brc76
Oct 15, 2020 12:44:23 GMT
Got the missing bushing for the gearstick end of the shift rod. Searched for the M7 bolt and locknut. I have a tray of new locknuts, metric only in this house, but no m7. 30 min wasted but found it. Put the gear change mechanism in the car, have to decide on position. Pic 1 is mercedes location, but the rods go uphill to the shift yolk on the gearbox. Pic 2 is shift rod level. 70mm higher than stock. I think 40-50mm higher than stock would be a good compromise, the linkage doesn't bind in any way at the top or bottom regardless of what I choose. I'll need to make some, ahem, adjustments to the tunnel and rather than cut up the stock mercedes manual trans cover plates, I'll make my own?
Last Edit: Oct 15, 2020 12:47:00 GMT by brc76
brc76
Oct 16, 2020 20:40:32 GMT
Last night's work: One gearshift mount, now for the front cover!
brc76
And top cover roughed in. I have started writing notes on my metal parts so I know where to fold and more importantly which way to fold. Because no one ever has folded something backwards have they?
Last Edit: Oct 17, 2020 2:09:51 GMT by brc76
brc76
Working on house today, so no merc action, but I fulfilled a lifelong dream this afternoon. I bought a drill press or pillar drill depending on where you are. It was local, good price, and hardly used. 1969 Craftsman. 15in travel. It is 6' tall. Its massive. Way way way more than I will ever need, but for $100 who could say no? No? Guy's dad bought it new, guy has had it for 20 years and has never used it. Came with manuals and spare belts. Result. All I need to do is give it a once over, Oil it and I think get a half-way decent cross slide vice.
Last Edit: Oct 19, 2020 1:42:36 GMT by brc76
jpsmit
I have never seen one in that nice of a shape, well done!
brc76
Oct 19, 2020 19:23:32 GMT
It still has the plastic over the metal data plates.
I'm the sort of person that needs to remove them on anything new. I will resist that temptation.
brc76
Decided to paint the trans tunnel covers, awaiting bolts and some gasket material to make it complete Did some research on aluminum and such, then decided to start looking at the rust nasty that lurks on the rear drivers side... well, it's not nearly as bad as I feared. You can see some factory seams here and there which is nice. I mean it is crusty and there is some surface rust, but I think this is actually easier to deal with than almost anything else I've done already. A lot of this scabs. Otherwise the repairs needed are pretty much flat or angle. Apart from the rear arch corner, obs. And I found these sitting on my workbench. I think the fuel injection gods have been leaving gifts again. I mean they are pretty.... I blame yoeddynz
Last Edit: Oct 21, 2020 2:13:44 GMT by brc76
Oct 21, 2020 21:31:56 GMT
I mean they are pretty.... I blame yoeddynz Brilliant.
brc76
Last Edit: Oct 24, 2020 2:06:44 GMT by brc76
brc76
We all knew that the holes were going to get larger, didn't we! Chop Chop! Needs tidying and squaring up then I can start adding less lightness. Does this mean that the Merc is the polar opposite of a lotus? Safety note: Don't forget your safety gear and keep angle grinder shield! Was being good, and had a disk explode on me. I wasn't even doing stupid things with it. Had chunks of disk all over me, but yet I remain not injured! I know the disk shield can sometimes be a pain, but it has it a purpose!
Last Edit: Oct 27, 2020 2:15:06 GMT by brc76
brc76
Still pottering along with this! I have progress! Patched the trailing end of the sill and corresponding chassis rail to almost the bump stop. Happy with that. Mostly.... Also chopped out the trailing end of the rear arch. I had been looking at repair sections, but given the cost of getting one here, there will be an attempt at making it myself.
Last Edit: Dec 17, 2020 4:16:26 GMT by brc76
brc76
For my first arch work, I am as happy as I can be. There is work to be done to tidy up, and seam seal, but I have seen worse. I mean I've seen a lot better, too.... yes... mostly better now that I think of it.
Last Edit: Dec 24, 2020 4:29:58 GMT by brc76
brc76
Been working on the house project, so little updates. Had to change the rocker cover gasket on my t4 as it had been leaking enough to cause a misfire. Turned out that when the previous owner had the water pump and timing chain done, the garage left out the gasket for one of the spark plug holes. I had been putting it off as long as possible, until I finally got a check engine warning. This picture sums up why I was procrastinating. It's VW / Audi service position! I still had to take the alternator off.
Last Edit: Apr 25, 2021 0:05:41 GMT by brc76
brc76
Generally the last year has been a bit rubbish. I'm not sure why....
T4 has been fine, I've had the check engine light on since April, but I don't want to repeat the service position. or spend the money on the intermittent fault that the exhaust bank cam position actuator is having. I'll need to address it before the end of Feb otherwise it'll fail it's annual inspection, and no one wants the big red R sticker on the windshield.
I've recently started working on the Merc a little more as well. My house building projects are stalled while I wait for the trade that I'm not allowed to do here. Plumbing is the one thing the state will not permit a non-licensed person to do. Electric work is up to the local inspector, prove you have a brain cell? you are good to go. Any trade here is overwhelmed and busy busy busy.
