sparko
I would firstly like to.state i know jack about saabs and volvos so i need help! I'm rebuilding a mk1 astra and was originally going to whip in a bike carb'd xe but am now wondering, why build an engine that Will produce about 180 bhp when i can just whip in a turbo lump that Will have a hundred more!
I don't want to go down the stereotypical route of a let as.they are fairly expensive (tight budget) but know saabs and volvos can handle.good power on standard internals. What i want to know is what engine is the best compromise of of power and.price. If i could buy a whole donor car for 500 quid then amazing! Ideally it would need to mate up.to a vauxhall gearbox as well with minimal effort.
So, thoughts? Dirty easy cheap power? But.from where!
sparko
Oh and it has to be a 4 pot as space is tight!!
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
best saab/volvo turbo engine?speedy88
@speedy88
Club Retro Rides Member 118
Try and get hold of a B230FT. Go for a 940 - you can easily pick one up for around £500. But TBH any of the engines, 2.0 or 2.3 can be tuned far beyond those figures for not much money.
I reckon you're thinking of the 4 pot from a Saab 9000. My knowledge is poor.. But they come in 2.0 and 2.3 flavours. 2.0s apparently rev better but the 2.3 will make a bit more power. They are supposedly good for 400bhp on standard internals. Later ones (post '93ish) will bolt up to GM gearboxes. Please note the number of 'supposedly' and 'apparently' and 'ish' used in this post Mark: It's going in a Mk1 Astra so a redblock probably won't be much use since they are generally only used in RWD applications
Last Edit: Oct 7, 2011 21:55:31 GMT by ben711200
sparko
Ok... 400 ponies is a.good figure! Id be aiming for 300 ideally so happy days!
sparko
Is the b230ft a 2.3? Assume it is from the engine code, also, do you know if it would mate up with a.gm box? Ta :-)
The B207R bolts up to the F23 and possibly the M32 6-speed as well. It has a lot in common with the 2.2 Z22SE Vauxhall engine.
froggy
what you need is a b204 /234 from a 94 on saab 900 as it will bolt straight onto your box , a mate of mine on mig web (astra nige )does a tidy loom adaptor to make wiring simple and with sensible mapping 250 reliable hp from the standard t25 turbo and injectors
Garry
East Midlands
I dunno how much space there is in an Astra Mk1, but people have squeezed the SAAB 2.5V6 into a Corsa....
sparko
Nah not feeling a v6, a bit heavy to be hanging over the front wheels of a fwd car. Good thoughts though :-)
depends if its ally block v6 vs iron 4 pot .....
In case its of any use, I'm breaking a Saab 9000 2.3 turbo. Its auto, still in the car complete at the mo. If you need any details or engine codes etc, let me know, cheers
1997 BMW E36 328i Touring 2000 Renault Clio 172 ph1 2006 Discovery 3 1996 VW Corrado 16V 2002 BMW E39 530i Sport 1995 Subaru Legacy GT twin turbo 1992 Rover 216 GTi 2002 BMW 330Ci Clubsport SMG E46 2007 Ford Transit 6 seater Jumbo
best saab/volvo turbo engine?Robinxr4i
@robinxr4i
Club Retro Rides Member 143
I think the Volvo idea is epic, but with the lack of a FWD box and the fact the post 1994 Saab engines share the GM bellhousing pattern makes the Saab engine the best option for cheap powers! A friend of mine put a Saab B204L engine in a Astra van, was quite a lot of work mind, IIRC pity much all the engine mounts need changing or making and the wiring is a bit of a fiddle. Again I'm only going off what my mate said and what I saw of him doing the conversion. He bought a whole work taxed and tested Saab 9000 Turbo for ?300 with panel damage, drove it about to make sure the engine was good and then did the conversion when the MOT ran out. Having seen what engines sell for on eBay getting a whole car makes sense as you'll get all the ancillaries and wiring, plus you have a car to weigh in as well. Although my mate did say that the Saab engines are quite heavy, so I wouldn't discount the V6 engine. I had one in an Omega only a 2.5 but it still went quite well and made a nice sound. Well worth a look. I dunno how much space there is in an Astra Mk1, but people have squeezed the SAAB 2.5V6 into a Corsa.... The Saab V6 is the same as the Vauxhall one, GM basically just lifted it into whatever it liked..... en.wikipedia.org/wiki/GM_54-Degree_V6_engine.....although I believe the 95 Griffin got a 3.0 GM lump (like the Omega) but with a single turbo. IIRC it was about 250bhp and was only fitted to auto boxes
Last Edit: Oct 8, 2011 8:13:34 GMT by Robinxr4i
sparko
Thanks for the info chaps. I'm don't fancy a.v6 tbh, its all about building my first turbo'd car so 4 pot.with a.big whizzy thing.bolted to it is the way to go for me! Does anyone know what a saab 9000 bhp is from standard?
@robinxr4i
Saab did a high and low pressure versions of both the 2.0 and 2.3 although internally they are the same just different maps and turbos.....
2.0L 150 hp - low output 2.0L 175 hp - high output
2.3L 170 hp - low output 2.3L 200 hp - high output 2.3L 225 hp - Aero version
.....IIRC the 2.0 don't have balanced shafts and the 2.3 do.
`state
Yorkshire and The Humber
Theres a guy on mk2oc who put one into his mk2. You`ve got to cut the drivers side chassis leg right back to nothing to get the engine in. F20 gearbox wont last 2 minutes so you`ll need the f28 and make the mounts for that too.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
sparko
Excellent cheers, aero lump it is then! Well il probably need an lsd at some point in the future so an f28 would need to be purchased anyhow. Ooooo can't wait to shift my clio so i can crack on with this!
sparko
Also 'state, do you know if the chap on mk2oc did a build thread? Cheers
`state
I`ll have alook later for you as cant remember off the top of my head. T`was a red gte,its been in Total Vauxhall mag too. Theres also a guy on mk2 cav site who`s putting one into his mk2 cav.The bays are the same width and practically the same so that`ll be one too one.Guys called Ritchie and he should be putting pics up in the next day or two.
