Nov 17, 2006 22:15:00 GMT
I'll be doing a list of things on the mini
Including....
Fit new wheel bearing at the front.
Wire in a new "accessory" loom to power the stereo and fag lighter for the sat nav, as well as any other goodies I fancy popping on it..
Fitting group 2 wide arches to said car.
Cleaning fiesta calipers (cheers for them Sammyboy) for mini disc brake conversion.
Starting work again on the brown van.
*possibly* driving to Alton Towers area to get some more bits for the bus.... but I may leave that for another weekend.
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
Nov 17, 2006 23:02:40 GMT
Busy boy! ;D Do you ever get everything done that you planned to? I never do! Hope it all goes well for you anyway.
Nov 17, 2006 23:24:20 GMT
Busy boy! ;D Do you ever get everything done that you planned to? I never do! Hope it all goes well for you anyway. I got a massive bulk of work done on the van really quickly, then my health let me down, so I took a break. Getting back into things again now... slowly
Clear, clean recarpet garage,get trailer into backyard, find rear bevel drive seal for the 1150GS, fit that, MOT sometime. Clean Aprilia Tuareg and get it onto the"Bay" Unpack boxes that I packed 5 years ago before moving to the UK...... ooopps. Make serious space for a winter project inside the garage.
I'm going to pull my third (and hopefully final) plenum from the mould today, i really hope its worked this time!
If it has then i will be putting a second layer of carbon on the inside, reinforcing the flange area, and then drilling eleventybillion 4mm holes for the stainless allen retaining screws.
The inlet manifold should also be finished by the end of the weekend, and that means final wiring and bits and bobs, then ......... start up! UH OH!
J
i got the mk3 2door of darrens to paint today then tomorrow i'll be doing a few odd jobs on the estate fit new flowmater back box fit a new alarm as the other one has decided to go all wierd and find what the annoying rattle is thats coming from the alternator then i'll do some more on the van hopefully get the new front hubs and brakes on and do some of the ignition wiring
qwerty
Club RR Member Number: 52
At work till 4 When I get in I'm gunna move my pannels out of the garage and into the shed to stop the parents winging. On Sunday I'm gunna finally get around to checking the thermostat and coolant system. Might even flush it out and refill it. If the carb and fuel pump I'm awaiting arrive today i'll fit them. Then I can start the re-furb of my original carb. ;D
Nov 18, 2006 10:18:44 GMT
Not going to get anything done at all Beautiful weather today but I'm stuck inside working, no doubt it will be lashing it down tomorrow and she'll be wanting to be amused. I actually sense the Pop never making it right at the moment, I'd forgotten that jobs take up all your time which is depressing.
Nov 18, 2006 10:34:03 GMT
Just about to go and pick up some paint. Prepping and hopefully painting some panels on a rover 220 if I can get a bit of heat into my garage to drive the moisture out. Fit a radiator and replace a wheel stud to the same. Might be going to have a look at a Senator at some point and see if it has the engine I am wanting for the monza. Then if the panels are painted I will be refitting them to the Rover and getting it ready to sell. Pretty un-retro weekend
Nov 18, 2006 13:36:32 GMT
curse of posting that you'll get stuff done, woke up today feeling awful Took the old arches off the mini and started to cut the new ones. Realised I've left a load of tools at work, including the ball joint splitter, the hub puller and the rivet gun.... That'll be an archless mini for a few days then And the wheel bearing is gonna wait too..., early brakes mean I need some bits which I just don't have here... I'll clean the car later... lol, it'll get done Monday by my dad while I'm at home recovering from op number 2 Ah well, at least the revolutions look farking awesome and it still goes nice Oh, better add, gonna do the wires that I threatened to do as well.... nice easy job
Nov 18, 2006 14:18:18 GMT
Grouting the bathroom floor,... wishing I had enough money to do stuff to the Datto,.. Oh well,.. not going to bankrupt myself this time, so it'll all jsut have to wait
Nov 18, 2006 14:26:55 GMT
I've just gone out there and made some holes in the car, only to realise I'm low on rivets, so can't actually fit the arches (the only rivets I have are too short!) but, it's gonna look cool with the arches on gonna pop into hellfrauds tomorrow morn after Sarah kicks me out of bed and purchase the ones I require, then the fitting of the arches will commence.