So where we left off, I pretty much stopped. Over the last few days I've tried very much to get back into it. I've stripped down the new to me rear axle with the 3.27 ratio, stripped in the sense of removing the old brakes, lines and rubbers. I sandblasted and POR15 coated all the suspension arms, then top coated. I've re-bushed the arms and re-installed them onto the axle. In removing the old axle, I found the source of the large "clunk" I got when shifting from forward to reverse or vice versa. The link arm that joins the differential to the car had worn to about 1in of play at the mount. oops.
While that has been going on, I have also removed the gas tank and wire wheeled the tank and the underside of the rear of the car. I wanted to get rid of any remaining loose paint, underseal or surface rust. I'm glad I did, as 2 holes appeared and some filler I wasn't aware of appeared. All that has been then painted and undersealed. I'll deal with the 2 holes when I turn the car around at some point, they are too close to the garage door for me to really get to very well.
Last night I fought with the axle to get it back in place, I'm most of the way there. I'm going to try to keep getting on it a few nights a week. Maybe I'll even remember to take some pictures.
Last Edit: Jan 15, 2022 1:37:21 GMT by brc76
brc76
Jul 10, 2022 12:23:31 GMT
Been a while! I fought with the axle and fought it some more. Then when I thought I was done, I fought it again. The issue was trying to get the angle of insertion correct. There is a carrier in the floor of the boot that locates the swing axle. It's an arm that is attached to a heavy, bendy axle that has a mind of it's own. For something that came out so easily, it really did not want to go back. Or perhaps what I should say is, it only wanted to go in when all the stars were aligned, and it felt like it. I had initially thought that I would get the trailing arms all in place, with shocks and springs and the rear compensator spring. It's much easier to install these off the car than when the axle is under the car, but that was a mistake. In the end I stripped the axle down again to just the bare unit and then the center support went in fine, almost easily. Almost.... All arms, springs, shocks, etc were put back on, without drama. I lost the rear brakes. I have 3 sets of rear brakes for this car. I found a set, stripped and seized bleed nipple, I don't want to deal with that. Look again for several days, find another set, the rebuild kit doesn't fit. It appears that I have a combination of different piston sized ATE calipers. I had assumed that the rebuild kit was delivered incorrectly, bit the replacement also didn't fit. I ordered another brand and it too, didn't fit. I go and look at the 1st set of calipers and they are the correct size for the kit. From what I can see, and it's not clear, that either the early cars had a carry over from the W111/2, or USA and EU cars started with different sized rear calipers. either way, what I had didn't fit. I used the set that had seized bleeders and ended up tapping them out and using a repair kit to..... repair them. I also painted them while they were stripped down. I thought I had ordered black paint, but red was in the tin. Red was used begrudgingly. New brake lines, bled them, handbrakes adjusted, I can move on to something new. Well something old. When I replaced the sill on the P/S I had left the trailing end rough and this was done knowing I would have to replace the rear arch. I didn't want to do it then, and I still don't, but it's the last major rust that I have to deal with so... It's the first photo I've taken this year of the car. Yeesh! I also put the hood back on and wings are also back on. Mostly. OK, mildly. Last night I put the DM flywheel on the engine, clutch and after fighting the gearbox for 30 min, gave up before I hurt myself. I'll try again later today after work.
brc76
Jul 10, 2022 12:24:44 GMT
I really want to get this out of the garage and clean everything out and up.
Paul Y
Jul 10, 2022 16:22:38 GMT
I really want to get this out of the garage and clean everything out and up. Feel you on that! I have a Mojo failure at the moment so about to go outside, push Woody out of the shed and have a clear up in teh vain hope this will reignite the spark. Nice work there, I really like these old Merc's. P.
Last Edit: Jul 10, 2022 16:23:00 GMT by Paul Y
brc76
Jul 10, 2022 22:19:01 GMT
I had written some waffle regarding getting metric bolts in the USA, the gearbox going almost straight on, cutting down and modifying the driveshaft to work with the newer gearbox, getting the car on it's wheels, and outside, cleaning up, but effing crashing computer saw that off. So I will leave you with this. The car is outside for the first time since September 2018. I forgot how many shades of grey it is. I forgot that all the window seals leak water. I pressure washed it 2x. It's still filthy. It is sitting very high in the front. I know the M104 is slightly lighter than the M129, but its very reverse raked.
Last Edit: Jul 10, 2022 22:20:45 GMT by brc76
brc76
Jul 17, 2022 11:18:53 GMT
Gearbox has oil in it now,
Clutch lines made up, and although I think there is still some air in the system, I have a clutch that looks like it will actually work!
I was worried that the combination of parts - a DMF from Germany ordered off the bay of e, 3 years ago, a new clutch pack ordered for another car, gearbox from another that it was going to fail, but no, it works as intended!
Thanks to everyone for their help when I asked questions!
The two fails of the day 1) I ordered a M103 oil filter housing - it's shorter than the M104 one with a screw on filter rather than the cartridge M104 one. I went to install it and found that in the past I had already installed a M103 housing. Oops. 2) Got a filter for said oil system, it fouls the intake I was making. Rats. looks like a remote oil filer is in my future.
