79cord
Wow, lots of work there! Glad to see it looking for more solid. Amazed the 400 rear seats fit so well & look great, love the tyre tread pattern, though sad the shiny cloth & plastic belt-buckle holders look so obviously modern.
May 24, 2013 14:34:04 GMT
hi rob I was going to do that with dead sheets then I thought I could stamp them myself but at this point I had them welded in place so I made a block of wood grooved out the half round then capped it with some sheet metal so I had a negative stamp I jacked the block from the floor and hand stamped with a round edged chisel just drilled a hole in the floor each end to line up then filled with the mig when done I was supprised on how much the sheet went rigid after I done it . ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/feb2floor013_zpsa0eeccc7.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/feb2floor016_zps61848e5e.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/feb2floor018_zpsbffaab04.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/aug2011010_zpsfe6b6a68.jpg) new inner sills in place with the new blocks i welded in the the rover front seats the big bar to the left is not part of the car its the spit support bar i made .
sowen
Club RR Member Number: 24
1970 Austin 1300 2dr sowen
@sowen
Club Retro Rides Member 24
May 24, 2013 14:41:53 GMT
Wow, you've put a lot of new metal in that, and nice trick on jacking the block of wood up from underneath!
May 24, 2013 14:45:48 GMT
Thats looking good, not many 11/1300 2 doors about, your right mate its a shame more have not been saved there a good little British car and look good with some minor modifications . there are far more 4drs left i suspect i also have a 4dr Morris 1300 for a parts car but might become a future resto . ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/new_austin_001_1144_zps040c9eab.jpg)
May 24, 2013 14:46:10 GMT
v8ian
May 24, 2013 15:08:57 GMT
Funny thing, where I live there is a White mkII 4 door belonging to a mates wife, bit of a seaside car,---- flat paint and rust stains everywhere, but its not a bad car, there is a partially restored VDP Metallic Green MkIII and a very nice white MIII 2 door, its a bit of a haven for old cars here, Lost count of how many Morris Minors, a ratty Mk3 Capri 1.6 GLS??? Vauxhalls, Rovers, you name it there is one hiding.
Funny thing, where I live there is a White mkII 4 door belonging to a mates wife, bit of a seaside car,---- flat paint and rust stains everywhere, but its not a bad car, there is a partially restored VDP Metallic Green MkIII and a very nice white MIII 2 door, its a bit of a haven for old cars here, Lost count of how many Morris Minors, a ratty Mk3 Capri 1.6 GLS??? Vauxhalls, Rovers, you name it there is one hiding. nice one keeping the spirit of the old cars going , there are plenty of nice modern cars around today but go forward 20 years its not easy to pick one that would stand out , not like the good old stuff it as if they can tel you a story just looking them , cant beat old cars !
during the re fabrication of the front end i always had at the back of my mind extra power the top factory power for the GT engine that i have is in the 70bhp end , some of the mini scene guys are squeezing over 100 bhp with ease with some high end engines giving out 200 bhp with turbos and blowers ect the a series engine is a brilliant bit british engineering its amazing what it can be made to do, there are other conversions like the Honda vtec engine but for now no plans to go in that direction, so with this in mind during the build i decided to beef up the front end first with solid front sub-frame mounts and beyond that i built struts that one of them is bolted direct to the top sub-frame mount back to the dash cross member then the other goes down to a new box section i built over the inner A post, when my roll cage goes in it will meet up with this so its directly bolted to the front sub frame i hope this will give the rigidity i need to strap in as much future mechanical madness that i can only problem is this then opens up other issues like brakes suspension all of witch are standard not even a brake servo standard , so they will need addressed before any of that happens , it will become a rolling project at some point so standard it will stay for now in that respect the mot must come first . ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/austinsummer2013024_zps196f2d31.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/spit038_zps93b3eb5e.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/austinsummer2013023_zpsb1da425a.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/austinsummer2013017_zps545cd512.jpg)
v-tec in the ado16 this is a company in the states that develop a complete new sub-frame to take the Honda engine Mini Tec , now that's a modified classic! or Austin america is its called over the water, i would like to find the picture of this complete . ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/154713_483927052312_189756617312_5495439_3086497_n_zpsa07ea5a7.jpg)
May 29, 2013 18:46:00 GMT
hi i got the first coats of old English white on the engine bay today 1k acrylic now i just need to wet sand to prepare it for the clear , its good paint to use as it goes off very quick was just unsure of the mix i went for 1:1 . ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/austin2summer2013006_zpsa8fcda48.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/austin2summer2013004_zpsf036ab25.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/austin2summer2013005_zps01857af5.jpg)
now with clear coat on ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/enginebayclearcoated1002_zpsec3501b8.jpg) looks nice happy with the acrylic paint its also the first time i have painted other than a rattle can ! ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/enginebayclearcoated1003_zpse6637bba.jpg)
![](http://i1360.photobucket.com/albums/r644/austinmorris1300/enginebayclearcoated1001_zps72a41aaa.jpg) next job fitting back the front sub frame to start the mechanical work i plan to finish the body when it rolling and possibly running,
dajwid
Bloody hell! Fantastic job! I certainly take my hat of to you. I will certainly be following this thread closely.
Fantastic work turning this around with some excellent fabrication skills. Engine bay looks really good, if you finish everything thing to this standard it'll be a superb example. Keep going mate and keep the pics coming.
luckygti
I need to try harder!
Looking good, especially the fresh paint. Is it going all the same colour or will you be going black on the roof?
thanks for your comments . yes i will go for black on the roof not sure on gloss or satin though ? as its a 1970 i can go for the black reg plates to so this will add the the color theme quite well . would also like a set of black 13" superlights it would just top it off,
Loving this thread....
I REALLY miss my old ADO16
ed325i
v-tec in the ado16 this is a company in the states that develop a complete new sub-frame to take the Honda engine Mini Tec , now that's a modified classic! or Austin america is its called over the water, I would like to find the picture of this complete . ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/154713_483927052312_189756617312_5495439_3086497_n_zpsa07ea5a7.jpg) Looks abit like the one my brother built. ![](http://i44.photobucket.com/albums/f1/ed525sport/13001.jpg) Ed
v-tec in the ado16 this is a company in the states that develop a complete new sub-frame to take the Honda engine Mini Tec , now that's a modified classic! or Austin america is its called over the water, I would like to find the picture of this complete . ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/154713_483927052312_189756617312_5495439_3086497_n_zpsa07ea5a7.jpg) Looks abit like the one my brother built. ![](http://i44.photobucket.com/albums/f1/ed525sport/13001.jpg) Ed hi mate wow you can see a resemblance , that is a very nice car he has done there i like the arch extensions fit well with the body line. have you any more pictures of the car engine interior ect or is he on the forum , thanks for sharing nice car.
![](http://i1360.photobucket.com/albums/r644/austinmorris1300/th_a_zpsbfbce974.jpg) ![](http://i1360.photobucket.com/albums/r644/austinmorris1300/a_zpsbfbce974.jpg) in the early days of rotten floor and inner wing this car was really bad at the front end . Hats off to you, most people would have ran for the hills screaming like a loon when they seen that. Excellent fabrication work, your MOT tester will lay an egg when he sees that amount of welding ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Regarding wheels, what's wrong with the slot mags in your avitar ?
72 Pontiac Firebird Formula 400. 95 BMW E34 525i Manual. 80 Lotus Elite, sold ![:(](//storage.proboards.com/forum/images/smiley/sad.png) 86 Mk4 Escort RWD V8, sold ![:(](//storage.proboards.com/forum/images/smiley/sad.png)
