foxy99
Last Edit: Mar 4, 2013 2:43:02 GMT by foxy99
Feb 19, 2013 12:54:36 GMT
The design of those lights is really nice, they look rather like champagne flutes. They also seem to fetch around £50 a pair for ones scruffier than yours, I know this from failing to win a few auctions on eBay as I was planning to fit a pair in the Polo.
foxy99
Feb 19, 2013 20:44:59 GMT
Hi Volksangyl. I didn't realise that. I searched them on Ebay and noticed that they were fitted to TR6s as well. Unusual connection with the two different type of cars...altho I think they maybe both use Stromberg CD175 carbs
foxy99
Just a quicky tonight. Have been at the barn every night this week and was determined to finish blasting the trim rails. It's slow progress as the blaster is jamming constantly. I only have the back face of one still to do and was going to shoot some epoxy mixed up a while ago on the bits I have done but it has totally cured in the jar and at 2am it was too late to start mixing more up. The rear lower piece, which is the biggest, won't all be blasted as I'd mixed up too much epoxy mastic last week when I was sealing the underbody areas and ended up brushing it onto the unblasted panel to use it up. One end escaped the mastic and I blasted that tonight. Will be interesting to see, in ten years time perhaps, if the two areas will show different signs of corrosion. I won't be at the barn till Monday now but after a trip to B&Q am armed with the right size of staples and some glue so I hope to re-trim the can't rails in the comfort of the living room headling trim panels, L-R: rear upper/front upper and rear lowerblasting has left a nice clean surface on this part
foxy99
Ok. It's been about a week since my last post and if I hadn't went out on Friday night I would have had finished the trim piece prep. I spent the week blasting the pieces pictured last time and have got epoxy primer (Glasurit EP 801-72) on them at last and was dying to get some topcoat on so I could bring them home on Friday night and re-trim them over the weekend but I felt obliged to go out for drinks with my new team mates on Friday so I'll do it tomorrow. The blasting nearly put me over the edge. If the pot was running freely I could've done one of the beams in about half an hour, maybe a bit more, but I was at times only getting a piece the size of custard cream done before the pot had to be turned upside down/connections unscrewed/re-fitted/pressure increased/decreased/left the same and this went on for days but they are done and sealed so I can forget the trauma and move on. While the blaster was out I also cleaned up the scabby edges of the 2nd hand rear lower quarter panels I bought a while back and they are also epoxied. Really glad I done it now as I can put the blaster away and give the place a good sweep up. One good thing about the grit is it seems to act as a good scrub for the floor. I'd also had some problems with the rear quarters not fitting on without a bit of pressure and found that some welding I'd one on the wing support struts were fouling the faces of the outer panel. A little work with the grinder has improved this In other news I sent the 2 small radius arm bushes back to the Ebay seller who very kindly refunded my girlfriend and I also received another one from a different seller which I measured today and it comes in at 46.78mm I reckon which is smaller than the ones I returned but bigger than the one I managed to get in with a struggle so will be another wrestling match with the vice etc in store. The latest one is a genuine Metalastik one (which I got for a fiver but they usually sell for about £17) and has number 13/1421 on it. I bet there is some way to decipher that number to establish the size. Couldn't find anything Googling it but it did turn up some interesting articles where the consensus was that you need a huge press to install them as they are supposed to be bigger than the housing they fit so they become virtually welded in to the component. Seems a bit extreme but at least explains why I'm having a struggle. adjustment slots in lower rear quarter panels are generous but not much use when hole on wing is at limit of the slotlower quarter flange also sitting outboard of wing bottom.........with little scope for pushing inwards as bumper iron is tight behind itand at rear end bolt has to pull flange in and up at an anglescruffy mounting points of rear quarter panels cleaned up with grit blastingand lastly the part where the fuel tank filler pressings on rear haunches drain water out through the rear quarter panels front cornerlatest radius arm small bush coming in at 46.73+mm I reckon
Last Edit: Mar 4, 2013 3:14:50 GMT by foxy99
foxy99
Last Edit: Mar 11, 2013 11:09:43 GMT by foxy99
foxy99
