adi
Apr 12, 2012 18:03:50 GMT
Last Edit: Dec 10, 2013 19:31:33 GMT by adi
adi
Apr 12, 2012 18:04:49 GMT
Update o'clock! I've done a few bits on my latest GL, finally drilled and tapped the drilled out bolts on the centre caps, so they're now fitted making the car look a million times better. I've swapped the badged grilled for a debadged item, fitted rainbows, fitted the dishy suede steering wheel, osram nightbreakers with LED sidelights, new top rad hose, new heater panel that actually lights up, fixed the central locking and cleaned it I hadn't posted a pic of the PB lump, so here it is, needs some dressing and cleaning, however I'm not sure I'l bother as I really want an ABF in there... And lastly a little discovery I made today when I realised I've lost my autosol, so I found a replacement product to clean my tailpipes in Hobrite and a scourer! It took literally 2 mins to scrub the black curse word loose, then rinsed off with warm water, this is the result!
adi
Apr 12, 2012 18:05:54 GMT
Heater matrix time... The latter pic is where I'm up to, and my knuckles are SCRAPED! Not bad time though, got where I am now in just over 2 hours, I reckon I'd have it done in just over 2 hours Oh, and it would also appear my car has had a replacement scuttle panel welded in! Result edit; all done, heats up fine and no more steamed up windscreen when I try to de-mist! Took around 3 hours and thats including hoovering up, all those perished foam loom wrappings leave a fair mess!
Last Edit: Apr 12, 2012 18:07:48 GMT by adi
Apr 12, 2012 18:09:43 GMT
I know it's a bit late to tell you, but you can do the matrix with the dash in - mk2vr6.com/board/viewtopic.php?f=15&t=3560They are claiming it takes a whole day, but I did mine in about an hour without really knowing what I was doing
Last Edit: Apr 12, 2012 18:14:45 GMT by cobblers
adi
Apr 12, 2012 18:17:56 GMT
Oh I knew that anyway, but I've had dashboards in and out so many times before, it takes me so little time and made it loads easier so I did take it out. Really happy the heatings working all fine, the matrix was from a donor mk2 for the last GL, and it looked new when I removed it, so glad its still ok, would hate to have to change it again.
adi
May 19, 2012 14:53:26 GMT
Bit of an update on my golf. Still got it, still using/abusing daily, and still putting up with it! So, after the heater matrix fiasco, a few days later it started steaming the windscreen up again slightly, as you can imagine I was far from impressed. Then very soon after it over heated in traffic due to a now duff radiator fan, which caused the plastic coolant flange on the side of the head to distort and no longer keep water in my engine. So I replaced the flange, saw it was leak free, then although I hate using the stuff I stuck some radweld in it and touch wood so far I have no more steamy windows, lots of heat, and NO water leaks! Also in this time I changed a CV joint, but typically I now need one in the other side. Still in need of a rad fan, but keeping out of traffic Otherwise all has been good, it does desperately need some discs/pads all round for the upcoming MOT though. In cosmetic news, I got myself some flyeye kit. Can't recommend it enough, cost me just over a fiver posted for enough to do my headlights (and still have a bit left) and come with a posh scalpel, a nice little applicator tool and a letter stating they're vosa approved in case of a jobsworth copper! Have a pic Also jetwashed my engine bay a few weeks ago, its actually nice to do work on it without getting covered in all manner of curse word!
adi
OK so a small update, just spunked about 100squids on all new brakes. Went on the direct gov site and checked the MOT history, and was a little bit annoyed to find it had an advisory last year on pitted/rusty/worn discs/pads all round, and they haven't been changed since, bare in mind the MOT is due in about a month! So here is my collection fresh from ebay... So I need to get these on and bedded in nicely before the MOT. Could really do with selling this before spending anymore on it... Next update will probably be next month after the MOT, depending on whether its good news or not...
