Mar 11, 2017 18:48:45 GMT
Oh really, just been talking with him. Never had a contact issue. In closer inspection. I'm not happy with the mating surface of the block really, the cosmetics need the best surface possible to seal properly, there are areas of pitting, whilst it's at this stage and waiting for parts I'll get it back to the machine shop, also he heads will be getting a little work in the throats son may as well go back with them.
Mar 11, 2017 19:41:04 GMT
Great to see the updates on this!
Is the place you're having the machining work done familiar with the 1UZ with regards port work then? Or just a clean up?
- '80 Mk1 Vauxhall Cavalier Saloon, 3.0l 12v... in progress with some special plans ahead - '94 106 Rallye, Endurance Rally Car
Mar 11, 2017 19:42:27 GMT
I'll be doing the port work
Mar 13, 2017 14:26:40 GMT
If you still have not got the studs let me know, I think mine came within 10 days. I know there was a clearance issue on the even bank but that might just be for the VVTI engine.
“It Doesn’t Feel Pity, Or Remorse, Or Fear, And It Absolutely Will Not Stop, Ever, Until You Are Dead!”
Mar 13, 2017 19:01:19 GMT
If you still have not got the studs let me know, I think mine came within 10 days. I know there was a clearance issue on the even bank but that might just be for the VVTI engine. Cheers dude The early Ines need the clearance too,
froggy
Mar 13, 2017 22:18:23 GMT
Doesn't seem to be any support for the 1uz over here for tuning parts. Having a Google around tonight and the evidence for what a stock motor can support is all over the place and a lot of it a long time ago using the factory Ecu .
Mar 13, 2017 22:35:32 GMT
It is difficult for parts sourcing, and yes lots of internet banter but not much uk evidence.
Mar 13, 2017 22:36:32 GMT
A lot of the stuff is on Lextreme.
froggy
Mar 14, 2017 17:53:04 GMT
Made 400whp at 12 psi with just water in my spray kit today . No issues and the water really keeps everything nice and cool . Water temps never got above 82c all day
Mar 14, 2017 20:01:42 GMT
That's good going froggy.
Mar 14, 2017 20:02:55 GMT
Some more goodies arrive today And this, anyone know what is for??
heathrobinson
Broken everything
Club RR Member Number: 111
Mar 14, 2017 20:15:55 GMT
Ring gapping! I was ogling those the other day
Mar 14, 2017 20:30:29 GMT
Yeah, got it for an ok price too, with shipping from the states. Couldn't find anywhere in the uk that stocked em.
Mar 14, 2017 21:23:03 GMT
Mate this place sells them; h-tune.co.uk/eagle-h-beam-rods-full-set/ @ £664.99 but they don't come as standard with ARP 2000 bolts. I got mine form the states as well with the 2000 bolts, which ups them to handle 200bhp each.
Last Edit: Mar 14, 2017 21:23:43 GMT by Bullstarz
Mar 14, 2017 21:26:27 GMT
Made 400whp at 12 psi with just water in my spray kit today . No issues and the water really keeps everything nice and cool . Water temps never got above 82c all day So what do you think 25 psi would generate. Apart from a gearbox and axle in bits.
froggy
Mar 14, 2017 22:20:34 GMT
Stock cams are very Mild so at some point you start to rely on boost pressure to shove the mass through the engine . I'm only making 110 per litre at 10-1 Compression , how that translates to running at 8.5 or whatever I don't know . I didn't get to drive it after the last session but the jump from 360-440 is pretty hairy especially with track day tyres on it now . I'd imagine 1.5 bar is going to be in the 600,s if the turbo is up to the job
Mar 14, 2017 22:29:48 GMT
Got the rods from h-tune with free delivery and a discount code for 2.5% off. I have a good source for arp stuff so may upgrade but to be honest I think the setup is enough. These were dropped off tonight too! It's all happening at the moment
Mar 14, 2017 22:30:08 GMT
Got the rods from h-tune. I have a good source for arp stuff so may upgrade but to be honest I think the setup is enough. These were dropped off tonight too! It's all happening at the moment
Mar 14, 2017 22:31:53 GMT
You will have it all built by the end of Easter then
Mar 14, 2017 22:36:17 GMT
You will have it all built by the end of Easter then Engine could be bolted up mostly if I get other parts to me soon
