Ryannn
May 23, 2014 17:29:42 GMT
I've got a hire car at the moment whilst my Audi is undergoing an insurance inspection. They've given my a Merc C Class, the boot opens fully from a button and it's something that I'd like to replicate on my car when I get it back. Would it be easy to do? Do you think I could just attach a spring somewhere or is it far more complicated? Like this Thankssss
Porsche
West Midlands
Kev from B'ham.
May 23, 2014 20:13:08 GMT
What are you trying to replicate? Does your Audi already unlock with a key fob remote and you just want the boot to open with it or do you want your key opening boot to unlock and pop open with a key fob remote?
May 23, 2014 20:54:01 GMT
I have a strong gas strut on the boot of my Nova, I rigged a solenoid to pop the boot on the alarm fob and so it opens at the push of a button.
You still have to close it normally though!
Vauxhall Nova Estate Vauxhall Carlton V8
Ryannn
May 23, 2014 21:54:17 GMT
What are you trying to replicate? Does your Audi already unlock with a key fob remote and you just want the boot to open with it or do you want your key opening boot to unlock and pop open with a key fob remote? I know how to get the boot to unlock from the fob, I'm trying to make it physically open up by itself.
adam73bgt
Club RR Member Number: 58
Automatic Boot Lidadam73bgt
@adam73bgt
Club Retro Rides Member 58
May 23, 2014 21:58:08 GMT
A mates Lexus IS200 has a sort of torsion beam spring thing to open the boot automatically once its popped, had to change it though cos it had lost its springiness
Automatic Boot Lidfr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
May 23, 2014 22:26:02 GMT
The same as what Johnny A said - my smart roadster had the same - it's just a latch on a remote solenoid with a hydraulic strut (must be a certain kind but don't know name - pressurised so that when the latch moves it auto-stretches)
93fxdl
Enter your message here...
May 23, 2014 22:33:48 GMT
Some KIA Sedona and Chrysler voyager have power tailgates, push button on remote and it opens or closes, perhaps they could be a parts source. If you just want opening how about some strong rams ? Perhaps these people can help www.sgs-engineering.com/gas-strutsTtfn Glenn
Just get a bonnet strut fitted so once the alarm latches it open the strut lifts it automatically
Autoloc sell a power boot/bonnet opener, would have to ship it from the US but it's worth it as their products are good.
Ryannn
Just get a bonnet strut fitted so once the alarm latches it open the strut lifts it automatically I'm not sure if a gas strut would work though, you have to start opening your bonnet by hand before it'll raise up on its own, or at least I usually do!
ChrisT
Club RR Member Number: 225
Automatic Boot LidChrisT
@christ
Club Retro Rides Member 225
I used to have a couple of tailgate struts (of unknown origin) on the boot and a solenoid to operate the lock but the rear of the boot didn't sit properly with the force of the strut acting on it so had a look through Ebay for some boot hinges with integrated struts. Found some from a Volvo S40 and with a bit of adaption bot them to fit..... retrorides.proboards.com/thread/46953/1985-opel-manta-winter-jobs?page=11
May 24, 2014 18:40:55 GMT
if you want it to open and close get some convertible hood rams and the control units and adapt them, I'm sure mk4 astra convertibles had a remote operated hood so maybe find some one braking one of these and get the hood ecu, wiring rams ect and have a play.
May 24, 2014 21:24:17 GMT
I spend all day developing this sort of thing at work so have spent alot of time on this recently! Basically if you want to do it with gas struts you need to increase the strut force and potentially change the ball stud geometry as many systems go over center just before closing to allow you to drop the boot lid closed and not have to push it all the way down. If you do it will make the boot a bit harder to close (not over the top though) and you will have to push it all the way closed. It will also be affected by temperature as the gas strut force is reduced in low temps (and increased in high temps) but if you got it working at ambient it would probably be ok 90% of the time. Another method would be to introduce a secondary spring to pop the bootlid past the over center position afterwhich it will then self open.
The alternative is to fit some sort of electric linear actuation strut but this might be quite a costly option and the control system might get quite complicated!
May 24, 2014 21:44:04 GMT
Failrly sure there is a thread on one of the big vw forums about this.
They found that certain cars has a soribg loaded stop rubber on them. By fitting these when the boot was closed they compressed, open the boot and they have the struts just enough of a healing hand to soribg the boot right open
Ryannn
I used to have a couple of tailgate struts (of unknown origin) on the boot and a solenoid to operate the lock but the rear of the boot didn't sit properly with the force of the strut acting on it so had a look through Ebay for some boot hinges with integrated struts. Found some from a Volvo S40 and with a bit of adaption bot them to fit..... retrorides.proboards.com/thread/46953/1985-opel-manta-winter-jobs?page=11That looks perfect, just what I'm after!
ChrisT
@christ
May 25, 2014 10:24:40 GMT
The only problem I have with them is that in the upright position the edge of the boot lid is forward of the bodywork so if it's been raining any water runs off it into the boot. On my 200SX I've used hinges from an MGF - they've got an integrated spring...... www.mgfcar.de/boot_lid/hinge_cp_2683.jpgAfter a lot of trial and error I ended up just using the spring part on the original hinges img.photobucket.com/albums/v326/mantachris/SP_A0152.jpgDon't know how heavy your boot lid is, these are only just strong enough to prevent the boot dropping
Jun 13, 2014 15:04:22 GMT
I have always lusted (similar to upmarket vehicles e.g. S Class) after not only an opening, but also a CLOSING option. In stead of complicated hydraulic and/or vacuum systems, what about something simpler. Opening is straight forward - solenoid with simple spring arrangement to lift when activated - hinge integrated as suggested. Closing: Perhaps an electrical motor (maybe door glass lifter ex junk yard - guess it must be heavy duty) connected to one or both of the hinges (linked), either by an arm application or gear driven. Cut off switch integrated/add on to closing latch. My electronic knowledge not sufficient to link this to a remote. Still considering whether there is a benefit in duplicating the function(s) to dash switches.
1986 Mercedes 200 (W124) (Standard and daily) 1976 Peugeot 404 1800 Stickshift (Standard - awaiting complete resto, engine done) 1984 Ford Cortina (P100) LDV - Cab and chassis restored, interior and glass not fitted, brand new 3 liter engine (last 110kw Sierra XR6 engine fitted and married to 5 speed Toyota Gearbox), load body needed.
