Mar 21, 2012 21:57:45 GMT
Hello Retro Dudes I need a little advice on buying some steel wheels. There must be something already in existence, readily available. Any thoughts?
I'm looking for four 13" rims, PCD 4 x 114.3mm, 5.5" - 6" wide with a positive offset of between ET20 - ET30. Any condition
Can you help please? Cheers
Dez
Club RR Member Number: 34
Mar 21, 2012 22:05:11 GMT
13s are pretty much non-existant in 4x114. subaru justys have them, but they're pretty ugly.
kevfromwales
the conrod's REALLY out the block now!
Mar 21, 2012 22:07:21 GMT
b11 sunny have these, but not sure if they are 5 or 5.5" wide
can measure up next time I'm at the farm - they look like 13" k10 micra steels
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Brian Damaged
West Midlands
Club RR Member Number: 33
Mar 21, 2012 22:10:17 GMT
Standard Triumph 2000/2500 steelies are in 13" flavour.
Foxy
Making pink manly in the north!
Mar 21, 2012 22:11:11 GMT
I'm the handsome fella with the cheesy white specs or is that the cheesy fella with the handsome white specs?
Mar 21, 2012 22:11:37 GMT
Austin Maxi?
Mar 21, 2012 22:25:50 GMT
Cheers everyone. I don't care what they look like as I will be using wheel trims
The Doctor
Club RR Member Number: 48
Mar 22, 2012 16:22:23 GMT
every Toyota with disc brakes from the 70s has 13" steelies in 4x114,3. Old Celicas etc. etc. and i think the ETs of those are in the low 20s.
Mar 22, 2012 16:49:09 GMT
Some of the Daewoo's have them - I got 13" ones not long ago.
