qwerty
Club RR Member Number: 52
Help me please!!qwerty
@qwerty
Club Retro Rides Member 52
May 15, 2007 16:56:34 GMT
Well my car(mk3 1 litre polo) broke down yesterday (wouldn't start waited for 45 mins for the AA to come at which point it started and ran fine for the rest of the day and then today). Whilst we were waiting for the AA to arrive we were noticing how curse word the rotor arm/ dizzy cap/ leads etc were. So today I went along to Eurocarparts and got a Ner rotor arm/cap/set of plugs and leads. I've come home and fitted all of the above and now my car won't start.
Not only that but it keeps making a big POP out of the TB enough to lift the air box top which I placed on.
PLEASE PLEASE HELP. What could be the problem?? I desperately need the car for work as i work 20 miles away and have no other form of transport. Please please helP!!
Help me please!!Deleted
@Deleted
May 15, 2007 17:00:54 GMT
Does it have points? As that is the only thing you have not replaced! Are the plug leads in the right order? Easy to connect them up wrong.
Could be the coil too I guess
Last Edit: May 15, 2007 17:01:37 GMT by Deleted
Dez
Club RR Member Number: 34
Help me please!!Dez
@dez
Club Retro Rides Member 34
May 15, 2007 17:00:57 GMT
leads wrong way round. youve probably 2+3 or 3+4 confused.
qwerty
@qwerty
May 15, 2007 17:01:54 GMT
Yeah they all seem to be in the right order I'll go and check now
May 15, 2007 17:02:28 GMT
what he said^^^^ also, have you gapped the points up correctly?
qwerty
@qwerty
May 15, 2007 17:06:59 GMT
Doesn't have points I don't think. Which is number 1 on the Dizzy cap? Thats assuming no 1 spark plug is the one nearest the timing belt (left hand side with the bonnet up. I took each lead of by itself to make sure I didn't confuse them looks like I might have
qwerty
@qwerty
May 15, 2007 17:15:07 GMT
Firing order is correct 1243
May 15, 2007 17:15:44 GMT
you might have got the leads right but did you put the cap on the right way round? easy done is the rotor arm on the spindle right?
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
paul4be
'86 Capri Laser, Frontera 4x4
May 15, 2007 17:17:27 GMT
Sounds like dizzy timing out due to leads in wrong order as above, unless you messed with the dizzy itself and screwed up the timing?
qwerty
@qwerty
May 15, 2007 17:22:49 GMT
I haven't touched the dizzy just the cap when i put the cap on the other way then it doesn't do the popping thing but it still doesn't start.
qwerty
@qwerty
May 15, 2007 17:34:31 GMT
hecked firing order. Put dizzy cap right way checked firing order again, tried old dizzy cap still nothing. It churns and then goes POP and shoots vapour/smoke out of the TB
May 15, 2007 18:28:45 GMT
Firing order is correct 1243 I could be wrong but is the firing order not 1-3-4-2 thats fairly common for 4 cylinder cars
May 15, 2007 18:33:49 GMT
Yep according to autodata its 1342, 1 being furthest away from the gearbox and dizzy turns anti clockwise and I don't know if its any use but it shows no1 as being lower left on the dizzy cap.
qwerty
@qwerty
May 15, 2007 19:13:20 GMT
Hmmm well I'll go and check that now. I've just done it according to my bro's identical (but working) polo 1.0
qwerty
@qwerty
May 15, 2007 20:06:16 GMT
Yep according to autodata its 1342, 1 being furthest away from the gearbox and dizzy turns anti clockwise and I don't know if its any use but it shows no1 as being lower left on the dizzy cap. Yup mr Phoenix you would be right and I would be completely wrong and would feel quite foolish ;D Hey ho it works now!!
May 15, 2007 20:40:20 GMT
Yep according to autodata its 1342, 1 being furthest away from the gearbox and dizzy turns anti clockwise and I don't know if its any use but it shows no1 as being lower left on the dizzy cap. Yup mr Phoenix you would be right and I would be completely wrong and would feel quite foolish ;D Hey ho it works now!! Lol nice one. Have you got a thread in readers rides fot this 1.0 beastie then
qwerty
@qwerty
Yup mr Phoenix you would be right and I would be completely wrong and would feel quite foolish ;D Hey ho it works now!! Lol nice one. Have you got a thread in readers rides fot this 1.0 beastie then No cos I can't get pictures off my phone and onto the computer at the moment, however I will get some up soon. The other thing is its sitting sky high at the moment until next month when i'm ordering my suspension. Safe to say its not standard anymore
