Jul 11, 2016 18:38:35 GMT
Not much in the way of pics, but all the welding on the shell is done. Did the last bit today, making the front crossmember and valance removable. The front arches are done. If you look at the last pic on page 10 you can see filler on the wing as id got the shape slightly wrong. I cut that section open and re did it as I wasnt happy with the filler. Rear arch is done too. The arches on these vans are a nightmare to fix!! Only welding left to do is tidying up the door bottoms.
Last Edit: Jul 11, 2016 18:41:15 GMT by VW
qwerty
Club RR Member Number: 52
Jul 11, 2016 20:50:31 GMT
You've really smashed through the work on this! Its looking great. I bet you're looking forward to getting on with the more "fun" stuff.
Tom
Jul 11, 2016 20:55:26 GMT
Cant wait to start making it nice! I'm hoping to have it back up and running and painted so I can go away in it mid august!
Jul 18, 2016 18:20:37 GMT
Still lots going on. Got one door welded up and a few more bits painted. Got all the rebuilt steering fitted and all the bits n bibs in the engine bay done. Just need to add oil and its a runner again. Next step is to refit all the panels so I can do a bit of filler work and get the panel gaps right ready for paint and re fit the front brakes. Will be back on its wheels in a day or two so we will FINALLY have a result on the front lowering too. New pics as soon as that happens
Jul 18, 2016 18:23:02 GMT
Just realised I hadnt even mentioned the engine and gearbox went back in last week!
New gearshift bushes work a treat, as does a temporarily repaired gearbox mount.
Jul 19, 2016 19:25:40 GMT
Got the brakes rebuilt. Still need to get flexi hoses so not bled yet. Wheels on so dropped it on the floor. Ah. Its only a tiny bit lower than stock hence the huge positive camber. It needs more off the springs. Suspension still needs to be a bit stiffer so its no problem. Everyone seems to think I should drive it a bit first but I cant see it settling 2". Ill leave it as is for now and get on with other stuff. Need to time it, paint and fit prop, finish brakes and get coolant system done before I can drive it anyway.
steveg
Jul 19, 2016 20:38:47 GMT
Your missing a bit of weight without the bonnet, doors, screen and other bits and pieces so it might drop down a bit yet. Did you leave the suspension bolts loose as the bushes might hold it up a bit as well if they were tightened with no weight on.
Great job though !
Jul 19, 2016 20:52:17 GMT
Bushes are loose. Bonnet weighs nothing, doors are heavy though. But even with 2 adults in it its not having much effect on ride height.
Jul 19, 2016 22:16:08 GMT
Nice work. I recognise that workshop
Jul 21, 2016 18:57:24 GMT
Fell down the stairs this morning so stiff and sore. Still, half a day at work so van time. Filled engine with oil and fired it up. Started imediately. Put a light on it and set timing. Couldnt run it long as there is no cooling system yet. Fitted the prop and filled the gearbox oil. Set the gearshift properly and a few other buts n bobs. Then I decided id do something about the height. Took the springs out and put one side back together. Running the wheel through its travel showed I have full clearance throughout all travel at all lock even when its on the bumpstops. So I chopped the springs some more and this happened. looks ace but will end up with smaller tyres so will look bad again at some point. Cant really go lower with the suspension as geometry will get wierd and scrub line will get iffy so any lower will require chassis mods. Its fine where it sits for now though. Still too much positive camber though. The camber doesnt correct untill its on the bump stops so I obviously got my sums wrong. I think I might know what I did wrong, but whatever. The end result is I need to move the bottom arm pivots again. No big deal.
Jul 21, 2016 19:56:48 GMT
are the steering knuckles symmetrical ? just thinking (wondering) if it clocks any camber on when the wheel is in "not dead ahead" position
Last Edit: Jul 21, 2016 20:02:44 GMT by darrenh
Jul 21, 2016 20:07:55 GMT
Camber does alter with steering but not by this kind of amount. It doesnt look too bad in the pic but its worse in reality. Not worked it out in degrees but bottom of the wheel is 15mm in compared with the top.
Jul 21, 2016 20:50:37 GMT
fair do's thats quite a bit, and aesthetically maybe not great. if its a "handling" concern (yeah i know i know, its a camper!) you have a bit of "dynamic" coming into play, with caster and roll camber from the wishbones.
Jul 21, 2016 21:00:35 GMT
I'm not so fussed about handling, just want it to drive ok and look right. Not sure what I did with my original notes on working it out so not sure exactly why I got it wrong. It all seemed to work out ok on the bench. But it doesnt really matter what mistake I made, end result is the same and its an easy enough fix. it'll be sitting perfect by end of play on saturday
Jul 21, 2016 21:08:19 GMT
have you done the old roll it backwards and forwards with some weight in it trick? might be a bit of wheel "tuck" because the wheels hit the floor at full droop
wishful thinking!
Last Edit: Jul 21, 2016 21:08:33 GMT by darrenh
Jul 21, 2016 21:18:52 GMT
Lol, yeah, I did try.
Its obvious when moving the suspension through its travel and watching the camber changes that ive either set it up to have 0 camber at the wrong part of its travel or...
I may have worked out how far I needed to move the bottom of the rim, then applied that to the moving of the bottom ball joint meaning ive pulled it in too far.
Ok, so where we at. Its all mechanicaly back together. Everything has been cleaned and painted so its all nice underneath too. Put some new rear wheel cylinders in it too but having trouble getting it all to bleed out. Ill get there eventually. I re positioned the bottom pivot mounts to remove the positive camber and it sits well now. Trial fitting all the front end panels. Got a door on too. Bodywork will start in the next day or two. Got one rear door welded up, one more to do and that will be the end of welding! Ive also repaired the woodwork around the inside of the side windows and made a new wood side for the pop top frame. All wood will get soaked with wood hardener. Doesnt seem like much has happened but its sooo close to filler and paint prep
Loads of filling Loads of sanding Master cylinder rebuild Drives but no brakes Sits nice About to mask for primer Going to be a late one!
And its in primer. The bad news is I can now see which bits of bodywork wernt up to scratch. No late night top coats for me then.
Davey
Resident Tyre Nerd.
Well that's awesome! Well done.
K11 Micra x3 - Mk3 astra - Seat Marbella - Mk6 Escort estate - B5 Passat - Alfa 156 estate - E36 compact Mk2 MR2 T-bar - E46 328i - Skoda Superb - Fiat seicento - 6n2 Polo - 6n polo 1.6 - Mk1 GS300 EU8 civic type S - MG ZT cdti - R56 MINI Cooper S - Audi A3 8p - Jaguar XF (X250) - FN2 Civic Type R - Mk2 2.0i Ford Focus - Mercedes W212 E250
