Hi Jim Great progress and nice work! Two remarks. I do not think the distributor with the amplifier on the outside is an SD1 one. I believe this is a Range Rover or LandRover one. This does not matter as the one you have are better. You could consider to fit the amplifier on the inner wing as these can fail due to high temperatures. On late Land Rover, the amplifiers were factory fitted on the inner wing On the picture beneath the distributor on the LH is the SD1 type and this requires a ballast resistor. It could be that your amplifier is no longer working and non Lucas ones are avaiable for around 20 Euros. The vintage areoplane side shows ways to check your ignition. I would not advise to buy a Powerspark ignition. I did that and it lasted 2 years and parts are not interchangable with the Lucas distributor.
Another remark i have is that i believe that your fuel pump is missing a wire. When you crank the engine with the starter, the fuel pump should also work because there should run a wire from the additional connection on the starter solenoid(also used to bypass the ballast resistor for the coil) to the fuel pump which supplies power to the fuel pump when cranking and when there is no oil pressure. Keep up the good work! Peter
Hi Peter, its definitely the right dizzy. Real late SD1's had that type of dizzy and the loom has the correct multiplug for that amplifier at that location. Think its just because its such a late car. They probably were the same as Land Rover / Range Rover ones. Nice to see them taken apart like yours. I got scared by the 'do not remove cover label' so I didn't get into the guts of the thing. I might take apart one of my old ones to see how it works. Only just didcovered that you can have 2 Lucas 35dlm8 Dizzy's and yet internally they will have different advance curves for sd1 or range rover???
Hi Jim,
If your loom has the correct multiplug in the loom then it must be a factory fitment. I was not aware of that and i have a BL WSM and that only shows the left type distributor. It might be worthwhile to fit the amplifier on a heatsink on the inner wing.- Its hard to believe that these amplifier get cooled in their current position.
Its not a big deal to open these. What i noticed on the type of distributor you have is that the wheel with the 8 notches is rather heavy and it had some clearance on the connection with the shaft which would influence the timing
Peter
Ive got this week off work to try and get as much done on the car as possible. Sod's law I have a heavy cold, which is making all of this much harder work than it should be. I have done loads of stupid little time consuming jobs, but many of them don't warrant taking photos, so I haven't bothered. I decided that next time I start the car, I should have as much 100% finished as is practicable. So I went back through the throttle linkage and made sure everything was adjusted properly. Although it was mostly there, I had cut a few corners and not fully buttoned things up. To help in this process I used this excellent video. It is an original Austin Rover video on how to tune HIF44E carbs. Very handy. First important thing that i had forgotten to do is to bridge the terminals on the engine coolant temp plug. That tricks the car into thinking its hot, so it returns the idle jacking pins and should remove the choke. Then I went right back through the fiddly throttle linkages, connecting rods, lost motion shafts etc etc. Fiddly and time consuming. I also readjusted the main jet heights. When I first rebuilt them I read in the Des Hammil book that the jet should be 1mm below the bridge. So that's what I did. However, the Austin Rover Video and workshop manual says to set the jet level with the bridge and then do 2 turns clockwise on the screw to lower it. That actually gives about 1.8mm below the bridge, so much richer??? Anyway, that's where it is now. Also filled the dashpot dampers. In this photo you can just see the idle screw, the adjustable pad for the cold running jacking pin, and the adjustable pad for the lost motion shaft. All very fiddly. Then I removed the dizzy again and fitted my new vacuum advance unit. Also fitted a new coil as I randomly lost spark last time I was trying to run it. Then I removed the coolant thermistor and ambient air temp sensor and checked they were doing what they were supposed to at various temperature by comparing the changes in resistance with the tables in the workshop manual. All looking good. Then I continued the laborious task of checking continuity between the various pins of the ECU loom plug and the loom in the engine bay. All ok apart from some slightly dodgy resistances to the stepper motors, but ill just wait and see what happens with those. Might do another check tomorrow. Got a bit fed up this now! ECU and plug Lastly a slightly more fun and yet even more fiddly job. Rebuilding the Police switches again. I took more Lucas/Jaguar switches apart for their internals and fitted my Police specific lens'. Full set of Beacon, Horn, Police and Stop. Trial fitted into the heater vent surrounds as original
Oct 10, 2018 16:16:56 GMT
Was not aware that the SD1 came with carbs and ECU. Have never seen one and it is not mentioned in my Haynes or BL WSM. It must be quit rare.
