Dec 16, 2012 23:32:52 GMT
New title ive been offered a bmw e36 325 cab. what do people think of them? issues to look for? cheers andy quick pic for you lot
Last Edit: Dec 18, 2012 21:40:52 GMT by tattoo101
Dec 16, 2012 23:45:53 GMT
Rust & bushes are main thing on e36's. Nice car's though.
Last Edit: Dec 16, 2012 23:47:07 GMT by joem83
bl1300
One thing I found is fairly common when I was researching these is for the bonnet catches to stick either so that the bonnet won't close or wont open.
Either way its a bit of a pain of a job to do, I know as ive just done it. You need to remove the kidney grills , front bumper, and fan unit just to gain access to the catches.
SRS light on is a common fault and most often caused by a failing passenger seat occupancy sensor, this can be readily sorted with a bypass kit.
Front lower control arms are a weak point. If the inner ball joint is gone you have to replace the whole arm, where as the outer can be pressed out. To be honest its easier to change the whole arm and if you do so E30 control arms are stronger and do fit.
If it hasn't been started for a while a bit of tapping on start up is normal but if that continues after the first few seconds or you get a marbles in the engine sound, then you've got problems in the engine.
Electric window mechanisms often fail on e36s check they work.
edit: I put ABS where I meant SRS now changed.
Last Edit: Dec 17, 2012 8:01:24 GMT by bl1300
Current fleet.
Dec 17, 2012 16:16:47 GMT
I bought a 328 manual coupe in Aug and I'm loving it. It really was cheap as chips, but it had a list of things that needed doing. So far I've done all the suspension top mount (fairly easy), fixed the passenger window mechanism (common fault, very fiddly but a satisfying fix) and most recently fitted a new thermostat (bit fiddly again). Next on the list is the handbrake shoes and mechanism on both sides, this is a common fault but needed before mot time. So far the parts have been cheap, labour costs are however much coffee I can drink. Running wise, mine averages 27-34mpg. My biggest issue is the insurance. I won't say what I pay, but I have 13years NCB, am 34yrs, yet the fully comp was more than what I paid for the car!
Other than that, I love mine to bits, best car I've had in ages, but cheap cars are only financially worth while if you are prepared to work on them yourself. I've spent enough time under the bonnet, that if I had shipped the what out, I'd have paid more than the car is worth.
Ta ta, Mark
Monster Monster SIG TOO BIG
Dec 17, 2012 18:23:35 GMT
I'm very tempted to get this. would be nice to go RWD again
bl1300
Dec 17, 2012 18:26:35 GMT
I'm very tempted to get this. would be nice to go RWD again I thought that until I tried to drive it down the lanes to the farm last week. BMWs it appear do not like the combination of sheet ice on ungritted lanes, and steep hills.
Current fleet.
Dec 17, 2012 20:08:18 GMT
Oh yeah, the hand brake/disk set up is a pita of a job to swap.
Dec 17, 2012 21:59:06 GMT
The bushes went on mine.. The car was skipping side to side down the road. And then personally I felt like a tit when I had the top down..
Current retro - 1996 Alfa Romeo GTV / Daily - 2016 Nissan Qashqai Previous retros - Prelude, Integra, XR2s, XR3s, Orions, CRXs, Sylvia S12, S13, Pulsar, ZX 16v, 205 Gti, MX5, MR2 etc
Dec 17, 2012 22:31:45 GMT
I'm not a fan of how they're styled but that one looks much better with the removable hard top
Dec 17, 2012 23:24:31 GMT
the one I'm looking at has the removable top with it
Dec 18, 2012 21:42:40 GMT
Just changed the title for this. It seems the e36 is over looked by the e30. So let see some 36 love
Right now is the time to buy an E36 IMHO. They're now out of the 'chav mods', they're so damn affordable, good ones can be picked up for very little and I reckon they'll soon start rising (gradually) in price for tidy ones as the curse word ones get killed off and broken. A classic in the making? I think so. I'd have one....most likely a touring, probably a 2.5TDS, but they can look so nice whichever bodystyle you go for.
10mpg
Club RR Member Number: 204
love for the bmw e3610mpg
@10mpg
Club Retro Rides Member 204
I had a manual 2.8i vert tuned to 230 bhp, intake, remap ect, lowered on bilstiens, wonderful car, virtually gave it away in the end, nice to work on lovely to drive, great noise, and such a cool roof. regarding the roof I had the semi automatic one, (turn release handle, then push dash button and it all folds away), the fully auto does away with the release handle, but adds an extra 4 or 5 microswitches, a worm gear and a load of hassle, so I's stick with the semi-auto, unless you want to fit a remote control kit, they look cool, but only work on the fully auto...
Mine managed mid/high 30's mpg on a normal fast motorway jaunt, and mid 20's in normal use, amazing for a heavy 2.8 car, even hooning it would stay in the teens, the auto boxes make the car into so much more of a cruiser, the big six needs a manual box to sing.....
Check for rust, and rear subframe bushes, siezed track rod adjusters, and get the best spec you can options are EVERYTHING on a BMW, as everything was optional, and you NEED leather in a 'vert, fabric just doesn’t work and looks naff..
I had an Aubergine purple E36 318ti compact with a cream interior It was really nice motor to drive, was reliable and relatively easy to work on. I changed the front pads & discs (which were pricey, even from a motor factor) and I had to change the bonnet latch. The rear arches go crusty, as do the front. Oh, and it split my head open when the boot dropped down, which I'll never forget I like the styling of the E36 but if I ever have another (which I would) I'd go for a touring. My Wife hated it though
Dec 19, 2012 13:12:13 GMT
Ive had 2 as dailys, but now Id like one for the garage/weekends A 328i Sport Coupe yum yum!
Last Edit: Dec 19, 2012 13:13:10 GMT by RobMorris
Dec 19, 2012 20:45:06 GMT
Hey buddy. Cabrios always seem girly, even if M3, but it could work. I'm trying to imagine matte black with 5-series wheels (extra 15mm of poke) and some archery.
Dec 19, 2012 20:54:32 GMT
Great shape. I've just picked a 328i touring up to beat the winter.
Can't get a pic to work?
Dec 20, 2012 10:13:56 GMT
Hey buddy. Cabrios always seem girly, even if M3, but it could work. I'm trying to imagine matte black with 5-series wheels (extra 15mm of poke) and some archery. now thats nice
Dec 20, 2012 11:14:11 GMT
Last Edit: Dec 20, 2012 11:14:58 GMT by joem83
Ian
Dec 20, 2012 13:16:37 GMT
I really like mine, and miss not being able to drive it, its been laid up for over 18 months now needing a new engine due to Nikasil bore wear to cylinder two. Other than that it was great its a 328i sport couple auto. I habe coilovers sat in the boot waiting to go on as well as new RTAB bushes. Its atiny bit cripsy on one rear arch and the bottom of the drivers door.
