Phil H
Club RR Member Number: 133
1929 model A 300tdi Phil H
@philhoward
Club Retro Rides Member 133
Isuzu 1.7 goes with a Carlton or Omega gearbox, both being GM and all.
Wasn’t someone on here virtually giving a Ford 1.8TD and type 9 recently? That might be reflective of it’s worth though...
What about a V6 Tdi/hdi from a ford/jag/pug? Shorter than a 4cyl, with more oomph 😀
v8jim
Apr 23, 2019 11:09:42 GMT
Plenty of options but I don’t want it a big project right now as I’m still building the Ital van
There are so many things I want to change it really needs to come off the road for a year so as much as I don’t want to refit things that I’m not happy with the sensible option is to fix it and keep it the way it is while I plan a rebuild and collect the parts
There is definitely an engine swap in its future though
That’s all very sensible and boring isn’t it
Max sig pic size: 80px
1929 model A 300tdi glenanderson
@glenanderson
Club Retro Rides Member 64
Apr 23, 2019 18:43:04 GMT
Sounds like the best plan is to throw it back together, minimal effort/expense style, and keep it running while you get the van drivable. Once that’s done, you can look at your options for the Model A. Gives you plenty of time to do your research as to viable engine/gearbox options, and time to pick stuff up cheap rather than having to pay through the nose because you need it right now.
Have you determined what the fault is yet?
Apr 23, 2019 18:48:44 GMT
whatever lump is under the front it will remain just about THE coolest truck on the road... unless it goes 'lectric that is!!
v8jim
Apr 23, 2019 19:57:34 GMT
Sounds like the best plan is to throw it back together, minimal effort/expense style, and keep it running while you get the van drivable. Once that’s done, you can look at your options for the Model A. Gives you plenty of time to do your research as to viable engine/gearbox options, and time to pick stuff up cheap rather than having to pay through the nose because you need it right now. Have you determined what the fault is yet? Because it’s a mixture for parts that aren’t designed to fit together, 200tdi bellhousing, LDV input shaft, 300tdi release bearing (I think) and the sleeve the bearing fits over isn’t quite long enough so it partly came off and jammed up I can buy an extra short bellhousing and input shaft to match the sleeve but that’s £300, in my pile of bits I’ve found another sleeve the correct diameter so I’m going to weld an extra piece on the end to lengthen it. Sounds a bit dodgy and if it was thin I’d have my doubts about it but the sleeve is about 4mm think so I can crank the amps up and get a nice strong bead in it
v8jim
Apr 23, 2019 19:58:53 GMT
Apr 23, 2019 20:06:29 GMT
c'mon....if the truck spends any more time with its bonnet in the air it will start thinking its a land rover!!;-)
Apr 23, 2019 22:51:19 GMT
Just read this from start to finish.
This truck makes me happy. Thank you Jim.
merryck
Club RR Member Number: 9
1929 model A 300tdi merryck
@merryck
Club Retro Rides Member 9
Apr 24, 2019 13:49:12 GMT
Not sure if it's of any help but I've got an LT77 and longer bellhousing from a 200tdi Discovery in Hythe that you'd be welcome to.
v8jim
Apr 24, 2019 16:48:15 GMT
Not sure if it's of any help but I've got an LT77 and longer bellhousing from a 200tdi Discovery in Hythe that you'd be welcome to. Thanks for the offer but my bellhousing is too long already
merryck
@merryck
my bellhousing is too long already Oh my...
Apr 25, 2019 15:55:40 GMT
If you use the LT77 from a defender, it will be the same length as the short R380 box. An LT77S will be of similar strength as well. You will need the bell housing on the engine off a 200 TDI or TD though. Also, the suggestion of using the series 3 clutch fork I have done in the past, however, the geometry is not quite right, and the pushrod will sit at an acute angle in the slave cylinder, and will eat cylinders at an alarming rate. So now I went back to the pressed fork with a welded reinforcement.
Daan
v8jim
May 11, 2019 16:26:20 GMT
v8jim
May 11, 2019 16:52:15 GMT
It only bloody works!!!
May 11, 2019 17:23:15 GMT
Well done Jim , once again the coolest car on the block.
May 11, 2019 17:45:10 GMT
block?? western hemisphere.. possibly.
JoshO
May 12, 2019 13:39:25 GMT
This thing is flippin brilliant! Will you be attending either the Weekender or RRG?
May 12, 2019 14:12:21 GMT
That's so sodding cool mate! Well done with the build
v8jim
May 12, 2019 17:23:00 GMT
This thing is flippin brilliant! Will you be attending either the Weekender or RRG? Not this year sadly
