Feb 13, 2015 23:00:50 GMT
Hi there, I'm running a mk2 cortina as my daily with a 2ltr 16v i4 lump in it. I'm really impressed with this engine, it goes really well..... But I'm struggling to find any info on this particular engine. Any of you lot running one? Or know a bit about em? I've not seen another old for running one which I find odd. Any info gratefully received! Thanks Clive
Feb 13, 2015 23:02:19 GMT
Feb 13, 2015 23:09:08 GMT
Cheers bud. Seen one in an old ford?
Feb 13, 2015 23:21:31 GMT
No , well yes but not running . I believe they are not that popular due to being fairly rare and then the zetec came along as well , plus the lack of tuning options readily avaliable . Good engine from what i gather , certainly nothing wrong with it , just not popular or fashionable i supppose .
Feb 13, 2015 23:42:08 GMT
Makes sense! Thanks for that mate ?
qwerty
Club RR Member Number: 52
Cortina i4 16vqwerty
@qwerty
Club Retro Rides Member 52
There's a guy on turbosport who builds a lot of them. Unfortunately can't remember his username!!! Remember there is also a 2.3 bottom end in Galaxy's and Scorpio's, which can be used with the RS2000 head and cams to give more power and torque.
I believe @sheffieldcortinacentre has put a few in a few different Cortina's and even turbo'd one.
Feb 14, 2015 10:23:24 GMT
If it's the sierra engine they are Twincam 8v not 16v, my daily sierra is the dohc i4 and they are good engines as long as they are looked after, they deliver decent mpg figures and are torquey old lumps, they are prone to hgf and low oil pressure, it's usually the pressure relief screw has unwound out of the pump so pump can be removed and the screw threadlocked and tightened back up, the oil pumps are expensive as they are only available from ford mine was £330, the headgasket problem cam be overcome by using a scorpio 16v ford mls headgasket, they also cook the starter solenoid on rhd models due to them being sat right under the exhaust downpipe.
Last Edit: Feb 14, 2015 10:37:17 GMT by fordperv
Cortina i4 16vstealthstylz
@stealthstylz
Club Retro Rides Member 174
Feb 14, 2015 11:00:38 GMT
My mate had a Mk3 Cortina with a 2.3 Scorpio bottom end/RS2000 head combo. Think it had reground cams, a bit of head work, 45s and was generally just nicely built. Was a really quick car, quicker than his BOA Cossie V6 Mk5 and handled pretty well with basic mods.
qwerty
@qwerty
Feb 14, 2015 13:49:46 GMT
My mate had a Mk3 Cortina with a 2.3 Scorpio bottom end/RS2000 head combo. Think it had reground cams, a bit of head work, 45s and was generally just nicely built. Was a really quick car, quicker than his BOA Cossie V6 Mk5 and handled pretty well with basic mods. I believe Piper do regrinds of RS2000 cams. An i4 is in contention for my Cortina as they're cheaper to get in than a Zetec.
bortaf
Feb 14, 2015 14:16:45 GMT
As said they are a good engine, i love em BUT you get stuck when trying to tune them for more power, on buysellcortina, sheffieldcortinacenter has a daily Mk3 with the 8V twincam in it has done for years, i've put a couple of carb versions in cortinas and the like in the past, they are nice to drive. I take it we are actually talking about the same engine? the sierra/granada 8V 2.0 and not the zetec 16V 2.0 ??
R.I.P photobucket
turbom
Feb 14, 2015 17:03:55 GMT
There's a guy on turbosport who builds a lot of them. Unfortunately can't remember his username!!! Remember there is also a 2.3 bottom end in Galaxy's and Scorpio's, which can be used with the RS2000 head and cams to give more power and torque. I believe @sheffieldcortinacentre has put a few in a few different Cortina's and even turbo'd one. Minority is the guy your thinking of. Also rs200016v.com is a good source of info. Any pics?
Last Edit: Feb 14, 2015 17:06:14 GMT by turbom
steamo
Feb 14, 2015 20:35:23 GMT
My dad had one these in his Morgan for a few years, started with a RS2000 lump on 45s and weber alpha ignition. Running RWD through a cossie T5. Unfortunately he hit a rather large puddle and it put a con rod through the block after ingesting large amounts of water. He then swapped it out for a galaxy block and put some cams in (can't remember which I'm afraid) after this it was pushing close to 190bhp on the rollers. Might not sound that impressive but it drove great with loads of midrange grunt. I definitely have a soft spot for that motor great alternative to the ubiquitous vauxhall redtop.
Last Edit: Feb 14, 2015 20:36:20 GMT by steamo
Feb 14, 2015 21:20:50 GMT
Put a few of these engines in old fords first one in a TC taunus on twin 40s then a couple of mk 1 capris and with modified induction an Ashley modified manifold 160 bhp 38 mpg blinding engines correct about the starters tho !
Feb 14, 2015 22:13:14 GMT
Blimey, thanks for all the info. It is the 16v and as for some pics.... I haven't got a clue how to upload them from my iPhone.... Help! Thanks all very much
gavs1
Done a rad rs2k and now I have a 2.3 with rs cams both on twin choke, my only draw back is the ignition, esc currently but gunna get a noida set up, Have a look on turbosport Theresa mk2 escort with a tuned 2.3, a cortina/tau as witha 2.3 and minirotti awesome mk6 rs
gavs1
I run an RS 2000 16v engine in my mk1 Escort. I use the standard injection with the inlet manifold cut and shut to put the throttle body at the front of the engine. The exhaust manifold is a cut and shut X flow item, 1.8 Sierra cvh flywheel and pinto clutch plate. There is on only about 4 or 5 wires to connect up to get it running. They are a good strong engine in 2.0. Even better in 2.3. 2.0 is 150 bhp for £100. Can't be bad. These engines are becoming quite popular in classics. I have a mate with one in an Anglia, another with a 2.3 in a mk2 escort, another with a 2.3 in a rwd mk3 escort and another 2.0 in a chevette.
Feb 28, 2015 21:53:58 GMT
Funny you should mention exh manifold jonesy, just broken mine today.... Looks too thin to weld an all? . Bet your mates anglia running the i4 is lively!!!
conair
Mar 17, 2015 14:37:38 GMT
Awesome lumps and really underrated, standard got good grunt, like already said tuning is harder than zetecs and the like as there is'nt as many off the shelf bits, My Mate Carl has a 2.3 hybrid in his Orion (2.0 head, 2.3 block) Is an animal but cruises so well And we're almost done with mine in my Mk3 Tina, I'm gonna run a 38 webber instead of injection
Mar 26, 2015 22:35:32 GMT
I kinda fancy losing the standard efi setup that mines running and swapping to carbs. How do you know what electrics to lose and which ones to keep? I've got 2 ecu's!
