May 11, 2007 13:17:41 GMT
Loving this thread! How to get that cool retro look and not have to worry about speed humps or the missus and neighbours getting fed up with the growing collection! Sadly, my only model pimping happened when I was a child. Discovered that permanent maker is great for that tinted window look! Then I learnt that destroying model cars was good fun. Doh! How I look back and cry at some of the stuff I smashed up! My survivors The Maestro is one that used to have working lights when you pressed it down. Muggins here decide it would be fun to smash the windscreen so I could see what was inside. The Acclaim has steering front wheels and used to be yellow.
markbognor
Club RR Member Number: 56
retro modeling markbognor
@markbognor
Club Retro Rides Member 56
May 11, 2007 13:37:34 GMT
Nice tips wagoneer, keep em comming, ive just ordered a couple of kits so will be building for the first time in years. +++=Lowrider with working "Hydraulics" independent control of each wheel via IR remote control and set patterns all from an easily programmable IC. And, slightly less full on, ++=Lowrider with font and rear lift and drop, with a set sequence run from a programmable IC, possibly sound activated. So just these, the gravity racer and the real car to be working on now.
May 11, 2007 13:41:33 GMT
MB, they look good. I was reading a review of the engine that comes with that Catalina kit just last night (how sad am I). Where did you get the 'draulics stuff from?
Peugeot 307sw - Suzuki SV650S - MX5.
May 11, 2007 14:02:18 GMT
Where did you get the 'draulics stuff from? Ditto on the wheels. They from someone who carries a stock?
markbognor
@markbognor
May 11, 2007 18:18:54 GMT
Everything apart from the PIC stuff is off the bay, wheels from here. Micro servos from two different sellers, loads about heres who i used for the set of four SG90's. The Impala came from a uk seller, i was the only bidder! and the early skyline came from EnterFunThe Programmable ICs and accesories came from Techsupplies who are a schools technology materials supplier, its stuff we use to teach systems and control in school. Not quite sure how i'm going to make the linkages between the servos and suspension, but i've got this idea that i might be able to use very fine piano wire that runs into a peice of brass tube bent round 90 degrees, with about the radius of a 2p. Looking forward to getting all the bits and bobs through so i can start planning properly.
markbognor
@markbognor
May 11, 2007 18:22:21 GMT
Oh, and i don't think the wheels will look quite as cool as those, the listing says they are the narrow wheels, the pic has packaging for the wide. stll it probably means they will be easier to fit under the body.
May 11, 2007 18:26:55 GMT
Great links MB. How about guitar strings, either steel or nylon. One string would do the whole job easily. The tubing could be made to look like a shock, if you really fancy a challenge!
markbognor
@markbognor
May 11, 2007 18:39:23 GMT
Yeah, i was thinking about guitar strings as i put up the last post. The actuator tube could deffo be made to look like the shock, or the ram. I'll probably just get them up and running to function properly, without worring too much about going overboard on the suspension detail.
qwerty
Club RR Member Number: 52
retro modeling qwerty
@qwerty
Club Retro Rides Member 52
May 11, 2007 18:53:19 GMT
Gotta have a detailed and in depth build thread for that low rider!!
RetroMat
Column Shifting!
May 11, 2007 19:25:42 GMT
Last Edit: May 11, 2007 19:27:12 GMT by RetroMat
May 11, 2007 19:44:51 GMT
That's the trouble isn't, you fancy the wheels then buy something to put them onto. Obviously buying wheels to suit what you've got would be far too sensible...
Look forward to seeing how that one turns out MB!
I'm happy as I've won that oddball CROWN.
RetroMat
Column Shifting!
May 14, 2007 11:45:04 GMT
just won this I should realy finish some models before buying more, but it was only £1.99 now I just need some scale wires ;D
Last Edit: May 14, 2007 11:47:31 GMT by RetroMat
May 14, 2007 11:53:46 GMT
I'd have done the same... That's how I ended up with this on Saturday: It was down to £8 from £22, couldn't resist that level of detail for the money. Same as I've got planned for a Quattro rally car, will get built as a fast road car rather than a strict competition replica.
st182
'yota man
May 14, 2007 13:09:26 GMT
Good grief! lots of you guys got skills! I bought a few models (first ones since being a kid) a few years ago at shows, with the intentions of them being my winter projects. Heres a few pics and their progress: Fujimi Celica XX- written off really, it don't look that bad in the pic but believe me the black paint details are all wobbly Arii RA40 Coupe, just chassis assembled and sprayed shell Hasegawa TA22 GT, just shell and bodykit sprayed Having attempted to build themodels above, I have nothing but respect for the moddlers in this thread ;D well done folks, as you can see i've given up- I certainly don't have the talent for it
Dan '93 JZA80 '79 TA40 '99 SCP10
JC
May 14, 2007 14:04:43 GMT
Having attempted to build themodels above, I have nothing but respect for the moddlers in this thread ;D well done folks, as you can see i've given up- I certainly don't have the talent for it the first one looks like it's coming along quite well! I know what you mean though, I think I can only hope to achieve something close to some of the examples here. The Dioramas section of that site has given me some ideas though, ie i can buy a kit just to half-inch the wheels, then turn the rest of the kit into a garage/abandoned wreck diorama thing!
Last Edit: May 14, 2007 14:08:07 GMT by JC
May 14, 2007 19:18:50 GMT
For the black window trim I think you can get a black version of bare metal foil (self-adhesive stuff that's nigh-on essential for doing chrome trims).
Can you carefully scrape the black paint off back to the edge of the strip?
JC, don't waste cars just for the wheels! A wheel-less car is a perfect excuse to buy an accessory set...
st182
'yota man
May 15, 2007 16:33:18 GMT
hmm scraping, that may help a treat- I bought a craft knife thingy when I bought all teh consumables to build em, I'll give it a shot As for the rims thing, I'm thinking if I give the 77 coupe a good go, it'll be getting some hayishi streets or similar Ideally I'd want some ma61 arches too!
May 15, 2007 17:02:36 GMT
st182
'yota man
May 15, 2007 17:18:34 GMT
oar some!
May 15, 2007 17:27:48 GMT
thats mint. for my college photography project I took some pics of my models. The RX-8 and VW Bus are unfortunatley diecasts, but the Mini and Mustang are one's I've made [never actually finished the Mini...] ^ hand painted.
