A How do you create a link
B when I emailed them they stated they will programme it to getting running and to download tuner studio. Looking at their feedback to date they have sold 5 ECU with good feedback.
Bear in mind that with the edis you can only run a minimum of 10 degrees advance. I switched away from edis on my turbo setup as you cannot have a spark cut limiter or less than 10 degrees advance. When the spark signal is cut to the edis unit assumes there is a fault and just defaults to 10 degrees advance as a limp home mode.
I use ms2 on a v3.0 board and have added in the extra coil drivers. This let's me bypass the edis unit and run the ford coil directly from the megasquirt(still wasted spark) . I bought the gear to do this from diyautotune as it's alot cheaper than buying it in this country!
MrSpeedy
East Midlands
www.vintagediesels.co.uk
^^ Interesting. I was considering doing that myself. I've got an Edis 6 to use, but was considering the direct driver option. I prefer the idea of an ignition rev limiter rather than fuel based one.
A How do you create a link Instructions for a desktop computer or laptop, phones and tablets need different clicks but is essentially similar. Find the page you want to link to, select the site address ie. www.ovalbangerchat.co.uk copy this either by pressing Ctrl+c or right click mouse button and choose copy Go to the create post option on here, type your post then click the button at the top with a picture of the world and a sheet of paper (if you hover the pointer over it it says link You will get a box pop up on the screen with 2 boxes you can entire information into The top one is for text - ie what you want the link to read as The lower one is for the website address you want to go to. So as an example for this conversion/ thread you could enter - text - megasquirt choices link retrorides.proboards.com/thread/162051/megasquirt-choice?page=3giving you something that should read/ look like this Megasquirt choices page 3
sowen
Club RR Member Number: 24
Megasquirt choicesowen
@sowen
Club Retro Rides Member 24
To get around the minimum advance on the edis you could knock the crank sensor a few degrees out and map the ignition curve accordingly ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
You can do coil on plug too....
Koos
That would work Sowen, but it might make it confusing when you come to tune it in the future and forget that it is retarded by X ammount from what it actually is! The only part you need to add to the basic MS2 is HERE this will give you enough for 2 spark outputs (to run a 4cylinder wasted spark). If your replacing EDIS 6 then just get 2 of these, or for a V8, get 3 of these. Considering they are only about £5 each and can be added to the board when its being built, its a very good addition to the kit. Buying the bits to modify mine and also the postage from the states worked out cheaper than the EDIS8 unit which is pretty rare over here! James
All the wiring info is also HERE
Oct 28, 2015 15:20:04 GMT
Yes it uses tuner studio his ebay username megasquirt_performance, I have emailed him Link is here for a previous one ebay linkI think it is basically a clone/ copy of a MS but without the firmware loaded, which is i guess how they are getting round copywrite or whatever as MS isn't opensource. I guess it must be very very close to being a MS if they are planning on you using the firmware download designed for megasquirt, as they don't mention what firmware it is designed to run/ what they can supply and it would be pretty useless without. checked on the megasquirt support form, it has been recorded as a counterfeit, showing full details including photographs
Last Edit: Oct 28, 2015 15:32:19 GMT by oscarmax
