Sept 13, 2018 16:02:14 GMT
Had my first walk around the car since getting it back from DCe, making a list of jobs still to do. Probably missed a lot but this is something to work on :-) Steve
Secure intercooler Modify radiator brackets to allow repositioning. Fit air filter box Finish air intake pipework Fit header tank pipes Get header tank filler cap New pipe from overflow bottle to header tank. Make new exhaust heat shields in CF Fit wiper motor (either fix original or replace) Finish front bulkhead and add heat shield material Finish engine bay bodywork Secure and adjust steering rack/rod ends for bump steer Finish front clip Fit injector rail and injectors Connect up loom. Adjust position and wire lengths where necessary Repostion ECU support bracket Fit dash cover and cut hole for access Fit screen wash jets and piping Weld in additional roll cage tubing behind seats Fit roll cage cushioning Fit interior panels Make doors and glass Secure glove box door Secure switch panel Secure centre console and tidy up edges Make front screen Make and fit new roof and rear screen Sort out fire supression system Fit EGT and Lamda sensors Fit oil filler cap Get and fit plug leads Fit plugs Secure fuel tank and nitrous bottle Get new electric bottle opener (or fix old one) Fit fuel filler cap Fit rear lamps Finish droop limiters Tighten ALL nuts and bolts, marking as I go. Door locks and hinges Get seat belts and fit Parachute bracket Under floor trays, side splitters and strakes Rear view mirror Fit and wire up remote tyre temp sensors Change front springs Make new radiator bottom hose Fit hose clips to header tank hoses and secure Fit exhaust box and cover Fit heat shield material behind exhaust box Fit boot Bond in floors Bolt on exhaust manifold and turbo Fit turbo support strut Reposition alternator/battery cable Repostion loom through bulkhead and fit grommets/covers Final fit of loom, adjusting wire lengths where necessary Connect battery Sort out wheels and tyres
mrtow
Sept 13, 2018 20:53:58 GMT
Loving the to-do list on this thread: Secure intercooler Modify radiator brackets Fit this Reposition that Tidy up the whatsit Make doors and glass Fit... WHAT!! Make doors and glass!?!? Seriously, keep up the good work. Inspiring stuff
Sept 13, 2018 21:24:01 GMT
Against the likes of Steve Green I guess? Blimey, Malta is a long way to go to get a car built, no one local? Is he getting his Anglia/Pop rebuilt or a new ride? He currently runs a Mk1 Escort with a BIG turbo'd C20LET in it - runs low 8's (Or at least it did before it went out to Malta) Justin Ladmu is rebuilding it in time for Malta's 1st drag event of 2019, then it'll get shipped back as far as I know. It was supposed to be a 1yr max but as usual plans change and its been nearer 3! It is great that Kev is still Drag Racing - I spoke to him at the Pod about three years ago and he still wants to go faster! Those Maltese Fords are killers and I'm sure will get Kev into the 7's.......Which is unreal. But a lighter, more aerodynamic, Elan should be faster still??
Sept 13, 2018 21:34:47 GMT
He currently runs a Mk1 Escort with a BIG turbo'd C20LET in it - runs low 8's (Or at least it did before it went out to Malta) Justin Ladmu is rebuilding it in time for Malta's 1st drag event of 2019, then it'll get shipped back as far as I know. It was supposed to be a 1yr max but as usual plans change and its been nearer 3! It is great that Kev is still Drag Racing - I spoke to him at the Pod about three years ago and he still wants to go faster! Those Maltese Fords are killers and I'm sure will get Kev into the 7's.......Which is unreal. But a lighter, more aerodynamic, Elan should be faster still?? You can never go fast enough. Saw some Matlese cars at Doorslammers. Bloody quick but virtually mini top fuel cars with engine rebuilds after each run! Not sure about that. I am very grip limited with not the best axle for drag racing (independent double wishbone). On race fuel we have around 600bhp (around the limit for my chassis/suspension) and car should, hopefully, weigh around 650-700kg. I would love to get into the 8s but 9s will be pretty quick for a road legal car.
Sept 13, 2018 21:42:57 GMT
Loving the to-do list on this thread: Secure intercooler Modify radiator brackets Fit this Reposition that Tidy up the whatsit Make doors and glass Fit... WHAT!! Make doors and glass!?!? Seriously, keep up the good work. Inspiring stuff :-) Door carcass weighs around 6kg. Replaced skin with carbon and drilled 400 holes and got it down to 3kg :-) The thought of doing this again to the driver's door got me thinking about making a complete carbon door. So far I have made a mould for the external skin. Next task is to repeat this for the rest of the door.
bstardchild
Club RR Member Number: 71
Sept 13, 2018 22:28:30 GMT
That is a metric curse word load of holes!!!!
Sept 14, 2018 8:18:13 GMT
That is a metric curse word load of holes!!!! When drilling them it didn't seem to be that many, I was just concentrating on removing as much fibreglass as I could (there is still room for more holes :-) ). However, the thought of doing it again doesn't actually fill me with enthusiasm so I will attempt to make a carbon door instead. One advantage of doing this is that the original door isn't made unsalable :-)
820
Sept 14, 2018 14:30:01 GMT
Amazing build. Is there a target figure you know of that needs beating to make this the worlds quickest Elan?