Nov 18, 2006 14:35:17 GMT
Well, Garage cleared and repacked more sensibly. Now a shower, then to the skip to offload loadsa tut from said garage. Then off to ladeee friends place for DVD and dinner. Here's the garage floor space now....... enough space for a toy I would say.
Nov 18, 2006 16:44:51 GMT
Nice one grizz. Plans for filling space? TTIUWP I'm pleased. I got 1/2 hour outside under the car and tried a couple of things. Amazing what you can fit into such a small time frame if you don't have any time to do it. Jacked up the engine and the mounts are fine, they are just very soft rubber but they haven't failed at all. Got under the car with it in gear and rolled it back and forth and there's less play in the drivetrain than my Anglia which can only be a good thing. The front bearing is a little slack and noisy but it sounds dry and there's a nice grease nipple on it so I reckon a good few shots of gloop should quieten it. Can't for the life of me work out how it comes off so probably just as well. Fired up the engine again and drove it about the carpark. Feathering the clutch it is fine and it's only when the car starts to move that it starts to shudder. I'm sure it's not as bad as it was before either so it might well be curse word on the flywheel causing it. Engine died quickly and wouldn't start again so I hoiked off the fuel line and there wasn't anything coming down the pipe. Again I see this is a good thing because is means all I have to do is replace the pipe, stick in a filter and job is fixed. Future looks bright for once. All good because I won't get to play with it until next weekend now.
Nov 18, 2006 16:52:17 GMT
Well I took the thrid plenum out of the mould this morning, and it worked dagnammit! WoooooooOOOoOOOooOOOOoOoOooOOOOOooo carbon bits for la impy So tomorrow I'm going to crack on with the inlet manifold and start thinking about the wireing for the ECU injectors and sparks, I can smell that raw fuel on first start up guys. Talk about exciting! Ill get a full write up tomorrow evening. J EDIT - sounds very promicing Jonny, i hope it all goes smoothly And cappuchiniiononnsooo cruiser, hope all is well mate, min sounds ace
Last Edit: Nov 18, 2006 16:53:26 GMT by Blown_Imp
Nov 19, 2006 18:29:33 GMT
Nov 19, 2006 18:37:58 GMT
PHHWOAARRRRRRrr.... !!!!!!
Thats so HAWT !!
[glow=red,2,300]Well done mate..... She's a Honey.[/glow]
Nov 19, 2006 19:05:33 GMT
Grouting the bathroom floor,... wishing I had enough money to do stuff to the Datto,.. Oh well,.. not going to bankrupt myself this time, so it'll all jsut have to wait My floor looks ace ... And I'm back into smoothing the engine bay of the datto as an idea,.. just working out where to start... Nightmares! That looks ace... My dad will be needing to spray my old VW camper at some point, will it be possible to call upon the use of your space and maybe expertise at that point?
Nov 19, 2006 19:21:03 GMT
Grouting the bathroom floor,... wishing I had enough money to do stuff to the Datto,.. Oh well,.. not going to bankrupt myself this time, so it'll all jsut have to wait Nightmares! That looks ace... My dad will be needing to spray my old VW camper at some point, will it be possible to call upon the use of your space and maybe expertise at that point? depends when it is realy theres rarely much space space in there i share with other club members but i'm sure we could sort somthing
Nov 19, 2006 19:28:40 GMT
^^^^ Nightmares that looks ace.
Been doing a bit of painting myself not upto that standard though but its turned pretty well. Halogen heaters FTW ;D
