Am I missing something? Shouldn't Spax lowering springs be shorter than stock springs?
The Spax dampers are shorter than the stock ones for my 944, but the springs are the same length...
Is that normal for a lowered Spax setup?
I was expecting to drop the spring onto the strut, after fitting the insert, and then fit the top mount, but it appears as if I need to compress the Spax spring a lot to shorten it enough to get the top mount on.
Thanks for any wisdom
