Sept 11, 2004 18:26:33 GMT
Last Edit: Sept 11, 2004 18:27:16 GMT by WillCarter
Sept 12, 2004 10:40:43 GMT
Now if you put that in a 740 saloon you'd have some stealthy retro car, mabye I'd upgrade the brakes too and chop down the springs and put the wheels off an 850 T5. Otherwise it'd be fine standard. The rear wheel drive Volvo transmissions are more than over-engineered, they've been fitted to V8 hot rods running in excess of 350 horses, a lightly tuned T5 would be no problem.
"He's not the messiah, he's a very naughty boy!"
Sept 12, 2004 19:39:23 GMT
That should go in a P1800 !!!
----------------------------------------------------------------------- Owning a trans am is a sin, according to the pope.
Sept 13, 2004 12:11:04 GMT
I'd love to slap that under the bonnet of my dad's rat-look 760 estate (it's got moss growing on it!) but since he rarely goes more than 50 mph carting about batteries (and at the moment a display stand for Haynes manuals!) it might be a bit of a waste of time...
Sept 13, 2004 17:52:35 GMT
Might that not be a bit tricky to mount RWD? The throttle body and distibutor would be up against the bulkhead!
Sept 13, 2004 17:57:08 GMT
Might that not be a bit tricky to mount RWD? The throttle body and distibutor would be up against the bulkhead! Aftermarket throttle bodies and mapped distributorless ignition would sort that out but would cost a fair bit as well unless you're real handy on the lathe/soldering iron and p.c ;D
Sept 13, 2004 17:58:01 GMT
Those are in strange places on some Volvos anyway, and Volvos have unusually large, and very practically shaped engine bays as standard, so there would be plenty of space to move certain movable things around if they did get in the way. Another conversion gaining popularity in the US is the small block Chevy transplant into the 740, so that'll give you an idea of the engine bay you'd be working in.
Sept 13, 2004 18:19:54 GMT
I've found that the size of the enginebay isn't always a clear indication of what will fit. I fitted a Rover V8 into a big Datsun 280C I had which has a massive engine bay but it was really hard to get that V8 in there and make it clear everything. Yet I found a Nissan 300ZX engine (V6) would fit into a 1980 Sunny without any cutting at all! A lot of the time it's just down to luck wether a certain combo would work or not.
Would a FWD Volvo engine actually fit on a RWD transmission? I think if you were getting into the realms of needing adaptor plate, custom flywheel, as well as vcustom management etc, then it might be as well to go down another route such as modifying an existing RWD Volvo engine to turbo.
Then again you could always keep it transverse and mount it in the back ;D
Sept 13, 2004 18:27:47 GMT
The reason I was talking about converting the T5 there is because it's a bit of a legend among Volvo people that engine, and it has amazing potential. It's that engine that powered the BTCC winning 850 T5 estate in 1994, and in that car had 300bhp I think, so you can see the potential.
And I know what you are saying but a Volvo engine bay isn't just long and wide, it is a large an uncluttered space, and the bulkhead's well out of the way, as are the chassis 'legs' etc, and as I said, the Chevy V8 conversion is said to be relatively straightforward as far as putting 8 cylinder engines into 4 or 6 cylinder cars goes.
Sept 13, 2004 18:28:29 GMT
Would a FWD Volvo engine actually fit on a RWD transmission? I think if you were getting into the realms of needing adaptor plate, custom flywheel, as well as vcustom management etc, then it might be as well to go down another route such as modifying an existing RWD Volvo engine to turbo. Then again you could always keep it transverse and mount it in the back ;D Thats exactly how you can get carried away spending a lot more money than need be on a conversion like that, the best conversions are always the unexpected sucesses like the 300zx into a sunny or your prarie turbo Ed
carnut1100
If it's got wheels I like it!
Sept 19, 2004 11:55:43 GMT
I want a T6 in a 164 ;D I would follow that up with the new V8 that the XC90 is getting and stick it in a 264. Fun.................
They won't be restoring Hyundais in 30 years!
1970 Peugeot 404 1973 Volvo 164E 1979 Volvo 242GT
In the family, 1975 Volvo 245 1985 Volvo 360 GLT 1969 Ford Transit Mk1 1963 Humber Vogue Sports 1960 Morris Minor van
Sept 19, 2004 12:24:46 GMT
The V8 engine intrests me, it's a Jag engine really, isn't it? Still, with Volvo attention it could probably be a dependable engine. With any luck it'll inspire Volvo to go back to rear wheel drives and use the V8, but I've been hoping for Volvo to go back to rear wheel drive for a while now.
carnut1100
Sept 19, 2004 13:52:01 GMT
No, it's an all alloy super compact 60 degree V8 shich is unusual, and it has been designed to fit in Volvo FWD engine bays so it is very very compact. Heaps of grunt too. At the moment it will only be in the AWD XC90 and it won't be sold in Australia but it should be coming here in a year or so.
MWF
Sept 19, 2004 16:10:56 GMT
The T5 engine is good but the B200FT, B230FT and B23FT engines Volvo did seem to have a lot of tuning potential.
Sept 20, 2004 10:06:37 GMT
The T5 engine is good but the B200FT, B230FT and B23FT engines Volvo did seem to have a lot of tuning potential. That's because they are so unstressed!!
MWF
Sept 20, 2004 10:21:08 GMT
As soon as I saw the tuning potential of these engines I just had to have one. I will reserve my opinion until I have had a play tho.
Sept 20, 2004 11:25:06 GMT
How about a T5 Amazon slammed in satin black with big chrome wheels and limo tint windows and all the chrome on the body work black chromed? Bring the idea of the leadsled bang upto date?
Sept 20, 2004 19:42:04 GMT
That would definately work!
Sept 20, 2004 19:43:00 GMT
That was your 1000th post Rev!
Sept 20, 2004 20:32:37 GMT
I said that on another thread! I didn't notice till around 1005! It just goes to show that I spend faaaaaar too much time on this forum! Someone please take the internet off me before I damage my health! ;D ;D ;D
