FOAD
Jan 11, 2016 22:10:11 GMT
Why not just give up and accept the fact that you'll never escape it's charms? Reward its faithfulness and willingness to return after being shunned, and stick some new wheels on it. I'm not sure if there is much wheel choice, I think it has an odd pcd that isn't fitted to anything else. I heard transit wheels might fit but I've never found one to try it.
1981 Vauxhall Chevette 1984 Mercedes S123 230TE 1988 Peugeot 305 GR 1988 Hyundai Stellar 1992 Subaru MV BRAT 1992 Peugeot 205 D-turbo 2004 Ford Ranger retroshite.wordpress.com/
Jan 12, 2016 10:13:04 GMT
Transit wheels don't fit, I tried them once, they're really close, but not close enough. I thought about using land rover discovery steelies, and having an extra set of holes drilled into them in the Tata pcd.
FOAD
Jan 15, 2016 18:39:08 GMT
FOAD
Jan 30, 2016 20:19:17 GMT
DSC_7955 by srblythe, on Flickr The Corolla is looking a bit cleaner... DSC_7957 by srblythe, on Flickr The car repaid me by melting its alternator and blowing its radiator. New radiator and thermostat fitted and alternator refurbished but there's a fault in the wiring and the alternator isn't charging correctly. DSC_7997 by srblythe, on Flickr Took the 240 out for a spin in the snow, got stuck a couple of times on some big hills but overall did quite well... DSC_8002 by srblythe, on Flickr DSC_8006 by srblythe, on Flickr
Rola looks good with the clear lights. And I like that choice of rims! Do me a favour and paint the lips of the stars black, though? I can't wait to be driving in the snow. 5 days to go! Pity we'll be in a brand new Forester/Peoplemover thing and not an old barge.
FOAD
FOAD
Great thread. Where do you find all these old cars?
FOAD
Got an Espace too DSC_9349 by srblythe, on Flickr I think it'll be going to the for sale section shortly.
FOAD
iant
Great selection here Foad! Thanks for sharing them with us!
FOAD
Mar 20, 2016 21:52:07 GMT
Some updates DSC_9478 by srblythe, on Flickr Got a new wiper motor from French Ebay, fitted it and it works, just need some wiper arms... DSC_9499 by srblythe, on Flickr DSC_9496 by srblythe, on Flickr I love it, it's just the right amount of patina. Lada news! Build your own Lada kit... by srblythe, on Flickr Got some bits And used this DSC_9515 by srblythe, on Flickr for some of this DSC_9511 by srblythe, on Flickr Then chopped the crusty bits off DSC_9560 by srblythe, on Flickr DSC_9553 by srblythe, on Flickr DSC_9571 by srblythe, on Flickr New bits on! DSC_9655 by srblythe, on Flickr DSC_9660 by srblythe, on Flickr DSC_9667 by srblythe, on Flickr Need a bonnet and front doors and a lot more welding!
don't you normally chop the rusty bits off before you start welding bits back on? Good to see its getting some love. I see your list of cars is reasonably short at the moment. You're losing your game!
FOAD
don't you normally chop the rusty bits off before you start welding bits back on? Good to see its getting some love. I see your list of cars is reasonably short at the moment. You're losing your game! The list changes that much that I forget to update it.
FOAD
Mar 30, 2016 10:28:12 GMT
Can you get spats for those?
