bmboy
great age!
Can anyone tell me the differences between turbos used on diesel engines and turbos used one petrol engines? What I would like to know is if they are compatible or if they work differently. I have never had a car with a turbo so this is delving into the unknown. I have tried googling it but couldn't find a definitive answer. Your feedback is very much appreciated! Thanks, Barclay
Skoda Estelle 120l x3 Skoda Favorit Triumph Dolomite Mercedes-Benz 190E BMW 635csi BMW 528I Volvo 850 Mercedes-Benz 230TE Skoda 136 Rapid
The exhaust flow from a diesel engine, is at far lower temperatures than a petrol engine. As the only reason that the exhaust gas has increased in volume, is because it's been massively heated, deisel engines won't "flow" as much exhaust gas compared to a diesel. what does that actually mean in real-world use though? To accommodate the higher exhaust flow, the turbo for a petrol engine, will be much larger than a turbo meant for a diesel engine, of the exact same size. A petrol will usually only operate usually upto around 10psi of boost without spending lots of money (some even less!) whilst a deisel will regularly operate at around 20psi, straight from the factory. The boost pressure is essentially known as the "pressure ratio" (compressed pressure, vs atmospheric) and if you try to make a turbo deliver boost at less than half it's reccomended pressure ratio, it will do one (or more) of three things: 1) stall. The compressor isn't spinning fast enough, to deliver and contain the required boost pressure. The air ends up reversing, and goes through the compressor wheel the wrong way - stalling the compressor, and introducing LARGE loads through the turbo shaft, snapping the shaft is a large possibility. 2) Choke. You're trying to pass too much air through the turbo - it literally "chokes", as it can't pass enough air (ie: you're using too small a turbo for your flow levels) 3) Massive air heating. Being above "stall", but below "choke", but not at the required pressure ratio, will just mean the turbo is out of its efficiency range by quite a large amount - what this means for a turbo, is more energy just goes into heating the compressed air, rather than moving it. Also, the turbos have physically different cores too - as diesel turbos won' run anywhere near as hot as the equivalent petrol turbo, they won't have additional cooling capability that some large petrol turbos need to keep from overheating. One example of this, is a water jacket around the turbo core. so the main question is - are you trying to turbo a diesel, or a petrol?
bmboy
great age!
Wow thanks for that reply. That is pretty much everything I needed to know in a nutshell! I have the turbo for a 1.9 lancia engine and considered using it to turbo my 1.8 lancia petrol engine. I had not got any further than thinking about it and by what you are saying it won't go further than that!
So what you're saying is that for the diesel turbo to be effective, it would probably melt the petrol engine anyway!
yups! Lol, you can go the other way - and put a petrol turbo on a diesel..... but by the time it's on an engine big enough to make it spin up, the extra airflow it'll give is practically pointless! Tbh, shove the diesel engine in - much more fun than petrol
1.9 lancia diesel? likely to be an XUD9TE isn't it? so a K14, K17 or T2 most commonly, usually running at 1 bar.
bmboy
great age!
I had considered it but the diesel has 20hp less and a much lower top speed than the N/A petrol so whats the point? Thanks.
costs pennies to tune, if you fit a bosch pump you can run on veg oil, and you can get ridiculous torque numbers! The 1.9 XUD engine can easily see 160Bhp, and a peak of around 200Bhp, with only minor extra parts needed
What's the point of going above 70mph on the road anyway?
bmboy
great age!
costs pennies to tune, if you fit a bosch pump you can run on veg oil, and you can get ridiculous torque numbers! The 1.9 XUD engine can easily see 160Bhp, and a peak of around 200Bhp, with only minor extra parts needed What's the point of going above 70mph on the road anyway? Autobahns, track days etc! I don't know what the engine code is, I will check that out. Its from one of these; www.carfolio.com/specifications/models/car/?car=29590160bhp?? Keep talking?!
You will probably be aware, the XUD is a Peugeot engine. Search for 306 diesel tuning online, there is loooooooooooooooooooooooooaaads of info.
I've got Rovers.
for 160Bhp+, if yours already comes with a Bosch pump, just fit a decent FMIC, decent exhaust, up the boost a little, and up the fuelling That's it.... seriously to get about 180bhp, with just shy of 200lb/ft torque, you'll need a bigger turbo. Beyond that figure really isn't reccomended, they tend to fall apart in a rather vigorous[/b] manner
A Lancia won't have a Peugeot engine though. It's a Fiat based engine.
OVY871
Owner of Austin A35 Saloon
Club RR Member Number: 66
Turbos! Diesel to petrolOVY871
@ovy871
Club Retro Rides Member 66
That'll be the JTD engine won't it? Think thats whats also in the newer Saabs and if you get the Saab version you can get 230ish bhp and 500nm of torque (385lb.ft) just by plugging it into a computer (the TTid engine)
Depends on the age of the engine,it could be the older td that was in the tipo,for simplicity why not use the complete set up from an hf turbo or 8v grale,obv it isn't quite as simple as bolting on the bits though.
bmboy
great age!
Its a JTD engine it turns out. I think I will stick with the N/A petrol for now!
Damn, that's something I was thinking about looking into. I was thinking about adding a turbo to my classic Mini, but something small that spools low down just for the torque, not massive PSI and BHP. I was thinking something like a Renault Megane diesel turbo would be a good one to go for - plentiful in curse word yards at least.
Perhaps a rethink needed then...
Anyone know any modern(ish) turbo petrol cars with a turbo that will spool nicely on a 1330cc A Series?
1994 Mini Mayfair MegaJolted with BMW M3 seats; 1990 Volvo 760 D24Tic 16psi, more fuel, running SVO/WVO; 1965 Triumph 2000 Mk1 projects.. one day;
Appartently, the Volvo B18FT with a Garrett T2 (440 Turbo) can be upgraded with a turbo (T3) from a Volvo 940 Turbodiesel.
Click picture for more
ian - none, tbh. Totally different operating specs, for the reasons listed in my first post.
Ok, ignoring diesel's then - what Modern(ish) petrol cars could I rob a Turbo that would spool nicely on my Mini? Some take the Gt1725 but they are like a T3 - a bit big and laggy.
A good T2 will suit the mini nicely.
What kind of boost can you expect with it, and do you know what RPM it would spool at? Is there a more efficient modern version?
