Thanks Nick, you're a star. I have done lots of internet reasearch for this EFI project and I have to say, you pop up everywhere! How many forums are you on? How do you get time to keep on top of giving everybody else the benefit of your knowledge and at the same time get your projects done? I for one am very grateful for your help.
You are right about the loom it turned out to be a very long and drawn out process, but if I had made it off the car I would never have got it right.
The last post is a bit misleading as I was finished in the loom in early May so have already started on the Speeduino install.
I must admit I cheated, at least I feel like I cheated. I had aims to build my own Speeduino board but I had to give my head a wobble and realise that I didn't have the time and just wasn't confident enough in my own soldering skills. For the extra 60 quid I bought an assembled UA4C SeaWolf with VR conditioner. (I see that there is now an updated version called SeaFox too)
I mounted a 36-1 wheel a year or so ago and started collecting other parts I needed at the same time. The coil is from a VR6 Corrado and the crank sensor is a Ford item. I spalshed out on an LD Performance wideband kit too.
Funny you should say that the Speeduino range is too complicated for you (which I don't believe for a second) as that is the reason I didn't go MS, there is almost too much documentation if that is possible, I thought I would never be able to sift through all of it to find out what I needed. MS was just too overwhelming.
I take your point about the Speeduino documentation though, the 'updated' wiki now has less information than before. Overall though I've found it to be OK and the Facebook page and forum are good sources of info.
The only thing I hate about it are the two molex mini jr. connectors, those fiddly little pins, I have tried several crimping tools and they all either mash the pin or crimp it so that it's too fat to go into the connector. This has caused me several false starts due to wiring problems. I'm going to see if I can swap them out for something else. I'm not short on space for the ECU so i don't mind a couple of oversized connectors.
Otherwise I haven't encountered any noise problems, what symptoms are you seeing due to this?
I got the car fired up on the Speeduino a couple of days ago but haven't had much chance to drive it since, the first test run was pretty underwhelming I have to say, It felt better on coil points and distributor but this is only a generic base map so to be expected i assume.
I have made a new table based on yours and will try to get this uploaded to the Speeduino over the weekend. How does this look for a start?
otherwise i'm happy with the tooth logger, as far as I understand it it looks correct anyway?
Not so sure about the composite graph though, what am I seeing here? I do realise that the red line is where the cam sensor info should be, i'm was just worried that the crank sensor graph looks a bit odd.
Any tips about the things I'm f@%*ing up are more than welcome.