I've not updated this for a while but am still working on it 5 nights a week and never had time to update this recently so got a bit of a backlog. I won over £100 at the bookies on the Chelsea - Steaua Bucharest game (would've been over £300 if the game ended 2-1 instead of 3-1) so treated myself to some new parts. Now, way back when I got the car and intended to patch it up for the MoT one of the things on my shopping list was new pistons for the front calipers. Recently I got a whole new unused front caliper (not sue which side) off Ebay for £10 but I don't think another one will come along for a while so I took the plunge and bought 4 pistons (instead of the 8 needed for an axle set) to use in one of my original calipers. As posted a few months ago I laid out all the exhaust parts and have got a much better mental picture of what bits I need as I was never sure when they were all stored up the barn loft. Basically I need a passenger side rear silencer and could do with a driver's side front/mid silencer altho the original could probably be fixed. With my new winnings I had to take the plunge and but the back box as it was listed at a very reasonable price from a main dealer. I hoped but didn't expect, to get an OEM one but the dealers do lots of pattern parts so as long as it fitted I'd have been happy However, as you can see its the real deal and I'm really pleased with it. I also had a sub thread running a while ago about the fittings for the over axle pipe. The original set up is a a threaded rod with several washers/rubbers/a nut and my car has had home made efforts at replicating them. I was keen to get some of the original fittings despite the fact that added together all the little parts would cost more than an exhaust part and bought a couple with my free money. At least now I could copy them if I'm too tight to buy a couple for the other pipe. You may also remember the IRS was stripped for painting. That will be getting re-assembled soon and you could spend a small fortune replacing all the bearings etc there. I only noticed one damaged sleeve when I was dismantling the lower wishbone inner ends from the diff so bought 1, instead of 4 and I could have damaged a couple of the 8 needle rollers also so bought a few of them too. I mean how much do these inner ends actually move? Its not like they do the work of a crankshaft bearing where they are spinning constantly. The just rotate a little when the wheels move up or down. Also got the most recently acquired small radius arm bush 3/4 of way in by thwacking it with a large piece of wood. Worked a treat thumping with wooden blocks saw bush most of way home and has advantage of not damaging the part got the top score right but the following night's score was 3-1 istead of 2-1 which would've paid out £328but £10 back up bet paid out £110 so I feel like my box of parts cost about £10 4 of these little nylon sleeves would cost nearly as much as the back box pukka part have been waiting to buy these front caliper pistons for about 12 years
Last Edit: Mar 27, 2013 3:30:58 GMT by foxy99
79cord
Quite a wait! Trying to replace/glue on the headlining cloth in-situ sounds like a nightmare.
Mar 26, 2013 16:55:24 GMT
The design of those lights is really nice, they look rather like champagne flutes. They also seem to fetch around £50 a pair for ones scruffier than yours, I know this from failing to win a few auctions on eBay as I was planning to fit a pair in the Polo. That's interesting, didn't realise they were worth so much, there's a pair of these in my garage, (one painted matt black unfortunately,) Brilliant thread though, loving the work done so far,
foxy99
Cheers guys I've got another backlog of pics to put on and it's getting late and I've still to check my coupons from tonight's International games so prob won't get the wordy bit done. I do know I won £17 on England HT - Draw FT however so I could buy another £4 needle bearing or 2 more nylon collars lol. Anyway. Re the exhaust parts. The numbers change a couple of times in the parts books for no apparent reason so I've imagined they must all actually be the same and I've also been tempted to but XJ6 parts hoping they'd fit but now that I have compared the recently acquired part to the old ones it's a bit clearer. The original XJ12 back boxes had shorter silencers but were the same overall length....longer pipe basically. My car should have the later type per its chassis no. but came out the factory with the early parts. At some point in its life one of the front/mid boxed has been replaced with the later part and also one of the back boxes. Last year before I knew what I did/didn't have a guy was trying to sell two new matching front/mid boxes on Ebay for £40. Wish I'd bought them now as the only other one I can find anywhere in the world in on Ebay from a USA vendor and the shipping is gonna be high. He also has one of the early back boxes. Maybe buy them if I win more free money new LHS back box next to original. same overall length but longer silencer section. this explains part no change slightly different hangersnew LHS box next to RHS box which was put on car at some point in its life. part no's are a pairhangers are the sameslight difference in method of fitting tail pipe to box but not enough to need another part no. change
Last Edit: Mar 27, 2013 10:45:45 GMT by foxy99
foxy99
Last Edit: Mar 28, 2013 1:48:03 GMT by foxy99
foxy99
Last Edit: Apr 3, 2013 23:26:24 GMT by foxy99
Providing the new piece is symmetrical you'll get away with that and nobody but the most anorak-y will notice it. There's something very fitting about using your Bookie winnings to restore an old gold Daimler, can't think of a better way to fund such a project.
