Nov 27, 2014 13:58:52 GMT
Impressive amount of work going into this to get the details right. Much respect! I knew it was a major task to get some fiberglass cars up to scratch but didn't know what was required, this build helps a lot (* and confirms that I wouldn't have the patience to put together a tidy f/g motor ) Love the front indicator setup, suits the period look nicely. A neighbour had a 911SC many years ago and I loved the shape and details. As you were...
Nov 27, 2014 15:08:50 GMT
If everyone that built a kit car payed as much attention to detail as you have with this build, a kit car would be far more appealing second hand buy for most people! There are to many badly built kits out here that have not had any thought to fit and Finnish!
This looks like it's going to be a great car when finished, keep up the great work!
A small bracket fabbed in grp to hold the bonnet catch. the new bonnet is longer so the slam panel needs to be extended slightly. The mold is a some scrap steel bent to 90 degrees then some card & packing tape for the sides.
Stage 2 of the passenger wing mods...
adam73bgt
Club RR Member Number: 58
1967 Covin Nein12adam73bgt
@adam73bgt
Club Retro Rides Member 58
Top work! I can only imagine the amount of patience it must have taken to get those panel gaps sorted out and looking good
The bumper is only temporarily clipped into place for a mojo boost, but all the gaps do seem to be behaving. The bumper is only a flimsy skin, so will need to add a few layers if matting and bond in a metal frame, so it can be attached to the car.
Anglia68
Powered By Boredom.
Very impressive work.
bstardchild
Club RR Member Number: 71
1967 Covin Nein12bstardchild
@bstardchild
Club Retro Rides Member 71
Thank you - found this thread as a result of a nomination and this evening I've done all 14 pages - very impressive
nel5on
West Midlands
I've watched this thread since it started...great work, you will be rewarded with fantastic retro ride.
Covin 996.2 Tucson
Mark
You make it look easy but we all know it isn't.
E36 BMW 318is saloon (rare as a hens false tooth) VW Caddy Maxi 2010 (usually full of Labradors)
Last update of 2014 so i'll see you guys on the other side.... Reshaping the passenger side sill to allow the wing to sit flush. Also expoxied a new shelf into which will allow a bracket to keep the wing bolted down. Some grp flat sections glued into place to mount the horn grill and indicator unit First stage of laying up extra matting to beef up the bumper skin. Gotta do it a little at a time to keep the heat down to avoid warping
qwerty
Club RR Member Number: 52
1967 Covin Nein12qwerty
@qwerty
Club Retro Rides Member 52
Excellent work as always! Had you done much work with Fibreglass before this project?
Dec 23, 2014 11:01:03 GMT
No, nothing before this project. its really easy. hardest bit to work out is what type and weight of matting to use, then just knowing how much resin to hardener to mix for the amount of matting you plan to use. after a while you "just know" how much to use without measuring. TBH it doesn't have to be exact.
i buy cheap plastic pint glasses from the pound shops to mix the resin, use wooden stirrers you get in costa coffee (other brands will do) and buy quarter inch disposable brushes in bulk. its actually cheaper to use once then bin the lot than clean up with acetone.
So last night, a 100cm x 10cm strip of the main bumper section was beefed up - one layer of 300g matting, one layer of woven roving then another layer of 300g matting. laid up one at a time with resin. stipple down with the brush to push the air bubbles and force the matting to "drink" the resin. used about 1 pints worth of resin and about half a shot of hardener. you adjust the amiount of hardener up or down depending on the temp and how quickly you want it to go off.
Dec 23, 2014 12:21:41 GMT
...oh...nearly forgot...i picked these twin carbs up for £26 yesterday for the rotary engine. Twin HIF38's off a 6 cylinder rover sd1.
Jan 19, 2015 17:55:10 GMT
Excellent work as always! Had you done much work with Fibreglass before this project? I was going to ask that question a while back..... But while I'm here I'll ask if there are any updates...........please ;-)
Last Edit: Jan 19, 2015 17:56:03 GMT by redratbike
Ian
Jan 20, 2015 10:14:55 GMT
xmas was abit slow, had a dose of virally stuff and TBH doing the grp work to get the wing ready to bolt on and ready to accept the indicator lights and horn grill was, well, fecking dull. So no pics.....some pics when the wing gets fitted later this week Attention has now turned to fitting the bonnet catch - this is the catch fitted to the old covin "impact bumper" bonnet, which i had to wrestle out of its storage (was wdged between the standard 8 chassis and the ruby bodyshell which fitted straight on the 911 long nose bonnet.....those germans.....so efficient....as its appears the catch mechanism is off a mk1-2 golf Passenger wing is also ready to be fitted - just wating on some bridging filler to go off.
Jan 27, 2015 18:59:14 GMT
Always exciting to see an update on this, i've always been impressed with peoples fiberglass skills. all i can make is a mess.
Em
Fuel Injected? Carb Infested!
Jan 27, 2015 20:08:26 GMT
Just love this project!
There must be something very satisfying in knowing you can do pretty much whatever you want with it without fear of incurring financial ruin through spoiling it's 'Porche-ness', if that makes any sense...
Fantastic work so far, you make fibreglassing look easy (although I'm willing to bet it 'aint)!
Keep at it; it's going to be fabulous when it's done!
