Hello, here I am into a trap to take it apart and I can put my long studs I did unscrew the 4 screws behind, but it does not move and the center of the hub is full So how do I make of it? Extract Hard hub? has exctract inertia? but I do not know what he will use to extract it, risking everything just ripped... thank you for your answers;)
retromods.forumactif.com/"la Française" oldschoolers community my cars: -83' Toyota Celica 1600st -81' Bmw e21 320/6 -81' Talbot Horizon 1,5 -87' Ford Escort mk4 wagon
The Doctor
Club RR Member Number: 48
you need a slide hammer to take the halfshafts out, they can be stuck pretty good after all those years
it is force-fitted into the splines? just? surprising because the wheel could also be from a hard driving it will be hard to get out the hammer, it moves at all and I am afraid to break is what it was when you did your Toyota? I imagine a lot of penetrating oil? turnover has broken?
The Doctor
that's what i've used to take my halfshafts out. They sit in the axle and the bearings can be stuck in the housing as well as the splines in the diff. If you have removed the 4 nuts which hold the axle in place (through the hole in the flange) then it should come out with the slide hammer. They can be quite stuck, but they are thick and sturdy, so you won't break them easily! Just use the right tools for the job and you'll be allright!
Yeah! thank you for the explications the first hub is exit... with a friend of my father,he had a good facom extract (he drive a citroen traction,mercs 280se,Renault 20 and agricole machines) So easy for him!he laughing and ask me: little player... ;D rest the second tomorrow or wednesday encore merci a toi pour ces precisions
