Sept 11, 2011 9:55:47 GMT
Hiya, I've got a 2000 plate Golf GTi 1.8 turbo (AUM engine code) and it's just had the cambelt and headgasket done on it, just got to try and start it today and when the battery is connected the fans come on straight away without any keys in the ignition and then when you try and start it nothing happens, I.e no lights on the dash, no cranking or anything...I'm stumped?! Does anyone have any ideas? Cars been off the road for a few months now I'm getting desperate!! Ellie
Last Edit: Sept 14, 2011 14:36:07 GMT by shorty87
Sept 11, 2011 10:16:18 GMT
Make sure all your plugs are connected, especially the at the ecu.
R.S. Autotech. Servicing/Repairs/Diagnostics.
bortaf
Sept 11, 2011 11:27:34 GMT
Just done as in this is the first time you've attempted to start it ? if so check there water in it and the earths are back on with bnon left hangine, same with the starter lives.
Last Edit: Sept 11, 2011 11:27:49 GMT by bortaf
R.I.P photobucket
bl1300
Sept 11, 2011 12:06:37 GMT
Make sure all your electrical connectors are connected and in the right place. It definatly sounds like a wiring fault
Current fleet.
Sept 11, 2011 20:24:48 GMT
It was the first attempt at starting, checked the water and released the pressure through the system. Had to leave it and go to work but am hoping to find the problem before work tomorrow otherwise its on the bike (cycling) again!
Sept 11, 2011 20:40:07 GMT
Ok don't take this the wrong way but you have connected the terminals on the battery properly. Have you conected the earth on the engine?
Dez
Club RR Member Number: 34
Sept 11, 2011 21:25:54 GMT
a common problem (ive seen it more than once on this age of VW) is people getting the main battery lead, the starter lead, and the gearbox earth strap mixed up, with varying results. the symptoms you describe are one possible result though.
I'm not sure if youd have undone them to do the HG and cambelt though, depends how you did it, its more common after clutch replacements.
Sept 13, 2011 8:43:12 GMT
Finally got round to checking the connections, earth connections are ok, battery is connected up correctly, still the same result. Checked all the fuses they're all in tact, I'm lost!!
Sept 14, 2011 14:40:56 GMT
found this, is the fuse on the far left the culprit? 110A with the black wire leading in>
Last Edit: Sept 14, 2011 14:41:14 GMT by shorty87
Sept 14, 2011 17:23:31 GMT
That looks very, very likely to me. Make double sure all your leads are on right then change the fuse.
Sept 14, 2011 17:28:29 GMT
Awesome, that was the culprit, however now its trying to start but sounds like this:
I checked theres fuel up in the injector rail looks all good, now I'm lost again!!!
Sept 14, 2011 21:01:11 GMT
ive only got bad news for you mate that motor has no compresion. so the timings out[and hopfully no piston to valve contact] or youve got some bent valves in there me old fruit
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
will930
Decked K11 Micra - RetroRunner Mk2 Golf
Sept 14, 2011 21:42:48 GMT
if it was the cam belt that snapped initially then most likely bent valves I'm affriad! my dads 406 belt snapped and bent about 12 valves
Sept 14, 2011 21:45:22 GMT
I had all the valves replaced, the head skimmed and pressure tested and new gaskets used when it was all put back together, is there anything else that could be causing it, could the timing be out? Also someone suggested the tensioner sounded too tight?
Last Edit: Sept 14, 2011 21:51:46 GMT by shorty87
Sept 14, 2011 21:49:35 GMT
ive only got bad news for you mate that motor has no compresion. so the timings out[and hopfully no piston to valve contact] or youve got some bent valves in there me old fruit i replaced all the valves before putting the new belt on, will turning it like this risk bending the new ones? That would suck massively!!!
Sept 14, 2011 21:56:15 GMT
Sounds silly, but did you check the cam timing? If so, was it with tippex marks or with the timing pins? Another thing, did the crank pulley have a rubber layer in the middle circumference (basically, was it a harmonic balancer type?). You did turn the engine over by hand a few times (with the covers off) before trying to fire it up right? Sorry for the obvious questions, but you never know . I notice that you say that changed the 'belt'. AFAIK, don't these 1.8Ts come with two timing belts (one to drive the inlet cam and the main belt only driving the exhaust cam and water pump from the crank pulley). If so, did you change that one too?
Last Edit: Sept 14, 2011 21:58:24 GMT by ChasR
Sept 14, 2011 21:59:48 GMT
Sounds silly, but did you check the cam timing? If so, was it with tippex marks or with the timing pins? Another thing, did the crank pulley have a rubber layer in the middle circumference (basically, was it a harmonic balancer type?). You did turn the engine over by hand a few times (with the covers off) before trying to fire it up right? Sorry for the obvious questions, but you never know . Annoyingly I actually paid someone else to put the cambelt on to avoid messing up the timing etc, so I can't answer those questions , the belt that came off though had sheered off half the teeth as opposed to snapping completely could this send off the timing?
mk2cossie
Club RR Member Number: 77
Sept 14, 2011 22:03:47 GMT
if the valves have been done, I'm gonna have a stab in the dark and say that the cams arent timed up properly on the timing chain side of things double check the crank and camshaft marks are lined up with the correct timing marks on the covers (vw use the same covers for a few engines with different timing marks ) think on the timing chain end of the camshafts are each marked with a spot that needs to be lined up on each one so they are facing/nearest each other ;D
Sept 14, 2011 22:12:15 GMT
if the valves have been done, I'm gonna have a stab in the dark and say that the cams arent timed up properly on the timing chain side of things double check the crank and camshaft marks are lined up with the correct timing marks on the covers (vw use the same covers for a few engines with different timing marks ) think on the timing chain end of the camshafts are each marked with a spot that needs to be lined up on each one so they are facing/nearest each other ;D Thanks I'll give that a check over tomorrow!
murran
Sept 15, 2011 19:08:24 GMT
any joy on this? where abouts are you? if your near sheffield i'll come take a look. done more than a few a3 tt cambelts head rebuilds in my time at work.
