jomfun
I had a later shape ulysse a while ago. The wheels are pretty wide on these so I painted just the rim on these to give a faux banded steely look. Think yours would look good dayglow blue or green. Or some 5x98 alfa alloys will fit. Sorting the wheels and a hefty lowering will make a big difference
I think lowering and stiffening is probably best along with a chip or remap Plumes of soot and speed is the best you can hope for, maybe? Although there was this 806 at Spa
The ride height of the 806 is what I'm after, only thing is off the shelf springs only offer max of 40mm, not sure on cut springs route, is there coil overs that would fit. The colour i was thinking of was Fiat 500 volare blue, pop outs and mild tints on the rear windows lose the sliding windows. Then may be change the front and interior for 806, Ulysse etc thats the plan for the summer anyway.
May 13, 2014 21:07:00 GMT
I've got a set of 14" revolution RFX wheels with 5x98pcd, which is correct for you.........if you fancied the lower small wheel euro approach. PM me if interested.
71 Alfa GT 1300 Junior 89 Alfa 75 3.0 V6 Veloce 89 Alfa 75 3.0 V6 America 2015 C220 estate Daily shunter
May 14, 2014 11:34:24 GMT
^^ i think it would struggle with those. I tried to fit 14" scudo wheels to one like above and they wouldn't go over the brakes
qwerty
Club RR Member Number: 52
fiat scudo ideas pleaseqwerty
@qwerty
Club Retro Rides Member 52
May 14, 2014 20:32:15 GMT
Scudos are 5 stud. 5x108 I believe.
Slam and wheels, job done.
