Jul 26, 2006 10:03:41 GMT
guys i just bought a lovely 1985 Suzuki SJ410. i full repainted it in its original met blue, it has white wellers, white bull bars and white roof it lokks great!! ive fitted dark blue leater seats out of a porsche 944 turbo.
i cant find much info on em tho, anyone into these things??
cheers
Why you always bring me junk!
Jul 26, 2006 10:24:59 GMT
twin cam 1.3 gti engine out of the swift I'm pretty sure it will fit in (ive seen pics) can't be more help on the tuning front I'm affraid!
brilliant offroaders!
qwerty
Club RR Member Number: 52
Jul 26, 2006 10:29:58 GMT
Awesome off road. Pretty much everything has been and can be done. The sj410 has a lower gear ratio transfer box. 1.6 vitara engine would be my choice of engine. Suspension wise I would go Spring over axle conversion with Procomp shocks and some 35" tyres.
Try Difflock.com cos its a great 4x4 forum
Jul 26, 2006 10:45:26 GMT
There`s just something about them I like - here`s one I saw in Cyprus
Jul 26, 2006 10:47:06 GMT
Fantastic ofF road !
Suzuki ‘Jimny’ by other name these ‘Jeeps were originally the idea of ‘Hopestar’ which Suzuki bought out in 1968. Originally called the 360 (a two stroke), then in 1970 the LJ10 (LJ = Light Jeep), 1972 the LJ20, ’77 the LJ80 and LJ81 Pick up. In 1980 the SJ10 (SJ = Suzuki Jeep) , then SJ410 in 1982 and SJ413 in 1984. Even the badged as a ‘Jimny’ today is a good offroader and when these to become older I’m sure they will be a good source of FUN!
SJ410 can be underpowered
Bodies rot terribly, usually at all four corners, but chassis’s usually quite good .
Carburettors can give problems.
GREAT VEHICLES
Last Edit: Jul 26, 2006 10:48:10 GMT by TwincamGTi
Jul 26, 2006 10:47:39 GMT
I remember we saw one at Tixover quarry one pullying landy's out of puddles , they are fantastic off road, not my thing tho' That said, I've seen Syncro VW campers pull landy's out before too
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
Jul 26, 2006 11:42:04 GMT
I reckon it would be great to lower one right down and fit very skinny lo pro tyres to it. Rear wheel drive, Swift engine. Proper go kart!
I had an old 1 litre and it was a bit slow but amazing off road and very solid.
Is yours 1.0 or 1.3?
Charlie
Jul 26, 2006 11:48:22 GMT
Its a 1litre, and yes its very underpowered! ;D great for messing around in tho, diff lock hubs on it too, even with the puny engine it managed a rolling burnout in my garage ;D il take some pics soon, I'm beginning to really like it lol
Snoozin
Toyophile
Jul 26, 2006 11:50:11 GMT
The 4WD guys here have a thing for bolting Datsun A15 engines into them, they make supremely effective offroaders with this combination.
Jul 26, 2006 11:56:52 GMT
That's weird, I was just thinking about SJ jeeps the other day. There was a big hoo-haa some years back about them being very unstable on corners / in accidents... but then if you wanted something with go-kart handling I doubt a SJ would fit your criteria! ;D I'd really like one
B-8-D
down to one car!!
Jul 26, 2006 11:59:00 GMT
as most people say they are fantastic offroad.. watch the transferbox mount though they are commen for catching on stuff and pull the mounts off! the engines are not bad for a 1000cc but are prone to bigend failure and can break rings easily and head gasket probs.... change the oil as often as u can afford and they will live on.. but are hard to find second hand because of these probs. i had one bought it for 50quid... and took the engine out sold that for 140quid !! no probs.. i then fitted a bike engine.. never finished it though..(usual story..) lots of people reverse the rims and bolt them back on to give a slightly wider track for more stability. cornering fast on the road CAN tip them over... but they are great fun..
Jul 26, 2006 12:05:46 GMT
i had one bought it for 50quid... and took the engine out sold that for 140quid !! no probs.. i then fitted a bike engine.. never finished it though..(usual story..) Do you have any pics? Sounds really interesting!
B-8-D
down to one car!!
Jul 26, 2006 12:49:27 GMT
no i havent sorry.. ive had so msny wierd and rare cars over the years that i wished id took photos of.... its a pity really because id love to have a record.. nowadays i take a lot more but no enough.. i always intended to do buildup pics for each of them but never really get around to it.. ho hum.. si
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Jul 26, 2006 13:02:10 GMT
They are so holiday!!
happy sunny funny cars!
This space available to rent. Reach literally dozens of people. Cheap rates!
Bioshock
It aint hip to be square.
Jul 26, 2006 13:18:32 GMT
Last Edit: Jul 26, 2006 13:23:00 GMT by Bioshock
Almera GTI = ugly bird who turns out to be great in the sack = Win
Jul 26, 2006 13:45:51 GMT
I had one a while back - took a complete disco in the back! Great fun if a little slow. Engine trouble killed it in the end.
Peugeot 307sw - Suzuki SV650S - MX5.
Bioshock
Jul 26, 2006 13:53:21 GMT
I've had two,410 and 413. When the Engine on the 410 went belly up,I bought a rusty Suzuki "whizzkid" and swapped the engine(Same block different ancillaries) trouble is they're as rare as hens teeth now
Jul 26, 2006 15:51:27 GMT
theres one in the local breakers, running a 2.0 corty engine one of the young lads was tinkering with it the other day just the thing for messing up there recently flattened ground.....
2006 Audi A3 2003 Fusion 2 looking for a project....
Jul 27, 2006 18:05:17 GMT
here is some food for thought, as I've got my scanner working! lowrider- see all the legendary rides surrounding it in the top pic thats bruisercapri's old sri cavvy in the lower one. and yes, I carried a torch for them then, and still do now. all thanks to this one (excuse the photo of a photo, but the pic won't fit on my scanner bed ) inspirational! according to the accompanying text, it has 3" de-arched springs and employs other lowering practices. it also has 10" wide kmc alloys its
