pad has only been made bigger by about 1mm either side has brought the pad within 1mm of the edge of the disc. This did have the problem of the locating pins no longer fitting with the pads back in so a bit was ground off the top of the pad so the it is now located securely and won’t wander about. Pads and pins back in. Even the pipe fitting into the caliper is the same as the Capri it the pipes are a bit mangled so I’ll make new tomorrow. I think these repro Princess calipers are ok but they’ve not machined the pad locating parts in the correct place so the pad fits correctly. The pads could be wrong but Ferrodo are usually pretty good.
Jul 18, 2021 17:36:56 GMT
Today I was up early again and fitted the 260mm disc to the hub and fitted the caliper to the other side (no photo). I went over my brothers to make up the 2 new brake pipes. They could do with being about an inch shorter because the caliper is bigger. I did this then went home to fit them. I started to fit them and then realised that in fact they were about 2” shorter and were now too short. In fact one was about 1/2” shorter than the other. What a numpty. This is one of those times that “that will do”, won’t do at all. I’ve cut some new pipe - hopefully the right length, and will get some more made up in the week. 😩
Jul 27, 2021 18:40:26 GMT
Having made new pipes I fitted them last week and took it for a spin to see how the brakes worked. It was quickly evident that there was too much braking effort on the front. I took it to my brother’s garage and he put it on the brake dyno. The balance was ok but he said there was a lot more pedal travel to lock the wheels on the back compared to the front. As the the Capri brakes were marginal I had connected the servo to work only on the front brakes. This then gave me the balance I required. Now I need to connect the servo to work on all the brakes. As I was a day off today I ripped out all the brake pipes in the engine bay and replumbed it all. The servo is on the passenger front so I had to get the servo feed into the master cylinder outlet, come back over to the driver side and into a 4 way block, then back over to the passenger side for the front caliper on that side. The photos don’t show much as the engine bay is quite full. When the rain dried up, I took it for a spin but it was obvious there was too much back brakes now. I hadn’t fully bled the brakes, just bleeding through the connectors. So assisted by Jones Junior (the younger), I bled the calipers and went for another spin. At first it felt like to much rear and then to much front. Now I’m starting to get danted. I have driven this car for years and I’m used to knowing exactly what it will do. Now it’s doing something completely different. I think being used to the old brakes where I would jump on them to stop is part of the issue. These bigger brakes with racing pads don’t need this. Another issue is when on the road I use old hard tyres on the rear to save my expensive tyres and because it makes the car feel like it’s got 300bhp. I need to try it with the R888Rs all round. I’ll swap them over when I’m off on Thursday and try it again. I’ll also see if I can get it back on the brake dyno. In other news I’ve finally booked the Cortina in for a session on the rolling road to have the carbs set up on 10th August. I spoke to the guy last week and told him the jets I had in it from the 1725 Hillman carbs. He said they sounded all wrong. I need to change the emulsion tubes to F16s which cost £18 x 4 but luckily I already have a set. He also said to fit a fuel pressure regulator to drop the pressure to around 3psi as this is what the Webers like to run at. So I’ve bought a filter king and got it fitted. As I run the standard mechanical pump the pressure shouldn’t be to high but now I’ll know it’s right. My plan was to fit it under the carbs out of the way but I’ve ran out of real estate on that side. I could have fitted on the passenger side but I didn’t want fuel pipes running around the engine bay. The only place left was on the bulkhead where there is a bolt to hold the top of the pedal box. Drilling new holes in the paint wasn’t an option so it is what it is. I don’t like it there but needs must. I gust put a couple of bends in the supplied bracket and bolted it on. I had a bit of fuel hose and some clips so it was only a half hour job.
Escort- So I took it for a longer drive so everything was warm, unlike the short drive last time. As the rear pads are standard they are good from cold. The front pads being full race take a while to warm up. To warm them up quicker I drive with the brakes on for a little bit. With everything nice and warm I’ve now backed off the rear brakes on the bias valve. It’s a lot more confidence inspiring now, but in the long term I think I’ll fit a bias pedal box, and keep the bias valve. When they run big brakes on the back of Escorts they tend to put a 0.65 master cylinder to the front and a 0.7 to the rear so they have less effect, but you still have the good hydraulic hand brake. Cortina- I can’t remember if I’ve already mentioned it, but on Tuesday I’m taking the Cortina to the rolling road to get the carbs set up correctly. So this morning I put it on the trailer ready so there’s no faffing on the day. I’ve changed the engine oil as it’s been in there 2 years and replaced the inlet manifold gasket as it was leaking coolant. The gasket I had originally fitted was a new one I had in stock but it had stuck to the cardboard packaging. I’d scraped it off with a razor blade but it obviously wasn’t right. It was only a small weep but I thought if it’s leaking coolant then it could also be letting in air to muck up the mixture. All sorted now. The rolling road guy asked if I had the vacuum advance connected to the inlet manifold. I’ve never run one on the race cars but as this is a road car I thought it might drive better with it. I needed to fit a take off for the manifold and happened to have one! But when I connected it up to try the engine was making a clacking noise. It sounded like a cam follower had broken up. I disconnected it and the noise stopped. I don’t know if it’s just the timing is not right for vac advance, or if it’s the distributor pulsing as the vac pipe is only connected to one cylinder? Anyway, I’ve disconnected it for now and blanked off the manifold. If the dyno guy wants to use it the facility is there. I also tried adjusting the tappets as they are quite tappety. After doing it, it sounded exactly the same. The rockers have worn so even though it’s right on the feeler gauge the gap is a lot more. I looked it a few spare sets I have knocking about and they are curse word too. As luck would have it there was a set of refaced rockers with steel shaft and steel rocker posts on ebay finishing the next day and I got them for £87. Bargain. They won’t be here before the rolling road session though so it will have to go sounding like a load of bolts being shaken in a baked bean tin. I have a spare set of Holby carbs that have the jets in them that were in the Cortina carbs when they were on the Astra I rebuilt (thread on here somewhere). I’m taking those with me as the dyno guy says all the Holby jets I’ve got in the Cortina now are pish. The emulsion tubes need to be F11 or F16 and that’s what the spares are, so using those will save me the best part of £80. I’ve also written down the Astra jets as that was set up on the same rolling road so I have them for reference. I’ll stick them on here if anyone needs to put a set of Weber 40s on a Vauxhall red top engine. A standard engine made 179bhp flywheel 137bhp wheels with this set up. I also had to do the yearly “pull all the lights apart on the trailer” exercise as everything corrodes. I keep meaning to swap them to an LED setup but the lights fit the recess on the trailer and have built in triangles. The rectangle LEDs look a bit clunky, but at least they would work. They all worked on the wife’s Rav4 but not on my Avensis so I put a new lighting hitch on that and all’s good.
if you have a dial gauge you can set the tappets accurately even with the wear.
if you have a dial gauge you can set the tappets accurately even with the wear. I do have a gauge, but my thinking is that as they’ve already worn through the surface hardness then they’ll only get worse and the refaced ones have apparently (let’s hope) been rehardened. Edited to add - I did use the dial gauge to make sure I was adjusting with no lift but did not think to use it to set the gap.
Last Edit: Aug 9, 2021 8:49:02 GMT by jonsey
