grumpy
Apr 11, 2014 18:09:11 GMT
Does anyone know if there is a way to find out if a car is tax exempt - its manufacture date ? Can you get this from the dvla ir is it a owners club job - i don't own the car , its a prospective purchase [ 74 plates ]. Cheers in advance
Last Edit: Apr 11, 2014 19:01:22 GMT by grumpy
Copey
Apr 11, 2014 18:18:22 GMT
you can work it out from the chassis number, its got a build date coded into it, google how to read the chassis number for whatever make of car and you should be able to work it out from there
grumpy
Apr 11, 2014 19:02:14 GMT
I havnt got the car mate and cannot see the number unfortunately
Apr 11, 2014 19:53:50 GMT
Hi, what car is it? I it's BL then use the Heritage centre at Gaydon they will issue a cert to present to DVLA otherwise use the relevant owners club. Do you know when it was first registered? Do a reg check with DVLA. If it was first registered in the January then it may have been built the previous year. If it's a small or popular model, build date and reg date can be quite close. If it's a large or slow moving model it may hang around in stock for a while. You say it's on 74 plates which letter plate is it? Don't forget the letter changed in August.
Colin
grumpy
Apr 11, 2014 20:02:23 GMT
Thanks for the reply , no its a car on ebay , on 1974 plates just wondeing if there was a easy way to get the build date , didnt think there would be really without having chassis number .
Apr 11, 2014 20:08:19 GMT
Why not ask seller - they might have already done the search to see if tax exempt. Also in last budget wasn't it announced the reintroduction of a rolling 30 year tax exemption so all you'd have to do is wait a year at worse.
Paul H
grumpy
Apr 11, 2014 20:14:12 GMT
Yes paul , it would only be a year but knowing my luck it would get changed again - you know what these govements are like !! Didnt think of asking seller - its a bit hit or miss them answering most of the time . Cheers .
Apr 11, 2014 20:57:06 GMT
you can work it out from the chassis number, its got a build date coded into it, google how to read the chassis number for whatever make of car and you should be able to work it out from there There is not a build date code as such , the 'chassis' numbers are a numerical or alpharetical order in which it rolled off the production line so you need to find out what chassis number rolled off the line on the cut off date and if the one on the car is a lower number than it will RFL exempt. Owner clubs are the best option to find out even with just the reg number as some clubs have a database of cars (and before some cries data protection it doesn't apply to car details)
Last Edit: Apr 11, 2014 21:20:35 GMT by Deleted
Apr 13, 2014 20:04:28 GMT
is the build date not written on the V5? Could you not just ask the owner for this info?
Apr 14, 2014 13:40:27 GMT
is the build date not written on the V5? Could you not just ask the owner for this info? No only the date first registered is on the V5C.
Apr 14, 2014 13:41:37 GMT
. Also in last budget wasn't it announced the reintroduction of a rolling 30 year tax exemption so all you'd have to do is wait a year at worse. Paul H It's a 40 years rolling exemption.
craig1010cc
Club RR Member Number: 35
Apr 14, 2014 14:16:39 GMT
I'd work on the assumption its not, and then if it is you've got a nice bonus. Realistically, if its got a 1st reg date in Jan / Feb you've got a chance, after that (unless it wasn't a good seller) its very unlikley to be. And if its not on a M plate, I'd def say its highly unlikley to be.
Apr 14, 2014 17:22:56 GMT
. Also in last budget wasn't it announced the reintroduction of a rolling 30 year tax exemption so all you'd have to do is wait a year at worse. Paul H It's a 40 years rolling exemption. is that not the important date anyway. I knew there was only one date on the V5, got mixed up which one it was
Apr 14, 2014 17:58:55 GMT
i would think the free tax is 40 years from registration rather than build date as this is already on the dvla data base so easy for them to govern, also the free tax was for cars which had been on the road for 25 years thus paying enough rfl in that time to get it free so i would expect that this will still be the case except its now 40 years.
adam73bgt
Club RR Member Number: 58
Apr 14, 2014 22:29:34 GMT
the tax exemption for historic cars goes by build date as opposed to registration date
Apr 15, 2014 10:28:57 GMT
I may as well ask since this topic is open.
I know about the fact that it is the build date which goes towards determining whether a car is tax exempt or not, but is a rolling exemption as of this moment or is it an annual rolling exemption? I ask as when my Stag's tax comes up for renewal in a few months time it will be 40 years old by the build date, but the car itself was built in March 1974 going by the VIN number. I may apply for exemption this year, or will I have to wait until April next year?
Last Edit: Apr 15, 2014 10:29:58 GMT by ChasR
Apr 15, 2014 11:00:36 GMT
Hi, it's annual rolling exemption. If it was daily like you are hoping for, then it could be too much for DVLA and it might slow down or upset the service they provide!!
Colin
