V-reg Peugeot 106 Diesel for sale
Great little runner, would be perfect for a learner/new driver or someone who needs a super budget eco car.
This little car does on a combined cycle (mixture of city (stop/start), country and A-road driving) 58-62mpg depending on the time of year. It will go up to 70mpg on a motorway run!
Good points:
Very very reliable mechanical diesel engine (no electrics to fail and cost you money) that doesn't use any oil or coolant... at all!!!
Cheap to run
Cheap to insure (my last renewal was £302 with NO NCB!)
Cheap to tax (lower tax bracket - £125ish for the year)
New clutch 20K ago (genuine Peugeot part)
New windscreen 20K ago
New radiator 10K ago (coolant changed at the same time)
New passenger side driveshaft 1K ago
New handbrake cables 1K ago
New front tyres 2K ago (rear tyres still have a lot of life left in them)
Serviced using genuine Peugeot filters (oil, air, fuel) 1K ago and fresh oil (5w40 fully synthetic)
Comes with Tax and MOT till the end of October
Upgraded Kenwood front speakers with a Sony CD player head unit, sounds a lot better than the original speakers.
Bad points:
Both doors have lots of dents (I bought it like this), it's only cosmetic and both doors and window winders work perfectly. Subsequently one of the door trims is missing because of this.
Has had some paint touch-ups with green paint that doesn't colour match very well.
Dent in boot panel
Small plastic chip on the instrument panel in the corner, doesn't effect the readouts at all.
Glow plugs on the engine are a bit tired - in cold weather it will cough when started from cold for a few seconds then clear and run perfectly. This has never really bothered me but it's not an expensive job if you wanted to fix it.
That's it! So if you're after a cheap reliable little workhorse here you are, the only reason I am selling is because I needed something with more load space so I bought an Astra estate.
Viewing is recommended, due to work commitments this means in the weekday evenings or at certain times during the weekend. Email me to make arrangements, the car is in Oxford.
£400
Good points:
Cheap to run
Bad points:
Dent in boot panel
£400