Peter
Oct 10, 2018 16:25:47 GMT
Got up early this morning to continue playing with the Police switches. After the paint had dried, I mounted them on the air vent trim panel as original. Then offered it up to the dash. Looks good. Ive not done the final fit yet as I want to make sure all the wiring is correct first. Just before lunch I collected my repaired radiator. Port all soldered/braised back in properly. I can recommend Steve King at Regal Radiators. Knows his stuff and very reasonably priced. Here is the website. regalrads.com/I put the rad back in the car, refitted the fan shroud and filled up the cooling system. I also fitted a new ignition amp to the dizzy. This is a proper job two pin one I got of Kev Clark in the SD1 club. Thanks Kev. With the dizzy in and fitted, nothing else to do but start it! I was bricking it, but after a few cranks, it fired up. Took a while for the lifters to pump up, and ive set the idle too low, so it stalls if no throttle on, but sounds real healthy with a nice burble. Stainless system sounds meaty! I ran it for 20 mins at 2000 rpm which is recommended to break in the cam. Apparently running at idle is a big no no. I don't actually know the engineering reasons behind this, but fairly well documented online. Here is a video of the car running. I made a longer video, but MovieMaker ballsed up the sound, so this unedited short clip actually gives a better representation of the V8 loveliness.
Oct 10, 2018 17:10:12 GMT
Glorius
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
Oct 10, 2018 17:41:35 GMT
Awesome!
Oct 10, 2018 18:19:19 GMT
Well done Jim.
820
Oct 10, 2018 18:50:37 GMT
Well done, sounds nice, a Rover V8 without catalysts, I could almost smell the hydrocarbons
Oct 10, 2018 20:15:16 GMT
Great success is right ...well done .
That sounds nice and promising!
Well done, sounds nice, a Rover V8 without catalysts, I could almost smell the hydrocarbons Lol, mine once set off the carbon monoxide alarm i have in the garage. With the garage doors open.
jamesd1972
Club RR Member Number: 40
That’s why he’s all light headed - not just the joy of a running engine after a fantastic rebuild journey! Love it James
You sound rather pleased...... Well done mate.
Thank you all. Work continues. Spent the last couple of hours fixing the hazards, side repeaters, adjusting brake light switch. Got an irritating problem with the reverse lights though. When the switch is closed (car in reverse) I get continuity at the switch terminals. If I follow the wiring up to the connector in the engine bay, I get the same. SO switch is ok and closing. I f I check the loom side of the engine bay multi plug I have a 12V supply. If I use a power probe to put 12V into the multiplug the reverse lights illuminate. If I use a jumper wire to go from 12V supply in multiplug to feed to the rear lights they come on. However when the plug is reconnected they don't work? So then I cleaned up the plug terminals and closed them up a bit to ensure they make real good contact. Guess what, still not reverse lights!!!? Anyway, in better news my number plates arrived. They are as close to the original as I can get. They have the correct curvy '8' and funky looking number '2's. The 'G' isn't quite correct but pretty good. Some SD1's had tall rear number plates, but in the photographs of its sister cars, they all appear to have standard height rear plates, so that's what I have ordered. Just need to buy some plastic number plate screws and fit them. Old New
By the way, massive thanks to Fancy Plates who did these ultra fast through their website. Unbelievably good services. I recommend highly. www.fancyplates.com/
Oct 11, 2018 13:20:52 GMT
Thank you all. Work continues. Spent the last couple of hours fixing the hazards, side repeaters, adjusting brake light switch. Got an irritating problem with the reverse lights though. When the switch is closed (car in reverse) I get continuity at the switch terminals. If I follow the wiring up to the connector in the engine bay, I get the same. SO switch is ok and closing. I f I check the loom side of the engine bay multi plug I have a 12V supply. If I use a power probe to put 12V into the multiplug the reverse lights illuminate. If I use a jumper wire to go from 12V supply in multiplug to feed to the rear lights they come on. However when the plug is reconnected they don't work? So then I cleaned up the plug terminals and closed them up a bit to ensure they make real good contact. Guess what, still not reverse lights!!!? Anyway, in better news my number plates arrived. They are as close to the original as I can get. They have the correct curvy '8' and funky looking number '2's. The 'G' isn't quite correct but pretty good. Some SD1's had tall rear number plates, but in the photographs of its sister cars, they all appear to have standard height rear plates, so that's what I have ordered. Just need to buy some plastic number plate screws and fit them. Old New Jim - If you want self tapping type number plate screws with the plastic caps coloured for back & front just pm your address to me and I will send you a set FOC - I have a boxful upstairs in the stores that I will see me through until I hang my boots up - Chris
Last Edit: Oct 11, 2018 13:24:53 GMT by Deleted
Oct 11, 2018 13:24:08 GMT
Ho and by the way - 'No Pressure' to get the car completed the NEC show is only 5 weeks away !
Oct 11, 2018 17:09:18 GMT
Ho and by the way - 'No Pressure' to get the car completed the NEC show is only 5 weeks away ! Thanks very much for the offer of screws but I bought some this afternoon! Yes car has to be ready for the show. It will be on the SD1 stand again.
Oct 11, 2018 19:01:26 GMT
Ho and by the way - 'No Pressure' to get the car completed the NEC show is only 5 weeks away ! Thanks very much for the offer of screws but I bought some this afternoon! Yes car has to be ready for the show. It will be on the SD1 stand again. there's always someone worse off than you, i'll be the one on the mk2 astra stand using black pigmented polish on my bonnet to fill the stone chips
Last Edit: Oct 11, 2018 19:01:38 GMT by darrenh
