Thought I’d show you all my MK2 Fiesta
Spec;
2.0 Blacktop
1800 Ported / polished head
Megajolt
ZX6R Carbs
DanST alloy inlet
Ashley Manifold
XR ‘Challenge’ Exhaust system
XR2 Brake callipers, green stuff pads, Rally Design Vented discs
XR pots wrapped in Yokohama 175/50
Koni dampers, Rally Design 450lbs Springs -120mm
Stripped, SD cage, Sparco 4 point Harnesses, Corbeau buckets, OMP Deep dish suede wheel, Battey re located to boot
[/url
I've pretty much left the exterior as Ford intended, apart for the MK1 Golf GL splitter, raised bonnet and single wiper.
It will be off the road for winter to address afew niggles but all in all its going well.
Spec;
2.0 Blacktop
Megajolt
ZX6R Carbs
DanST alloy inlet
Ashley Manifold
[/url