Sept 14, 2018 14:54:59 GMT
Amazing build. Is there a target figure you know of that needs beating to make this the worlds quickest Elan? Thanks. Actually, no :-) However, the plan is to set a benchmark and then see if anyone challenges it. Sort of 'I have built and own the fastest UK road legal Lotus Elan in the world. It does the 1/4 mile in x.y secs @ zzz mph" and then see what comes out of the woodwork. As there were only around 13,000 (can't remember the exact figure) built and most of the surviving cars are kept as standard, there isn't much competition :-) There are a few running highly turned twincam engines (mine was around 200bhp back in the early 80s) but nothing I know off approaching the power at my disposal. It would be great if there is someone out there as daft as me :-)
820
Sept 14, 2018 15:22:14 GMT
I think you just laid down a challenge to find some base figures, I had a quick look on youtube but nothing. What was your best with the old set up? No matter what happens speed wise the car is very special and I am looking forward to seeing it up and running
Sept 14, 2018 15:37:42 GMT
Sort of a 'I have built the world's quickest Lotus Elan...prove me wrong' sort of thing. I like it
jamesd1972
Club RR Member Number: 40
Sept 14, 2018 15:50:08 GMT
Hummm, not a lot of competition I suspect ! Anyway, keeps you off the streets bothering people.... James
Sept 14, 2018 15:51:50 GMT
Great project. Back in the early 2000s I had a friend who built race engines for a living, (name was Martin Cheetham, specialised in Aston Martins, if you google him you will find a vid of him setting hillclimb records in 1988). He had an ongoing Elan project that was running a heavily tuned Vauxhall twin cam engine. It was a beast, I don't know any figures, but he regularly attended track days and showed me a video of it at one where it was overtaking cossies etc. Sadly I don't have any pics as it was the days before camera phones. I've lost touch with him now and he must be in his 80s by now so not sure if the car still makes any appearances on the track or if he still owns it. Wish I could get more info, or find a pic as whenever I see your thread title I think of that car and how I would love to see a race between his car and yours once complete! I would know the car if I ever saw it again as it had a very distinctive hand crafted bonnet that I struggle to describe, but I think was designed to aid downforce, scooping the air under and over.
If at first you don't succeed........ ....Don't try skydiving!
Sept 14, 2018 15:54:43 GMT
I think you just laid down a challenge to find some base figures, I had a quick look on youtube but nothing. What was your best with the old set up? No matter what happens speed wise the car is very special and I am looking forward to seeing it up and running Yeah, when I started this project I scoured the internet looking for someone who had done the same. There was a rumour that there was another Elan with a (I believe) NA YB Cosworth engine, but I couldn't find it. The old set up was a 1650cc Lotus Twin Cam tuned to the (at the time) eyeballs. 168whp so around 200bhp at flywheel. Ran high 12s at around 120mph. Someone who knew how to drive could probably have got it into the low 12s :-) Thanks, I am looking forward to this as well, but with some trepidation!
Last Edit: Sept 14, 2018 16:34:30 GMT by nalesutol
Sept 15, 2018 17:31:33 GMT
Great project. Back in the early 2000s I had a friend who built race engines for a living, (name was Martin Cheetham, specialised in Aston Martins, if you google him you will find a vid of him setting hillclimb records in 1988). He had an ongoing Elan project that was running a heavily tuned Vauxhall twin cam engine. It was a beast, I don't know any figures, but he regularly attended track days and showed me a video of it at one where it was overtaking cossies etc. Sadly I don't have any pics as it was the days before camera phones. I've lost touch with him now and he must be in his 80s by now so not sure if the car still makes any appearances on the track or if he still owns it. Wish I could get more info, or find a pic as whenever I see your thread title I think of that car and how I would love to see a race between his car and yours once complete! I would know the car if I ever saw it again as it had a very distinctive hand crafted bonnet that I struggle to describe, but I think was designed to aid downforce, scooping the air under and over. Thanks Over the years I have searched for and not found any seriously modified road going Elans, apart from mine :-) I searched for Martin but everything relates to Aston Martins, not an Elan in sight. Oh well. Once it is out and setting some times and I make the fastest Elan claim we will see if anything comes out of the woodwork :-)
Sept 15, 2018 21:29:50 GMT
Yes I did a bit of googling too hoping somebody might have snapped it at a track day or something, but no joy. But I do know it exists! Or at least it did 15 years ago...
Sept 15, 2018 22:16:23 GMT
Yes I did a bit of googling too hoping somebody might have snapped it at a track day or something, but no joy. But I do know it exists! Or at least it did 15 years ago... Lotus Elans rarely get scrapped (unless they catch fire, and even then all you need is the identification plate :-) ) so it is probably around in one guise or another.
Sept 20, 2018 18:06:38 GMT
Last Edit: Sept 20, 2018 18:07:19 GMT by nalesutol
Sept 23, 2018 16:27:35 GMT
Front and central aero panels in position. Next task is to fit the fasteners. After that I need to add some additional sections to cover the holes between the front tyres and existing floor, just visible behind the tyres.
Last Edit: Sept 23, 2018 16:39:12 GMT by nalesutol
Sept 24, 2018 22:16:51 GMT
Started on fitting front aero section support brackets. Made the long straps out aluminium to start with in order to sort out length and angles. Then used these as moulds for the aramid/carbon mix which are less than half the weight of the aluminium ones. looking closely you will notice that I have used the P clips I made some time ago as the main support brackets.
Last Edit: Sept 24, 2018 23:01:00 GMT by nalesutol
