May 30, 2013 21:09:04 GMT
I'm thinking about changing from a twin choke weber on my 2.0 pinto to either twin carbs or bike carbs I'm just putting out the feelers to see what people have avalible. I've a manifold for 40's already ;-)
omega
May 30, 2013 21:57:39 GMT
if you want easy go for the 40s plenty of info for jets etc
goldnrust
West Midlands
Minimalist
Unless I've got mixed up, bike carbs are usually used instead of something like twin 40s as a cheaper option. So if you've got the manifold ready for 40s and wanna pay for them go for it.
`state
Yorkshire and The Humber
You`ll get same results power wise but with bike carbs it`ll drive better at low speeds,wont use as much fuel and wont need them retuning again and again like twin carbs. Just make sure its set up on a rolling road by someone who understands bike carbs rather than just drilling the main jet out. Ive got a set of zzr1100 carbs that are the full power import ones where the slide moves right up unlike the uk restricted ones. 40mm so ideal for a 2.0. £45 posted.
Last Edit: May 31, 2013 8:13:59 GMT by `state
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
You`ll get same results power wise but with bike carbs it`ll drive better at low speeds,wont use as much fuel and wont need them retuning again and again like twin carbs. Just make sure its set up on a rolling road by someone who understands bike carbs rather than just drilling the main jet out. Ive got a set of zzr1100 carbs that are the full power import ones where the slide moves right up unlike the uk restricted ones. 40mm so ideal for a 2.0. £45 posted. Hi there I'm deffo interested in these carbs :-D PM me your contact details and I will be in touch ;-)
May 31, 2013 15:51:54 GMT
Show me a car that has ran bike carbs successfully and efficiently for at least two years,
Bike carbs are for bikes get a set of twin carbs properly set up keep the clean and you'll get more smiles per mile than bike carbs..
I'm leaning towards twin carbs if I'm honest but the price of them is what puts me off, unless somebody has a set they would let go for a reasonable price
i would not touch twin 40's in a month of sundays over bike carbs. people that slate them, don't understand them or know how to set them up. i had mine at the rollers recently and the operator couldn't get over how smooth and stable the torque curve and the afr was
Why you always bring me junk!
Jun 13, 2013 20:43:14 GMT
I have a matching numbers pair of 40 dellortos £140. Simon on 07940 722558
Jun 14, 2013 16:27:58 GMT
Well I've bitten the bullet and gone for bike carbs, Honda crb 900, fingers crossed
cortinadale
luvvly jubbly!!!!
Jun 14, 2013 22:13:55 GMT
I have a 2 litre zetec with bike carbs. Its amazing. Twin carbs are history!!
We learned from an early age that...people who change signatures suck balls ;-) 1978 Cortina 2.3 ghia
Well I fitted them yesterday and they seem to be working fine, one thing I hadn't thought about and knowbody has mentioned is that the throttle is really short, I think it's something I will have to learn to live with
Jun 16, 2013 11:10:36 GMT
Try fitting a twist throttle to your steering wheel..
Seriously though you just need to lengthen the throw on your peddle or on the carbs.
This will give you more leverage and more control,
Good look and you do realize PICTURES are mandatory on RR.
Jun 16, 2013 11:28:35 GMT
I will get some pics up soon I'm having some laptop issues (I browse on my phone)
Jun 18, 2013 21:19:01 GMT
if you need any help with the setup just shout !
if you need any help with the setup just shout ! You will be first person I call for if I run into difficultys ;-) I've currently got an air leak but I'm sure I can sort it easily
no prob,remember to block the air corrector for the main jet if your using the cbr900's, otherwise it will keep leaning out at what and you'll keep enlarging the main jet to compensate which is not the right thing to do.
