But I just don't seem to be able to find the motivation at the moment!
Been to as many local meets as I can, but after having my wheels nicked from the barn, it's kinda put a damper on my spirits.
The van is sat, tail in the air, new engine, loom, coolant system installed, and I've had it turned over, but it's not firing.
This is probably a fueling issue, as the fuel tank "feed" is at the back of the tank, the nose down setup of the bus on axel stands is prob causing a fuel starvation problem (it does fire sometimes, but I've not run it....)
I need to replace a section of hydraulic clutch hose, and I've gotta figure out why I've got no oil pressure warning light... then there's a small hole in the sump I need to do....
that's really all that needs doing now....
So why can't I find the drive.....
I think if I got it off the stands and had it running, I'd change my mind, but I can't seem to find the motivation to do even that at the moment....
Having those Fuchs nicked REALLY hasn't helped, and I've got a load of other bits I could be getting on with too, such as that 1302 of mine, the "1200 beetle" of Sarah's is another, not to mention that Polo I got and was using as a daily.....
Oh, and a Merc...
Oh, and a Merc...
