120y
May 18, 2014 15:20:55 GMT
Could I use the old pressed metal numbers plates on a 94 M redg car or better still am I allowed to use the old style with metal back and individual letters. Ive never got my head round the legal side can somebody explain it to me, sorry if its been covered before. Thanks
1996 Renault Clio MK1 1.4 RT Auto
May 18, 2014 15:29:23 GMT
No you can't use the black and white ones.(legally)
As for the pressed type , you can get ones that meet all bs requirements with regards to legal font, spacing and reflection with the correct bs marks.
Though some people do still get stopped with these on
starionturbo
Is planning mental turbo action MU HUH HUH!!!
May 18, 2014 15:30:11 GMT
You can't use black number plates, they are for pre 73 cars (i think) Fpr a 94 you must have white front, yellow rear and they must be reflective so you could get pressed ones as long as they adhere to those rules. Don't forget the font has to be correct and the right size to.
1900sr
I like Mantas me!
May 18, 2014 21:11:22 GMT
The only replacement number plates you can legally fit to any post 73 car are the current font ones as fitted to new cars, which is ridiculous. My Manta has the aluminium reflective plates with rivetted plastic letters. If I ever damage one I can't legally replace it with a period correct one.
May 18, 2014 23:15:40 GMT
No you can't use the black and white ones.(legally) I don't think the op thought you could I believe the reflective pressed ones are ok
Copey
Had reflective coloured pressed plates on my 1990 Saph for a while, never been pulled with them and they went straight through an MOT with no mention
Number plates legalitiesChasR
@chasr
Club Retro Rides Member 170
The only replacement number plates you can legally fit to any post 73 car are the current font ones as fitted to new cars, which is ridiculous. My Manta has the aluminium reflective plates with rivetted plastic letters. If I ever damage one I can't legally replace it with a period correct one. You could always not mention it . My Stag has a pair of age related styled plates fitted.
kabman
The only replacement number plates you can legally fit to any post 73 car are the current font ones as fitted to new cars, which is ridiculous. My Manta has the aluminium reflective plates with rivetted plastic letters. If I ever damage one I can't legally replace it with a period correct one. It only applies to cars built after Sept 2001 (those with a two letter prefix). You can use whatever plates were required at the time your car was new. You might have to search to find them though. The rules are vague to say the least. They refer to 'new plates fitted before 2001'. How can plates be 'new' if they were fitted more than 13 years ago?
Last Edit: May 19, 2014 7:44:40 GMT by kabman
jonw
Can open a Mouse with a File
May 19, 2014 12:29:23 GMT
You can use pressed steel, but they must be a legible sans serif font (there is no specific font until 2001), of the correct size and correctly spaces. They must be black letters with either white or yellow reflective backgrounds.
Had these on my '92 mini and passed MoT and never got stopped.
Black plates are for pre 72 only.
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
v8ian
May 19, 2014 13:54:50 GMT
Not saying too much, I have just cast a new rear alloy numberplate for my Austin, going to be "aged" before I attempt to fit it,
May 19, 2014 14:51:21 GMT
wonder how long I will get away with a backlit numberplate for my Herald (once I've finished it). it'll be on a pre 1973 car, so black and white is fine and current MOT regs say backlit plates are ok, but I don't think you can make your own number plates legally, but are stick on number plates still legal for age related cars (which this plate is)
1900sr
I like Mantas me!
May 19, 2014 17:54:30 GMT
The only replacement number plates you can legally fit to any post 73 car are the current font ones as fitted to new cars, which is ridiculous. My Manta has the aluminium reflective plates with rivetted plastic letters. If I ever damage one I can't legally replace it with a period correct one. It only applies to cars built after Sept 2001 (those with a two letter prefix). You can use whatever plates were required at the time your car was new. You might have to search to find them though. The rules are vague to say the least. They refer to 'new plates fitted before 2001'. How can plates be 'new' if they were fitted more than 13 years ago? This is from the document linked to earlier on "For vehicles with new or replacement number plates fitted from 1 September 2001, “3-line” number plates are no longer permitted (except where the vehicle was first registered before 1 January 1973). In addition, the characters on number plates purchased from 1 September 2001, will need to meet the following specifications. n Character height 79mm n Character width (except the figure 1 or letter I) 50mm n Character stroke 14mm n Space between characters 11m" So as I said, LEGALLY you cant fit anything other than current font replacement plates to any 1973 onwards car. Obviously plates fitted to the car before 1 September 2001 only have to meet the then current British Standard (BSAU145a in the case of my 73 Manta)
Last Edit: May 19, 2014 17:55:02 GMT by 1900sr
1900sr
I like Mantas me!
May 19, 2014 18:01:25 GMT
The only replacement number plates you can legally fit to any post 73 car are the current font ones as fitted to new cars, which is ridiculous. My Manta has the aluminium reflective plates with rivetted plastic letters. If I ever damage one I can't legally replace it with a period correct one. You could always not mention it . My Stag has a pair of age related styled plates fitted. The OP was asking about legalities, there are ways around it but it's not strictly legal. Proving when they were bought and fitted would be difficult for the authorities, so as long as the plates are period correct in every way, including the correct BS numbers you'd probably be OK.
ferny
Club RR Member Number: 13
Number plates legalitiesferny
@ferny
Club Retro Rides Member 13
wonder how long I will get away with a backlit numberplate for my Herald (once I've finished it). it'll be on a pre 1973 car, so black and white is fine and current MOT regs say backlit plates are ok, but I don't think you can make your own number plates legally, but are stick on number plates still legal for age related cars (which this plate is) That looks lovely! How did you make it? Don't think you'll have many problems with it. I ran the Herald with no front plate for a couple of years and never got a pull. It currently has one this small and again, no tugs. img.photobucket.com/albums/v153/ferny/Sally/20140218_140803_zps886f34ba.jpgCould be because they don't think their pencil will last long enough to list all the "issues" on the car though.
So as my car is 1982, can I legally have reflective pressed plates in the German style font?
wonder how long I will get away with a backlit numberplate for my Herald (once I've finished it). it'll be on a pre 1973 car, so black and white is fine and current MOT regs say backlit plates are ok, but I don't think you can make your own number plates legally, but are stick on number plates still legal for age related cars (which this plate is) That looks lovely! How did you make it? Don't think you'll have many problems with it. I ran the Herald with no front plate for a couple of years and never got a pull. It currently has one this small and again, no tugs. img.photobucket.com/albums/v153/ferny/Sally/20140218_140803_zps886f34ba.jpgCould be because they don't think their pencil will last long enough to list all the "issues" on the car though. sorry for the thread hijack..... ohh I'll my herald wont be rocking over riders when its finished either , the lettering on the number plate is a stick on plate from ebay with the letters cut out, thats stuck onto some 3mm white perspex and then cut back to the size of a number plate. the base is bent from aluminium and led strip lights stuck arround the inside,the plate is then stuck the the aluminium base with silicone sealer. the base ended up being 22mm thick to give an even distribution of light. I also used an external resistor (68 ohms) to reduce the light so it doesnt glow like a taxi sign. the boot lid has been smoothed and then a numberplate recess was welded into it
Copey
May 20, 2014 10:08:14 GMT
Those backlit plates are fantastic! Good job man!
May 20, 2014 10:19:31 GMT
So as my car is 1982, can I legally have reflective pressed plates in the German style font? Only if you live in Germany... otherwise it has to be the UK style (legally)
May 20, 2014 19:30:10 GMT
Slightly off topic but how about square plates on the rear or front like old FIAT have?
