XL391
Apr 29, 2013 23:51:51 GMT
After wanting a Series 1 XJ since Dad had his, (early 80's), the last 6 years i've been half looking for one, the last 8 months seriously. Lots of overtime working away allowed me to seriously consider getting a decent example. I've had this just over a week, not perfect by any means but a good solid base to improve over the next few years. Anyway, a few photos, one of her outside my place the first night I got her, the others I took of her last Friday evening.
Last Edit: Feb 28, 2020 23:01:18 GMT by XL391
Mark
Apr 29, 2013 23:57:36 GMT
That looks incredibly tidy!
XL391
Jul 10, 2013 20:29:07 GMT
Not much to report really, some initial problems with the AED (auto choke) have been resolved and she's running great! I also found the carbs were hissing to a great extent. Found it was a tap from the inlet manifold drawing air in. I couldn't see any pipes in the vicinity that had come adrift so I went to the Internet for help. A very basic diagram drawn on Microsoft Paint saved the day. It showed a pipe that ran from the back of the engine bay into the AC system (now long gone). Plugged the hose on the inlet and the car has improved immeasurably! Done nearly 1600 miles since I got her, long and short trips, and she has behaved superbly. Don't ask about the fuel bills though! Some areas have been found that will require attention, front and rear screen seals, near side inner rear arch, small section of the floor pan and a rebuild of the handbrake mechanism. Anyway, some pointless photos from a trip to Wales, taken in the middle of nowhere... Oh, and a pic with XH558, the last flying Vulcan bomber! Thanks for reading!
Last Edit: Feb 28, 2020 23:09:52 GMT by XL391
cozjon
Jul 12, 2013 18:43:34 GMT
one of my favourite car ever, yours looks stunning
Jul 12, 2013 18:53:04 GMT
very tidy looking car
www.facebook.com/AngrySpiderRacing
1965 Karmann ghia RHD Race car
1969 Baja Bug (splat)
1979 Leyland National London Bus
1981 DeLorean DMC-12
1993 Chevrolet S-10 4.3L Pink, and rolling 20's
1996 Toyota Paseo Super Modified Rallycross car
Brian Damaged
West Midlands
Club RR Member Number: 33
Jul 12, 2013 20:32:47 GMT
That's gorgeous, the pre-facelift XJ is one of the best-looking Jaguars (ok...and Daimlers) ever, IMHO. Timeless.
XL391
Been away for some time from here so I thought I'd update you on what's been happening with the old girl. The first 8 months of ownership have so far been very good, just a few minor issues to be expected of any 40 year old! I had an issue with the off side front indicator unit back in July, behaving as if the bulb had blown. Bulb changed and the problem remained. Earth checked which was fine. Wiring connections checked and, again, all good. So, multimeter into the socket which indicated it was getting power. I didn't know how much it should be getting however. Long story short, the wiring in the light unit corroded to a pile of green dust when I checked it. Not wanting to shell out for a new light cluster I soldered a new wire into the back of the connector and we were up and running again. Also cleaned the earths and soldered the wires in as opposed to them being held in by a copper sleeve. The AED was cleaned out not long after I got the car but soon began its party trick of trying to remove as much fuel from the car via its overflow pipe as it could. In the end, I removed the bi-metallic strip from the top of the unit and its been fine since. You just have to warm the engine for a minute before moving off. Normally, once the temp needle is off its stop, she'll idle. As she won't be leaving her cosy lock up over Winter, I've no real need for a choke anyway. Anyway, this Winter I plan on removing the front wings and rear lower panels and fuel tanks to give her a bloody good hiding with the Waxoyl stick. It was with great trepidation that I took the inner wheel arch closing panels off expecting it to have a few patches of the dreaded tin cancer. To my eternal surprise, not to mention joy, all seemed good both sides! We'll see if it is the same story at the rear...
Last Edit: Feb 28, 2020 23:24:49 GMT by XL391
That is a truly glorious car... I have always liked the S1 XJ6's (who hasn't?!) and this one looks a peach!
I will keep a close eye on this one although I cannot see how this can be made any better.
***GARAGE CURRENTLY EMPTY***
Nice car! Not helping my Jag withdrawal symptoms at all....
Series I XJ's seem to withstand the rust bug better than the later SII and to some extent the SIII.
The AED's are a pain - if you can find one of the override mechanisms that sit on top and are controlled by a choke cable, they make a world of difference. The bimetallic strip is activated by hot air off the exhaust manifold. There's a metal pipe run round the back of the engine and if its lost its lagging, the hot air is cold by the time it gets to the AED so it doesn't work, and acts as if its on choke all the time.
Also the AED has its own float chamber and filter; these are usually the culprit when the overflow pipe starts dumping.
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
XL391
Evening gents, thought I'd go for another six monthly update. I had a massive schedule of work I wanted to do to get it to how I want it. Needless to say I couldn't complete everything without not being able to use it do I've done what I can. First off, I took Rich's advice from the above post and lagged the AED hot air pipe that draws hot air from the exhaust manifold. The AED was also removed and stripped right down for a thorough cleaning. While it was apart I replaced the gaskets, filter and the float, the diaphragm was in good shape so I left it. I also fitted electronic ignition in place of the points and now it's running great. With the body, I knew the inner rear arch panel would be needing work or replacement. So I removed the tank panel and tank and went digging... After tearing off all the old under seal I found a couple of holes and a poor previous repair. Instead of just patching it I decided to make a template and just cut the lot out. After clamping it all into place using Frost's brilliant panel clamps... ...It was all welded up. I also found a rust scab in the nearside outer headlight which was ground out, treated, primed and painted. After all the bodywork was finished it was back to dealing with the details. I changed my centre console from my black one which was looking tired to an aluminium one I got from a car being broken not far from me. I also sourced a period Radiomobile 1095 with iPod capability to replace the woefully 80's tape deck fitted. The car had a period Moto Lita 3 spoke wheel fitted which I replaced with a standard wheel, again given up by the Jaguar being broken. There are still a few jobs to do, since being laid up she has started getting warm in traffic. The rad is getting re-cored and there'll be a Kenlowe fan getting fitted. Changed the exhausts from curved to straight too, I think it looks much better...
