edk83
Sept 28, 2020 15:34:26 GMT
Got myself some fancy mounts, polybushed all the rest of the engine steady mounts as well. Engine bolted in, lots of plumbing and wiring to do, Getting a GT30 with a 53mm shaft made up hopefully then I can start on the downpipe
Sept 28, 2020 17:00:08 GMT
I had very similar engine mounts on my mk2 jetta when the whole car was polybushed. I ended up going back to New stock engine mounts as the nvh was crazy.
edk83
Sept 30, 2020 15:09:58 GMT
I'll have to see how it goes, this one is the fast road version rather than the race one. something needs to keep the engine in check though!
edk83
Oil cooler mounted, lines will be routed properly Although I do quite like the Bosozku look!
Can you let me know how much the oil temp drops after this is fitted?
madwrx
in my experience often the problem is stopping overcooling --my last subaru could,nt get above 75 degrees(19 row),,at those temps the oil doesnt evapourate off fuel and water vapour ,and they take ages to warm up ,lesson learned to always fit a stat lol ,,
madwrx
Oil cooler mounted, lines will be routed properly Although I do quite like the Bosozku look! ed i would consider remembering that those oil lines will have 100 degree oil at full oil pressure running in them mate ,i ran braided sleeved lines with fire sleeving on my oil cooler -recently 3 years after fitting i changed exhaust headers and the return line from my small oil cooler was burnt to death out of sight above the header ,only saved by the fire sleeving,not sure how long it would of continued like that. i had a cooler split its core years ago with a cold engine and it pumped the whole 5 litres on my driveway in less than 5or6 seconds,if the engine had been up to temp and driving it would have lunched my new engine and may have burnt the car to the ground ,,
edk83
I did think about upgrading the lines to braided AN ones but these pipes are pretty tough, better safe than sorry mind. The sandwich plate has a stat in it so the cooler circuit will only be used once upto temp, with the turbo helping to heat the oil I'm sure it won't take too long.
Have seen an oil cooler pipe fail and it did come out quick!
Luckily my ecu will be monitoring oil pressure and has safety cuts I'll setup
edk83
Fitted a teflon spacer to the inlet last night, gives me a little more clearance to the head and should help with heat soak into the inlet.
edk83
Breather tank is going to live there, cheeky ball valve on the drain
edk83
Attacked the front panel! Not too bad I think
edk83
Calling that done Pipes next
edk83
Oct 28, 2020 10:46:39 GMT
Just setup my mig welder for ally, only hoping to tack the pipes before getting them tig welded properly by someone half decent Quick tease, these are going to be time consuming !
Oct 28, 2020 12:50:08 GMT
This is really coming on, very impressed
edk83
Nov 23, 2020 10:15:18 GMT
So in order to fit a 3 inch exhaust through the tunnel the mgzr gear linkage will have to go, I didn't like it anyway. Plan a is to use cables routed around the passenger set and an aftermarket Honda shifter.
edk83
Slow progress but progress still. Intercooler pipes are done and actually fit Top coolant pipe and sensor rail, turbo is also now mounted. I'll be monitoring coolant pressure as well as temp, also added a bleed port Next jobs make some turbo coolant / oil lines, downpipe will fit but be tricky to make Also sending this coolant outlet away to have the pipes made in ally rather than the awful plastic connectors
Man this is such a cool car progress is looking good!
edk83
Cheers Just ordered the biggest ramair filter I could find Have a bunch of oil lines to make up, exhuast to make Wiring loom Shifter cables About done haha