Last Edit: Jun 8, 2012 18:07:19 GMT by adi
adi
Jun 10, 2012 14:21:42 GMT
Bit of a premature update. I've almost lost mojo with this and almost considered just buying a cheap driver shell and breaking this, but I'm soldiering on. As soon as I got the car in the air I discovered this... Yes thats a very rotten subframe, right next to a wishbone mount. Very safe. NOT. So I carried on and started on the rear brakes. 1st one was the drivers side rear, which I was already aware of it having a stuck handbrake that didn't work. 1st disaster was me trying to wind the bearing into the disc with the hub nut. Bad idea. I stripped a few threads off the nut. Poo. Luckily I managed to bash the bearing in with a hammer and socket, and there was enough thread left on the nut to tighten it to my satisfaction, plus theres the split pin for good measure, so I'm just about happy with that. So onto the other side. I lost my 8mm allen key socket, so removed the other side carrier with a torx bit which was ok, but the passenger side didn't appreciate this. And rounded them off. Double poo. So I moved onto the fronts which went smoothly, apart from ebay sent me the fat pads for solid disc equipped cars, so the pads don't fit. I stuck the new discs on with the just about usable old pads until I get hold of the correct ones next week. Anyways back to the stuck off handbrake on one rear caliper. I managed to sort of free it off, but it now works but sticks on and won't return. I've moved the return spring round a bit to no avail. Poo again. So a new caliper will be required. As I've left it I now have new discs on front with old pads, and one new rear disc and pads. Not ideal, but its drivable again until I can sort it all out ready for the MOT. Have some useless pics of my rear brakes. Thats the old passenger side rear, with the dead carrier bolts. And thats the new rear set up with the none working handbrake. Now I'm off to sulk/kick the curse word out of my car.
adi
Jun 10, 2012 18:40:25 GMT
adi
Jun 12, 2012 14:59:00 GMT
So today I got the subframe fixed. To remind you all this is the mess I started with I ground out as much of the rot as possible (its a really difficult place to get a grinder into!), then I made up a repair piece and bent it to shape. It looked like this Then I welded it in a flush as possible, the welds don't look so good at the bottom, but thats because I ran to welds to ensure I had good penetration in both the subframe and the repair patch. It looked like this I then gave it a few coats of zinc primer, then re-assembled the suspension. I'l brush on some paint at a later date. Its all good now apart from the knackered wishbone bushes I discovered but at least its flexing there and not in my subframe!
Last Edit: Jun 12, 2012 16:59:31 GMT by adi
adi
Jul 16, 2012 18:19:20 GMT
Last Edit: Jul 16, 2012 18:22:16 GMT by adi
adi
Jul 26, 2012 20:18:09 GMT
Well I guess no-ones following this but I'l update anyway... I took delivery of this rotten heap o curse word today. I swear I've never seen a golf with so many holes! Unfortunately due to being made redundant next week I had to make do with whatever donor was available locally and cheaply, so no ABF Here's the tall block 2E and other curse word that'l end up in my mk2 280s and widetrack... oh go on then
Mike
East Midlands
Jul 26, 2012 20:35:47 GMT
I might have missed it, but why'd you take the PB out?
adi
Jul 26, 2012 21:04:10 GMT
Because the intention was to get a 16v mk3 as a donor, and a mate in Lincoln had a dead GTI and desperately needed an engine, so I took it out a bit prematurely to help him out.
adi
Well quite a bit of stripping of the donor car has happened today, mainly because travellers found where my garage was and have seen the donor car outside my garage, and in case they come and nick the donor, I want to make sure I have what I need. First of all I had a look through the history of the donor, nearly a FSH, tax discs back to 1997 and this... Who would pay that for a mk3 golf? haha. I had some difficulties in removing the rolling mk3 front end, as some numpty had snapped a bolt, tack the half of a bolt on, and run a curse word bit of weld between the subframe and chassis!! This is what happens when you attack it for an hour with a lump hammer and a chisel Then I dragged the running gear out Then pulled the widetrack rear beam out Then dragged the mk3 out the way with the trusty laguna and ended up with this Made room under the mk2 front and ended up with a big pile of golf curse word This is the mk2 bay before I took the old 1.8 GTI downpipe off Then me and a mate moved the mk3 stuff in Stripped this rats nest out the mk3 Thought it was a good time to call it a night, cover up the mk3 and put it all away Nest up, removing the mk2 loom, and bay cleaning!
bstardchild
Club RR Member Number: 71
Great work
adi
thanks, its been a productive day
I second the great work comment! Bookmarked....looking forward to updates
'86 E30. '86 E28. '92 E32. '97 Laguna. '98 March. '00 A4. '05 Focus.
adi
Will do my best. What the hells happened to my thread title though? Someones edited it and they've got the year of the car wrong!!! Gonna have to sort that...
is the donor's steering wheel going spare ?
