find another 1.3 modern turbo, and slap it on. Would be perfectly suited Smaller than 1.3, it'll have less lag, but will severely limit power. Bigger than 1.3, you'll have the possibility for more power, but much more lag
Go VNT for less lag, base your turbo sizing on BHP your aiming for rather than capacity. Garret do some very nice variable nozzle turbo that can be had for peanuts on evilbay.
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
Cool, yeh I would be up for using a VNT one, they're great on VW TDi's.
Sorry, I'm not up with modern cars at all - do you know any modern petrol 1.3 (up to 130bhp ish) cars that have a VNT? Or do you know what more specifically I'm looking for on Ebay?
1994 Mini Mayfair MegaJolted with BMW M3 seats; 1990 Volvo 760 D24Tic 16psi, more fuel, running SVO/WVO; 1965 Triumph 2000 Mk1 projects.. one day;
VNT on a petrol, is asking for problems - as stated before, petrols run FAR hotter than dervs. To my knowledge, there isn't a single manufacturer who fits a VNT style turbo to a petrol engine, for good reason too.
If the vanes seize up (the extra heat will see to that rather quickly) you'll either be VERY lucky, and have them seize "open", and give very little boost. If you're unlucky, they'll "close", then stick there - making maximum possible boost, with no way of bypassing any of the exhaust. The turbo will overspeed like mad, and boost will reach normal derv pressures, of around 20-25psi.
Yes, they work on petrols - but don't expect it to be a fit+forget item. You'd be well advised to replace the compressor wheel with one suited to a petrol, and fit an external wastegate as an emergency backup - just in case the vanes seize.
Then there's the control method......
Mar 10, 2012 20:34:54 GMT
2005 onwards Porsche 911 has a VNT on a petrol engine, the first one I think!
I would say theres no problem 'in the real world' to bosh a suitably sized diesel turbo onto a petrol engine, though I defo would not use a VNT.
froggy
Mar 11, 2012 17:53:43 GMT
correctly sized a diesel turbo is no issue on a petrol engine , ive been running holsets for a few years with no issues ,diesel vnt isnt a problem other than figuring out a way to control the vane . i don't think you can have your cake and eat it though as the normal route is to use a turbo from a diesel motor at least twice the size of the petrol unit its going on and lag is the issue although top end power is epic . the vnt holset i was developing was perfectly happy making 2.5 bar and 550+hp with reasonable response low down