FOAD
Apr 16, 2016 22:34:30 GMT
FOAD
Apr 29, 2016 22:32:53 GMT
I've been patching up the Tata piece by piece, the welding looks curse word horrendous, I started of with 1.2mm thick flux cored wire then managed to acquire 1.2mm solid mig wire and finally managed to find a reel of 0.8mm wire. The Tata NotmuchBeta by srblythe, on Flickr No close ups because I am ashamed of my shoddy welding... I took the Alto out for a spin on Saturday 1983 Suzuki Alto FX by srblythe, on Flickr It's still running sweet, no mechanical issues to report but there's some lacquer peel in places and some scuffs and scrapes appearing with light rust marks. I gave these 360 glt alloys a quick clean up and paint with the aim of getting some tyres on them and fitted to the 440. DSC_0972 by srblythe, on Flickr The Ex Wilsonx2 309 didn't stay with me for long... Snow in April by srblythe, on Flickr I traded it with Derskine for the Renault 18 gtd, the deal was I got to keep the interior to fit to the phase one 309 and I got the good driveshafts but Derskine decided it would be easier/quicker to order a pair and fit them to my car than removing them from his, fitting to mine then having to source another pair for his 309... Third time lucky! by srblythe, on Flickr I'm thinking about going back to the original colour with the 18. In other news I took the 305 SR in for a test at my local place. Peugeot 305 Sr D-turbo by srblythe, on Flickr Peugeot 305 Sr D-turbo by srblythe, on Flickr Peugeot 305 Sr D-turbo by srblythe, on Flickr Reason(s) for failure Service brake: efficiency below requirements (3.7.B.7) rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b) offside rear brake recording little or no effort (3.7.B.5a) Exhaust has a major leak of exhaust gases (7.1.2) Exhaust system not adequately supported (7.1.1) Battery insecure (1.9.1) offside Front position lamp(s) not working (1.1.A.3b) offside Rear position lamp(s) not working (1.1.A.3b) nearside Registration plate lamp not working (1.1.C.1d) nearside Headlamp aim beam image kick up to the offside (1.8) Hazard warning lamps inoperative (1.4.B.1b) Hazard warning switch faulty (1.4.B.1d) Hazard warning tell tale not working correctly (1.4.B.1e) Rear fog lamp not working (1.3.2b) Main beam 'tell-tale' not working (1.7.4c) Horn not working (1.6.2a) offside front Wheel bolt(s) missing (4.2.A.1e) front Windscreen wiper does not clear the windscreen effectively both (8.2.2) Windscreen washer provides insufficient washer liquid (8.2.3) Advisory notice item(s) nearside front Brake pipe slightly corroded (3.6.B.2c) offside front Brake pipe slightly corroded (3.6.B.2c) nearside rear Brake pipe slightly corroded (3.6.B.2c) offside rear Brake pipe slightly corroded (3.6.B.2c) nearside rear Tyre worn close to the legal limit (4.1.E.1) offside rear Tyre worn close to the legal limit (4.1.E.1) offside Steering rack gaiter deteriorated (2.2.D.2d) So, a bit of a list to work through!
Last Edit: Apr 29, 2016 22:36:37 GMT by FOAD
Oooh I like those alloys. Being old pug, are they 4x100?
FOAD
May 30, 2016 19:12:52 GMT
What's been happening lately? Panhard65 kindly sent me some rockers to try on the 18, upon opening the package they looked different to the ones on the car, I think they were slightly more beefed up as they had come from a Turbo diesel. I fitted it anyway and got a new belt from Derskine. DSC_0432 by srblythe, on Flickr I had some slight issues with timing it correctly, I put the belt on with guesswork, I found the cam and pump marks easily enough but couldn't figure out which marks on the crank pulley were the correct ones to line up the new belt with. I found out there's a way to determine tdc on the crank by removing a bolt on the casing and poking something in it until it stops turning. I tried this method along with lining up the other timing mark but when trying to turn over by hand it stopped turning. For some reason I figured it was 180 degrees out but after unbolting the rockers and turning the cam it still wouldn't turn over by hand. I decided to remove the bottom pulley and noticed the timing marks were there so I lined all of the lines marked on the belt up and tried turning it over by hand. It turned freely but after one revolution of the belt none of the marks lined up so I turned it over a few more times and the marks were at a different point each time. I thought "curse word it" and connected a battery to see what would happen when trying to start it. I spent a bit more time on the 18, I got a new v-belt from my local motor factors, it didn't fit so I took it back and got a longer one which was a better fit. To fit the belt the alternator needed unbolted but when unbolted there's not a whole lot of movement available so getting a belt to fit was always going to be a fluke. After fitting the belt, I fitted the radiator and bled the cooling system. The rear drums were seized so I removed the rear wheel to hit the drum with a hammer and it freed off, I took the wheel inside to put air in the tyre but the valve was letting air back out. I broke the bead only to find an inner tube inside so grabbed some Renault Espace wheels and fitted some tyres I had lying around... DSC_0457 by srblythe, on Flickr DSC_0459-1 by srblythe, on Flickr
