Nov 22, 2012 15:55:06 GMT
Tyres have turned up in the shape of Nankang NS2's in 185/55 flavour. They appear to have a little more side wall than a 195/50 and were slightly cheaper too. Should have them all bolted to the car on Saturday then I can't do some silly photoshopping of lows, until the coilovers turn up which should be in 2-3 weeks time. I ordered a Gaz GHA kit, but have specified stiffer springs in the rear, it seems most Cosworth owners prefer there cars to squat for grip where as I prefer it to be stiffer to aid traction loss (when required) ;D Good plan with the compression struts. Made a massive difference on my 24v. I went from not qualifying in the BDC, to qualifying 2nd after it was converted! Who you get the kit from? And the ARB kit? I just went for crazy spring rates on mine as I didn't care about comfort.... Would quite like to give my Cossie the same treatment. With camber and caster adjustment, I'm hoping the car will handle and drift really well. The Compression struts, Adjustable TCA's and Top mounts are all Compbrake items www.compbrake.com/The ARB kit came from Rally Design £95+vat. I went with the 10g tube. www.rallydesign.co.uk/product_info.php?products_id=7196The kit does require a fair bit of work to fit: 1. The brackets need to be welded to the chassis legs 2. You need to make some or adapt some drop links 3. Even with the adjustable TCA I've got. There is no facility to mount a drop link to the arm or shock, so that will need fabing. It would appear Reyland weld a mount on to the outer part of the TCA. Like this.... Unfortunatley my 90amp mig isn't up to this so I'll probably get someone else to do it.
Last Edit: Dec 3, 2012 10:23:46 GMT by Robinxr4i
Nov 22, 2012 18:00:39 GMT
"I can not stress this strongly enough: THIS SIERRA IS A KEEPER!" I'll believe that when i see it! Great work mate, it sure does look like you are doing things properly this time with lots of new shiny bits! Guy
AB car pix
Car mag' snapper
Nov 22, 2012 18:36:05 GMT
Check the lengths of the comp' struts when you get them.... mine were two bloody different lengths!
1979 Chrysler Horizon 1.3 GL 1980 Ford Granada 2.8 Ghia 1985 Ford Sierra 3dr 1985 Ford Escort Mk3 1988 Ford Sierra Sapphire Cosworth 1989 Ford Escort 1.3 Popular 1995 Volvo 960 1996 BMW 525i 1998 BMW 323i 1999 BMW 530d 2003 BMW 530i . www.facebook.com/ABCARPIX
Nov 23, 2012 16:28:07 GMT
"I can not stress this strongly enough: THIS SIERRA IS A KEEPER!" I'll believe that when I see it! Great work mate, it sure does look like you are doing things properly this time with lots of new shiny bits! Guy Good to see you on RR mate, hope your fleet of Lancia's is all good? Yeah hopefully "doing things properly" will be this Sierras watch words lol! Check the lengths of the comp' struts when you get them.... mine were two bloody different lengths! Crickey! I'll check them next time I'm at the unit, I've heard mixed reviews on Compbrake stuff, the problem is getting hold of adjustable Sierra arms isn't like Nissan stuff where you've got several different suppliers to choose from!
Nov 23, 2012 16:29:49 GMT
Copey
Nov 23, 2012 16:40:55 GMT
look well on the wheels, can't wait to see em fitted
not sure on my offsets though, can't remember what the backspace was on the mondeo steels so cant work it out i am afraid
Nov 23, 2012 16:46:55 GMT
I'm liking this Dude. I'm liking this A LOT! Unfortunatley my 90amp mig isn't up to this so I'll probably get someone else to do it. Can you wait until the weekend of the 7th-9th? The offer is there
Nov 24, 2012 10:01:40 GMT
Unfortunatley my 90amp mig isn't up to this so I'll probably get someone else to do it. Can you wait until the weekend of the 7th-9th? The offer is there Excellent, thanks Bruce I'll bring them with me ;D Right boring stuff first, when I picked the car up the oil was quite a bit over maximum and on the drive back I could smell a faint coolent smell (might be my imagination TBH), but anyway knowing the form that twinks have for headgasket woes I thought the worst and imagined a sump full of coolant. Thankfully this wasn't the case and it was just over full. However the sump nut was a bit of a nightmare, it was pretty tight and had obviously not been replace recently, so was pretty munched up. Nissan wheel nut and MIG welder to the rescue! Spot the difference...... Now on to the fun part ;D Annoyingly due to my mates having an addiction to cheap S13's (there are 4 of the bloody things at the unti!) I can't get the Sierra out to take better photos. Still I'm really happy with the fitment, just needs lows and a bit of arch rolling and camber to sort!
Copey
Nov 24, 2012 16:59:11 GMT
Sweet!! Can't wait to see better pics, looks like they suit well man!
Nov 24, 2012 17:04:39 GMT
Looks promising! Design suits the car.
What are you're planning with the arches? Or will it have more camber?
Click picture for more
Nov 24, 2012 21:22:28 GMT
What are you're planning with the arches? Or will it have more camber? I plan just to roll the arches a little, Sierra gain loads of camber at the rear when lowered, and the adjustable TCA's and eccentric top mounts should allow me to dial in enough camber on the front to get them to tuck in without having to flare the arches (well that's the plan). Plus generally for drifting you'll want to run a bit more camber up front than a usual road or track setup.
Nov 25, 2012 19:09:16 GMT
Awesomeness!
rysz
Nov 25, 2012 19:25:46 GMT
Nice one Robin, I really hope to see this at some point! Any engine plans?
Rysz.
markbognor
Club RR Member Number: 56
Nov 25, 2012 20:38:38 GMT
Out of shed pics. STAT!
Not at the moment, pretty happy with the performance. Power wise it feels much stronger than the last twink and V6 I had! Just want to get the handling spot on. Not until the suspension is on Which hopefully won't be long as these have just turned up ;D Also thanks to Copey's for his info on the Scorpio rear ARB. Unless you've got a V6 or Cosworth model rear anti roll bar wasn't an option, but is a relatively easy fit. The Scorpio one looks to be the thickest bar and has the added advantage of being cheap as it doesn't incure Cosworth tax I found one on eBay for a bargain £16 delivered, so that's on it's way too. Not sure if I'm going to have enough time before Christmas to fit everything.
Last Edit: Dec 4, 2012 11:47:22 GMT by Robinxr4i
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Copey
glad you have sourced a rear ARB, they make a hell of a difference and also, you git!! want coilovers for mine eventually, but they are all so expensive! can't wait to see how it sits mate, will look awesome!!!
I love how this is going...I also have coilover envy....
This is awesome! Loving the stance. It looks angry!
Went to A52 this weekend with my adjustable TCA's, as Bruce had kindly offered the use of the awesomely powerful Porta Mig to weld on a drop link mount. After a quick shuffle around in the nuts draw I found two deep M10 nuts with inbuilt washers which fitted the bill. Ian aka BIAS later informed me they are VW transported seat mount bolts. I attacked the TCA with a flap disc to provide a nice clean surface to weld to and offered up the nut. Bruce then did the honors and welded them on. Thanks to Bruce for his help
