I understand, seeing as i passed by driving test in 1996, i can ride a moped up to 30mph without L plates or taking a CBT
Is that my limit? It seems quite dangerous to be limited to 30mph on A roads
I worked for Pizza Hut in 2002 and we did some kind of driver instruction on the 'peds. Could this be a CBT? Would it make any difference to what i can do now?
I'm thinking of having one on hand for those days you want to save fuel / have a broken car / heavy traffic etc
ferny
Club RR Member Number: 13
What does your driving license say you can drive? All the info will be on there.
What does it say on yours?
It makes no mention of it on mine
doobie
i have AM,p and q which seems to cover all the mopeds... i also have A 79(tri) so i can ride a trike with more than 15kw but not ones with less... .. apparently.
Er, cool. What country are you in?
doobie
Er England.....
Great, none of that is on my licence
When did you pass your test?
doobie
May be a picture would help ....
Have you taken any additional tests? Mine shows:
Ah, i think i am stuck with the 30mph (without taking further lessons / tests)
Just seems so silly if you're allowed on A roads but can't drive quick enough to stay out of trouble
randywanger_
Nissan Bluebird P510 SSS Coupe
Ah, i think i am stuck with the 30mph (without taking further lessons / tests) Just seems so silly if you're allowed on A roads but can't drive quick enough to stay out of trouble You'll have to re take your CBT as it only lasts 2 years, then with a full car licence and CBT you can ride a 125 restricted to 33bhp I think it is, you use to be able to buy anything and restrict it, but I believe that's now changed.
Have you taken any additional tests? I see you took your bike test in 2013 That will be why you have the extra allowances.
doobie
You could always get yourself a road legal quad bike....
doobie
Have you taken any additional tests? I see you took your bike test in 2013 That will be why you have the extra allowances. If that was at me no only ever taken a car test... but was in 79...got my new licence in 2013 though...
Aug 10, 2014 10:01:48 GMT
You've got category A on your licence
Have you never taken a bike test?
doobie
Aug 10, 2014 10:04:23 GMT
Nope look at the bit on the end 79(tri) is the qualification... so i can ride a trike ...it seems
Last Edit: Aug 10, 2014 10:05:30 GMT by doobie
Aug 10, 2014 10:06:42 GMT
Category A allows you to ride 'motorbikes with a power output more than 35kW or a power to weight ratio more than 0.2kW/kg'
Seems like a full licence to me
doobie
Aug 10, 2014 10:21:59 GMT
Done a bit of digging and it seems they changed a trike's status from a car to a bike so that is why i have the A class with the proviso 79(tri) as a trike was considered a car when i passed my test and they cannot remove a licence from you once you have it..
Aug 10, 2014 10:27:08 GMT
Ok, it suggests you can also ride a motorbike
But that is not what i have so..
It is unlikely i will go ahead as i don't want to be taken by vehicles going 60+
