anden
Go low or go home
Aug 25, 2014 20:16:06 GMT
Had this one a couple of months now, shouldve started a build thread but never got round to it!! 1966 Volvo 121 Amazon B18 engine and single stromberg carb Had problems with leaky tank (now fixed) Dodgy welded on rear hub! (now fixed) carb and fuel pump full of crud (rebuilt) plastic fuel line loosely run under car ( replaced with new copper line). Issues with wiring,(fixed) speedo not working (fitted cable) key was also snapped in ignition ( fixed and sourced new keys) I Resolved all the above and moved onto creating the slamazon! Created an adjustable panhard rod from a landy one. Chopped 90mm out of it and tweaked both ends to fit. Set of very short springs and adjustable short gaz shocks all round. flipped lower balljoint mounts. Banded Steels bought and repainted 16 x 8.5 and 16 x 9.5 from a nissan xtrail/primera. 30mm hubcentric spacers on front, 3mm spacers on rear. no real plans to do much more, needs a little bit or welding here and there over time but nothing major.
bgt
Aug 25, 2014 20:31:53 GMT
Looks wonderful! I'm not usually that fond of the banded steels look, but it looks so right on this! Perfect height too.
The best colour for one of these too. Well done!
Now that is superb...
***GARAGE CURRENTLY EMPTY***
Clement
ambitious but rubbish
I wouldn't change a thing, that's just perfect. Congrats!
tdk
Fantastic! Love the colour too. What's it like to drive?
Aug 26, 2014 12:40:07 GMT
Perfect
Aug 26, 2014 12:44:42 GMT
very nice.
Aug 26, 2014 13:00:56 GMT
so many reasons to say yes to this, 'just' needs a V8 now
Honda Concerto driver
carltonx
yardie in brum
Aug 26, 2014 15:37:08 GMT
if i had one it would sit just like that
Last Edit: Aug 26, 2014 15:39:07 GMT by carltonx
Potentially offensive comment deleted. You are welcome to remove this text, but not replace it with more bigotry. If the need to express that opinion is particularly important, please let me know and I'll delete your account for you. Maximum signature image height: 80 pixels.
anden
Go low or go home
Aug 26, 2014 15:51:25 GMT
thanks guys, i havent really driven it enough yet to really comment on how it drives, handles etc, my view is also skewed a bit by everything i own being a) low and b)old. The test drive around the block seemed reasonable, its not as hard as the substandard but its still reasonably bumpy! its needs a bit of a tune after rebuilding the carb and I'm not convinced the valve clearances are right so should probably check them asap too. This one wont be getting a v8 in my ownership. All mods have been kept reversible, this was purchased and funded using house saving money that wasnt making much sat in the bank, come time to buy a house it will have to go, in order to maximise return ive had to be strict and only modify using bolt on parts and retain all the old bits. Its probably worth more in original condition than modified. This was mega hard and I'm sure some of you familiar with my other project will understand this isnt the way i usually do things! It was supposed to be a summer daily but its taken longer than i hoped to get it this far, should get a couple of months out of it before winter sets in and its garage away time! Heres how bad she had been bodged...... http://instagram.com/p/q7nNVnF83E saving this halfshaft took forever!
Last Edit: Aug 26, 2014 15:57:10 GMT by anden
orangecords
yawner extraordinaire
Aug 26, 2014 17:24:51 GMT
Pass the tissues...
I then wanted to start cleaning the interior as it stinks of wood (the material not the smell of a boner) best quote ever!
Aug 26, 2014 17:28:41 GMT
Digging it, just for the thread name
Sophers
Club RR Member Number: 80
1966 volvo SlamazonSophers
@sophers
Club Retro Rides Member 80
Aug 26, 2014 18:19:16 GMT
What a beaut! I seriously need to get my 164 on the road.
elfman
Aug 26, 2014 19:55:05 GMT
Fantastic car, been thinkg of one of these myself in the near future...love the slamed look and the wheels are perfect...class act.
sowen
Club RR Member Number: 24
1966 volvo Slamazonsowen
@sowen
Club Retro Rides Member 24
Aug 26, 2014 21:10:44 GMT
Inspired choice of wheels, well done! That halfshaft, never heard or seen anything like it before
anden
Go low or go home
its nasty isnt it! i drove it over 100miles like that too.
Also had a total of 6 wheel nuts missing too.. hubcaps hide too many sins, defiantly removing them on any future purchases of classics i made prior to driving!
79cord
Spectacular! You really must take some photos of it with the Standard, such similar shapes & treatments in different scales.
anden
Go low or go home
Aug 27, 2014 11:02:12 GMT
i hid the standard for a while so i wouldnt be able to break it before RR and so i could focus on other projects. My partner has a 64 beetle as well. As of last night all three are all in pretty much one piece all parked next to each other on the drive looking mean! ill take a pic later if i can with some strategic parking of the daily hacks out of shot!
