All repairs now done on the new floor and its almost stripped of all underseal and ready to be fitted to the car I have just got to weld some braces into the shell to support it once floor removed.
I have turned my attention's back to the sunroof conversion as I had to removed the dealer fitted sliding sunroof due to it having bits missing and was silicone shut so guess it leaked.
I managed to get a complete roof from a scrap 205 with all the vacuum sunroof parts needed. First up was to remove all bits from roof so it only left me with a roof skin which is now the template.
Now I know people will say it would have been easier to fit a new roof but I believe this is easier and on another note if other people wanted to carry out this the no paint would need doing.
the two sunroofs
I the place the roofskin over my roof and secured into place with a bolt through the Ariel hole.
Next up is to drill the holes these are a 12mm hole so to make sure these are drill in the correct position I got my dad to make a drill guide that will fit into the 12mm hole with a 5mm pilot hole through it then I will run a 12mm hole saw through the roof as this will give very little burring.
Once all the holes are drilled I will fit some bolts through the roof skins before I jigsaw the hole larger then I will glue the support bars once the new rivnuts have been fitted I believe this can be done to any aftermarket sunroof fitted sunroof as long as the hole is in the right place.
My dad has been working on the car rotating stand with the front almost complete and the rear one getting there progress will be very slow now as I going offshore for 3 weeks with work.
the two sunroofs