actionslaxx
a message to you rudy
Hi pal Have you any plans to change the ride hight ? I've not long ago picked up an 87 xjs which I've just finished the pre MOT weldathon on [MOT tomorrow] and if it scrapes through I might think about cosmetics like that , though not usually my thing , it seems to be all the rage on this site. Smith Cambuslang.
foxy99
Hi actionslaxx. I'm pretty sure I won't be slamming this. I think they look great stock and I tried to slam a Polo I spent years rebuilding and it drove so badly afterwards that I never finished the project. It gathers dust at the back of the barn Comfort is more important to me I think. If I see a slammed XJS in town I'll no it's you tho Vulgalour. It is a great way to fund a project but no wins on the European football from last night & tonight. I lost a fiver , so that Stateside silencer will need to wait. I should actually be trimming my parts tonight as I didn't go to the barn but instead I am counting all my wins & losses for the 11/12 season. It takes ages
Last Edit: Apr 4, 2013 22:04:53 GMT by foxy99
actionslaxx
Agreed, no slammin' I'm sure there are cars you can improve with sport suspension changes but these jags just drive so welll stock. Got my first drive of my xjs after passing MOT [yahoo] saving for road tax and a tank of petrol both about the same price. The Daimler resto is a great story, will you be painting it yourself? and if so what kind of paint, I've been spraying 2 pack with the hold your breath method of breathing apparatus, I can hold my breath for 20minutes ...... I think. Smith C/lang
foxy99
Last Edit: Apr 8, 2013 2:52:07 GMT by foxy99
foxy99
Last Edit: Apr 9, 2013 14:43:29 GMT by foxy99
foxy99
Apr 10, 2013 15:26:37 GMT
Last Edit: Apr 10, 2013 16:16:54 GMT by foxy99
foxy99
Apr 11, 2013 14:35:43 GMT
Small update. Got the repair finished on the bonnet hinge are bit. Am really pleased with the way it went apart from a couple of plug welds didn't pool out the way I like them. The other thing is that the steel I used was my very last bit of 1mm sheet. I've only got 3mm & 0.8 just now. The 1mm stuff was bout over 20 years ago!! as an 8' x 4' to use on my Hillman Imp. None of it was ever used on the Imp but over the years has been used to patch up several cars. I didn't actually have a piece big enough for this repair so had to join to pieces together hence the join in the middle of this patch. It might seem strange to do this but bottom line is it isn't worse than the surrounding metal..... patch shaped up to repair hinge mount area on bonnet. holes took ages to make with needle files but are copies of elongated(?) ones on original piece after measuring several times 1st step was to plug repair piece to capitive plate bracket per original. good penetration here then plug other end of captive bracket back to bonnet through original spotweld holes more plug welds where returned lip on repair piece meets bottom flange of bonnet outer skin. plug on left is how I like them. other two not so good done ...apart from little triangular piece needed here and maybe a little grinding on the welds