Last Edit: Mar 11, 2020 20:35:57 GMT by XL391
Now that is just stunning, remember these in the lex show room where i grew up in bexleyheath, the cream in the showroom amongst marinas dolomites etc,,, and granada daimler/jaguar in the sweeney? Blaggers car for me everytime ,, I'm so envious such a stunningly beautiful car
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
stonio
I would love 1 of these purring around town..lpg and air ride in the boot
Awesome stuff! Nice to see someone getting stuck into one of these.
I'll be back on with mine soon.
This just looks stunning...
These cars are just so pure in their design and this example really does show that off to the fullest!
It's nice to see you working your way around the car to bring it up to a really nice solid state. It just looks perfect!
Carsie
What a lovely car! As has already been said, so pure in design and great that you're focusing on it's purity rather than b**gering about with it! (still love yours though Richw82; it's a fav'd bookmark If you'll allow the anorak in the closet to come out... the straight pipes at the back were cranked because exhaust fumes entered back into the car. Alloy centre dash, rear reflectors and chrome instrument rings - all early cars (sad heh that I know this stuff! lol!...shakes head) Anyway - great Jag (Daimler) very cool!
XL391
Thanks for all your comments gents, they're much appreciated! There are certainly cleaner ones out there but this is just a nice, usable car. Whenever it's sunny it's out getting used, don't see the point in keeping them locked away. The mods I'm doing are concentrating on making it that bit more reliable, but all looking period. Mods like triple SU's off a Mk.X for instance...(I wish!!) Carsie, I'm an anorak as well! Or a nerd, as the better half likes to put it! I did look at a set of chrome rimmed dials, couldn't justify the expense at the time though. I much prefer the look of these straight pipesand they're a bit less restrictive. You're right about the pipes too, fumes were sucked into the boot. To be fair though, the Missus is very rarely locked in there now, her behaviour has improved a lot...
GT4ME
May 11, 2014 17:41:09 GMT
Nice old thing.
XL391
Aug 10, 2014 20:18:31 GMT
There are still a few jobs to do, since being laid up she has started getting warm in traffic. The rad is getting re-cored and there'll be a Kenlowe fan getting fitted. You may recall me saying this in my last update? Well, I had the radiator re-cored, an excellent job done as well. After coming back from Tatton Park, I stopped at a shop, got back in and when I started up I was treated to clouds of white smoke that rapidly dissipated. I went under the bonnet for a quick check and found the breather for the brake servo on the inlet manifold soaking wet with brake fluid. So next day I pulled the master cylinder to find a substantial leak into the servo. After fitting a rebuild kit to the master cylinder and a new servo valve, I reassembled it all and started up to let the excess fluid burn off. After 15 minutes of white smoke (!!) the exhausts returned to normal. Despite doing this, I noticed that every time I started the car I'd get white smoke. Not as heavy but enough to cause concern. She wasn't overheating but was using a small amount of coolant. The oil seemed ok until I took the engine breather off... This had also bunged up the pipes where they enter the carbs causing the crankcase to over pressurise and blow the dipstick out along with lots of oil! I did a compression test getting an average of 130psi on 1,2,3 and 6. 4 and 5 were at around 150psi, the cause of the higher readings confirmed when looking down the plug holes to see lots of coolant... So, the job I was dreading having to do since buying the car, failed head gasket. Anyway, not thinking about it too much, I decided to adopt a confident approach... Anyone who has done a head gasket on these 'long stud' XK engines fitted to the XJ will be fully aware of the common practice of the head corroding itself to the head studs with nasty results if the antifreeze isn't regularly replaced. With this in mind, I removed all the head nuts and blasted them with PlusGas and WD40 for a week while I removed all the other ancillaries. While trying to remove the stubborn Inlet manifold, the head cracked free from the block so I decided to take it all in one go. After putting a bottle jack in between the cylinder head flange and cylinder block flange, the head was free. I was going to strip the head myself but I decided to sent it to a local engineering firm as while it was off for a top end rebuild on account of the rubbish compressions. With the head away, I knocked out the core plugs to clean the block and to assess the head studs. The horror stories I'd heard with regards to the studs snapping when re-torquing convinced me to replace them all. After another 6,000 gallons of WD40 to the base of the studs, they let go with a crack. While they were out I decoked the piston tops and cleaned up the block. The head came back on Friday with new seats valves and head refaced and the tappets shimmed up. It'll be getting a lick of paint before being refitted towards the end of the week. In other news, I managed to find a manual choke conversion for the AED. It hasn't given any trouble since its rebuild but I see it as a worthwhile upgrade. I need to change the choke handle though, I hate it! I've also fitted the Kenlowe fan. I wasn't a fan of the aftermarket switch with its integral light so I obtained a sixties style warning light that I fitted to the bottom right of the dash and a Lucas toggle switch on the side between the dash and the door. I've also, at last, sorted a full size rear plate for it. Thanks for reading, more news as it goes back together.
Last Edit: Mar 11, 2020 20:59:18 GMT by XL391
Aug 10, 2014 20:47:18 GMT
wow cracking looking jag
Bolf
Aug 10, 2014 20:49:02 GMT
awesome , I saw a beige/light brown one of these last week in Ipswich , lowered on nice wheels , looked lovely!
