Thanks Rob, Yeh, I have spent an awful to of time shaping metal after grinding and cutting a lot of rot out of the car. There has been a few times when I was ready to chuck it to be honest. Lost the mojo for it many times.
Cheers Col.
very easy to loss interest , iv have done it many times , fly at it then come to a grinding stand still
MR TIKI
TIKI,style from a different angle!
Wow!! there's some IMP'ressive work going on here,top job.
Boldly driving faster than a tin worm can wiggle.
Thanks guys. Mr.Tiki. your Imp is always an interesting Imp to check out as it is forever evolving and going your own way with it to. Nice one. Cheers Col.
Last Edit: Feb 2, 2016 23:30:57 GMT by colimp66
Rob
You know, for kids!
Thanks Rob, Yeh, I have spent an awful to of time shaping metal after grinding and cutting a lot of rot out of the car. There has been a few times when I was ready to chuck it to be honest. Lost the mojo for it many times. Cheers Col. Easy to be overfaced by it all. I have to make a list of small things that will contribute. Sometimes 'derust and paint rear lights' is easier to face than 'rebuild steering' whne you only have an hour to spare but can leave you with a good accomplished feeling
Bang on Rob, I've learned not to be overwhelmed by the massive task of restoring/modifying a car anymore and do the little jobs that mount up to the finished product hopefully. Small goals regular accomplished keeps the mojo inline. lol
Cheers Col.
Mar 21, 2016 21:06:06 GMT
Last Edit: Mar 23, 2016 13:35:26 GMT by colimp66
Mar 21, 2016 22:27:49 GMT
But that's the undercoat. Looks good! What's the deal with legalities and adjustable steering columns like you have done? Over here any non standard column needs to be collapsible, etc. Probably wouldn't be able to use bike clamps either.
The steering column I have fitted is from a Rover 100 and is collapsible at the bottom of the column. The bike clamps are high tensile and can always be swapped over for bolts easily if required. Cheers Col.
Mar 29, 2016 11:41:26 GMT
Some more progress over the weekend with getting the Imp back on its wheels and rolling it out of the garage for the first time in a long time. Cheers Col.
Mar 29, 2016 12:36:24 GMT
A few more photos of it's journey to be put back on its wheels. Cheers Col
Mar 30, 2016 18:23:39 GMT
Something I've had brewing for some time for my Imp and took the plunge last might and made some space for it. Then slipped it in that space on a skateboard as you do. Cheers Col
Mar 30, 2016 18:49:36 GMT
Very nice work sir.
I have gone with Clark Dawson K-series BMW engine in my G15.
Ginetta G15 BMW K1100 conversion Sold Mk1 Mx5 on ITB'S Sold TVR Chimaera 400 supercharged MR2 Red Roadster 2ZZ Bee*R 324 Skyline 95 Cherokee Jeep
Mar 30, 2016 19:31:37 GMT
Thank you. Yeh, Clark has put a lot of work into that conversion and you won't need to cut the bodywork like I have which is important to a lot of people. It also uses the Imp gearbox which had the bonus of having a reverse gear which I won't have to start with. How far on are you with the conversion? Next good to see. Cheers Col
Mar 30, 2016 21:43:49 GMT
Mocked up the diff tonight and the driveshafts balancing on a tin of filler at roughly the height it will need to be placed at in.my mind. And how it is up against the engine Cheers Col
v8ian
Mar 30, 2016 22:04:15 GMT
I'm liking this, A quick question, does the rack steer from the rear of the suspension or from the front? I need a rear steer for a project,
Mar 30, 2016 22:59:22 GMT
Cheers, The trc arms are in front of the suspension. The photo from the underside shows the stainless arms waiting to be attached to the track rod ends and hubs once I fitted them later that day but didn't take a photo of, sorry.
Col
Mar 30, 2016 23:43:16 GMT
Ahhh, skateboards. Small engine converters dolly of choice. What's your plan for reverse? Probably not a trapdoor you can poke your feet out of and push. Although the car will be light enough.
May 13, 2016 10:50:55 GMT
Not a massive amount achieved over the past few weeks as I have been busy working and trying to raise some cash for the next bout of work on the Imp. Anyway I managed to pick up the coupling for to take the drive from the engine to the differential. Here is the main part of it which I need to weld a very short prop onto then to a flange to the differential. Cheers Col.
May 15, 2016 21:35:13 GMT
Started on the engine cradle this afternoon using 34mm thick wall tubing instead of the usual box section used in most conversions. Not a lot achieved but it's a start. All the engine pick up points have been made and I need to join them all together now :-) Cheers Col
