anden
Go low or go home
Apr 27, 2014 10:34:24 GMT
cheers guys, yeah its in this months ppc mag. Quite pleased with the article.
Apologies for the radio silence too..
The car is back on the road again now finally, ill do an update when i have a bit of free time and take some pics
also have a new project as well
Last Edit: Apr 27, 2014 10:45:09 GMT by anden
bstardchild
Club RR Member Number: 71
1954 Substandard 8bstardchild
@bstardchild
Club Retro Rides Member 71
Apr 27, 2014 17:02:51 GMT
Was a nice article on the car, well done on the feature, nice sticker on the windscreen, might not have any this year.
anden
Go low or go home
Apr 27, 2014 21:12:06 GMT
Was a nice article on the car, well done on the feature, nice sticker on the windscreen, might not have any this year. which sticker the rr ones?
bstardchild
@bstardchild
Was a nice article on the car, well done on the feature, nice sticker on the windscreen, might not have any this year. which sticker the rr ones? The hill Climb one from last year
anden
Go low or go home
Apr 28, 2014 11:37:43 GMT
ahh yeah, still sporting that one!
Good to see the car in PPC. In my opinion there aren't enough Standards in the mags.
anden
Go low or go home
Aug 25, 2014 20:25:17 GMT
looong long overdue an update! The car WILL be at retro rides next weekend On a set of staggered wellers now 13 x 6.5 fronts 13 x 7.5 rears, squeezed a teeny bit more rubber on the back end Freelander stud conversion which are thicker diameter and longer so i could run the required spacers to overcome offset issues. Mkl escort steering rack conversion. Back on the 32 / 36 carb as twin 40s were too thirsty! rebuilt the rear axle as seals were nackered as were the bearings bonnet mascot is a new addition too subframe has been notched 15mm too to give a bit more ground clearance. no plans to take this any further just going to use it and enjoy it.
Last Edit: Aug 25, 2014 20:32:45 GMT by anden
Aug 25, 2014 23:19:11 GMT
Love it in every way possible. Want!
*n
Aug 26, 2014 20:06:16 GMT
For me it's missing only one thing and I've no idea how you'd achieve it: spats/fender skirts. In every other conceivable way it's bob on and I still really like it.
qwerty
Club RR Member Number: 52
1954 Substandard 8qwerty
@qwerty
Club Retro Rides Member 52
Aug 26, 2014 22:46:20 GMT
I can definitely see why you're leaving it alone and just enjoying it. Looks absolutely bob on!
Aug 30, 2014 22:39:29 GMT
I'd only change one thing. The wheels. To holey for it. Cool car.
like it my uncles playing with a standard 8 at the min too
eternaloptimist
Staggered Wellers are the way forward.... Looking great!
eternaloptimist
Sept 2, 2014 13:25:06 GMT
By the way, what size tyres are you running on the back?
anden
Go low or go home
Sept 2, 2014 16:19:12 GMT
175 60 13 on the front on a 6.5j wheel 185 55 13 on the rear i think (need to double check profile) on a 7.5j wheel. it is pretty snug out back you wouldnt get much more wheel or tyre in there.
Got a set of 235 45 13 and 10j wheels on the dreaming shelf! they will never fit unless i swap to the gasser look!
Last Edit: Sept 2, 2014 16:19:18 GMT by anden
Sept 2, 2014 18:46:06 GMT
Would the axle have trouble with more grip? Three plus times the power and twice the rubber is a big jump from stock!
*n
eternaloptimist
Thanks - mine have 186/70 13's on, they're a bit snug. Will be interesting to see how good the lateral location of the axle is when it's on the road....
anden
Go low or go home
My wheels used to bang the arch a bit prior to replacing all the bushes. It's perfect now.
The axles are tougher than given credit for. I think the saving grace is the lack of rear end weight , it lights up all the way through first and into second in the dry if I'm heavy footed it's great fun!
anden
Go low or go home
Rr gathering is a bad influence...
Thinking of going turbo
anden
Go low or go home
Sept 12, 2014 20:19:04 GMT
So his happened this week.... Had to remove front bumper and wind coilovers up to get it on . Driving it hard as usual and here's the route cause of the issue Gunna need a stronger axle for a turbo I reckon hahaha, although that shaft has taken 3 years of all out abuse, running far more power than I am now!
