Jul 17, 2022 13:31:25 GMT
2) Got a filter for said oil system, it fouls the intake I was making. Rats. looks like a remote oil filer is in my future. How much extra clearance do you need to clear the manifold? The m103 filter has a m20 thread so you can fit different filters.
misteralz
Was gonna suggest that - smaller filter and change the oil more often.
madmog
Club RR Member Number: 46
1966 Merc 250s M104 madmog
@madmog
Club Retro Rides Member 46
Jul 23, 2022 22:21:20 GMT
Last Edit: Jul 24, 2022 16:45:00 GMT by madmog
brc76
Sept 22, 2022 20:15:59 GMT
Yeah, it's a M20 confirmed when the remote oil filter kit I ordered turned up with the incorrect adaptor and I had to argue with summit racing. It's my understanding that the correct thread is crawling the globe to me. The unit that turned up had a 3/4 thread for the filter.
I decided to get the starter installed - test that out and get onto the next steps. In my extended period of not working on the car, the engine decided it no longer wished to rotate. bugge.r
Spark plugs out, ATF down the bores, many days of walking out to the car, trying to see if it's free(er), camshafts loosened to reduce the load on the crankshaft nut and success! I now can get the engine to turn over on the starter on a jump pack!
I am now waiting for camshaft bolts to replace the loosened off ones. I believe they are a single use bolt - or perhaps they are not, but 2 of the removed bolts had clearly stretched and there was no chance they were going back in!
I also could see that the M103 housing for the oil filter leaks. The mating face is warped. Good thing I forgot I had it and ordered another one off ebay a few weeks back.
Now.... where did I put it?.......
Last Edit: Sept 22, 2022 20:17:09 GMT by brc76
brc76
Oct 13, 2022 18:09:05 GMT
Summit 3 weeks ago : Yes the MFG is sending out the correct part
Summit now? : We have no record of an issue on that order.
I think I will just tap the tread to the correct one, there is enough meat to do it.
Last Edit: Oct 13, 2022 18:10:09 GMT by brc76
75swb
Beta Tester
Club RR Member Number: 181
1966 Merc 250s M104 75swb
@75swb
Club Retro Rides Member 181
Oct 13, 2022 20:24:50 GMT
Summit 3 weeks ago : Yes the MFG is sending out the correct part Summit now? : We have no record of an issue on that order. I think I will just tap the tread to the correct one, there is enough meat to do it. Well that's unhelpful... this must have dropped off my bookmarks as i haven't checked in in a while, good to see progress!
brc76
To be fair, I'm not making speedy progress! I am also working on my house, currently redoing a bedroom and 3 bathrooms, so it's not like I'm doing nothing all the time.
