scmick
Aug 24, 2012 20:30:01 GMT
Seen here partly buried in junk in my garage... 1200S coupe, one of the 6 right hand drives made (5 still exist in the UK SIMCA club but none are on the road). Last on the road in '77 but in those 10 years managed to rust pretty bad round the arches and sills... as you's expect from a SIMCA 1000 floorpan with an Italian coachbuilder's body... double trouble in the rust stakes. Mick
Last Edit: Oct 24, 2012 10:47:16 GMT by rmad
scmick
Aug 24, 2012 20:39:29 GMT
LHD even rustier 1200S I picked up for spares for the RHD car which I'm rebuilding more or less as original. Should be enough left of this one then to make a seriously low, stripped out trackday creation, probably with Honda power.
scmick
Aug 24, 2012 20:53:23 GMT
Plenty of rust..!! have now rebuilt this side using adapted sill for 2 door SIMCA 1100....
scmick
Aug 24, 2012 20:58:57 GMT
Rear arch now done with help of what i cut off a Samba front wing to fit big arches.... It pays not to throw anything away..!! !200S coupe had a 1204cc engine running on twin Solex 36PHH carbs (later used on 1000 Rallye 2) that turned out a (lively for its time) 85bhp. A bonus with the RHD car is at just 80000KM, it runs really well. Engine in the other car was a later 1294 which we resurrected and it went on to power my green 1000 and now the 133. Mick
barrett
Plastic cars with metal doors BEST
Aug 27, 2012 13:31:11 GMT
So much want for these things. Still, rather you than me looking at that rust....
Somebody find me a Watling. ÂŁÂŁÂŁ waiting! (Seriously, I want a Watling. Help me plzzzzz)
Aug 27, 2012 16:19:13 GMT
Great car, but I'm not sure, how much I like these retro digital images.
scmick
Aug 28, 2012 21:22:00 GMT
Other side ready for work to start. rear arch lip just broke off as it was a mass of rust & filler. Will cut inner & outer arch back to good metaal (there is some...!!) and seam weld them together before grafting 'Samba' outer arch on as other side. Sill area looks at least as bad as other side...!! Mick
Llewelyn_
Hi everyone :)
Aug 28, 2012 21:33:20 GMT
Is it me or does the front end resemble a fiat spider?
"Back off man, I'm a Scientist" - Dr. Peter Venkman
scmick
Aug 28, 2012 21:47:02 GMT
There is something of the same lines. Probably some of the same teams had a hand in both designs. For the 1200S, I believe the SIMCA 1000 floorpans were shipped off to Italy to have the bodywork done by Bertone's guys.
Llewelyn_
Hi everyone :)
Aug 28, 2012 21:48:52 GMT
It looks superb mate, I can't wait to see the progress
scmick
Aug 28, 2012 21:51:31 GMT
Back in '67, a SIMCA 1200S Coupe cost new, in the UK, twice the price of a top of the range SIMCA 1000 Saloon that it was based on. Probably explains why very few were ever sold over here.
scmick
Aug 31, 2012 22:13:30 GMT
Have found a couple of photos from before I sarted work on the RHD car.
scmick
Aug 31, 2012 22:22:16 GMT
1204cc engine on twin 35PHH Solex carbs before it was removed for work on the rear end. Runs well after 80,000km and hardly being used since 1977. Ebay bargain unused Stainless exhaust trial fitted. Mick
scmick
Oct 22, 2012 21:54:48 GMT
Finally got back to work on the 1200S this weekend. Rear subframe complete with suspension and gearbox had to come off for derusting and allow access for welding. Pleasant surprise was all 6 mounting bolts came out cleanly... not always the case on SIMCA 1000's, often the captive nuts break out or even a chunk of the chassis leg comes with them. I can now remove fuel tank which lives above the subframe. It contains some 'stuff' that was once petrol back in '77 when the car was last on the road. Mick
scmick
Oct 22, 2012 22:00:01 GMT
Another shot of rear suspension removed. @67 1200S was first rear engined SIMCA to use 'later' semi trailing arm rear end with more joints in driveshafts. Earlier cars (from '61) had a cruder swing axle set up ...same as on my FIAT 133. Will have to check out subframe... from experience on 30+ SIMCA 1000's. they rot in the corners of the lugs where the trailing arms mount. Mick
scmick
Oct 23, 2012 22:38:41 GMT
Rear subframe out with suspension and gearbox. Looks very rusty but attack with chipping hammer sowed it's still remarkably solid, just needin minimal welding. Now I can get rear end of car high in the air to get on with welding in comfort. Mick
al67
Lovely looking car... A Renault Caravelle front/ Alfa 105 Coupe middle/ Alpine a110 rear!! Sweet. al.
Oct 24, 2012 11:20:23 GMT
Great car this! Can I ask, what camera are you using?
mjd
Oct 24, 2012 12:08:03 GMT
Love the car, +1 for the camera enquiry Have you made a life-size replica out of Lego and taken pictures of that?
scmick
Oct 24, 2012 14:49:06 GMT
Camera is a Kodak Easyshare M863. Take the point about the resolution....my fault, not the camera. I put these shots on the simcatalbotclub forum before this. I had to reduce them in size to put them on there...I messed up somewhere in that process. I'm handier with the spanners than the keyboard...!!! Hoping to get the 1200S welded up and together for early next year as I've got the other coupe and my SIMCA/Talbot 1100 pickup to finish then. Mick
