Jul 24, 2006 20:09:50 GMT
Check this one out guys its pretty good i recon autospeed.drive.com.au/cms/A_0059/article.htmlIve got a kill switch that is pretty good as unless you know its there, its difficult to connect. If you know its then then its also a piece of pee to connect I may do the one above as it seems jolly good J hi can any of you tell me where to bye the following items. 12 volt Double Pole Double Throw (DPDT) relay; 12 volt flashing LED; reed switch that closes when a magnet is nearby; pushbutton that opens when pushed; jon
ford driver
Jul 24, 2006 20:30:22 GMT
Check this one out guys its pretty good i recon autospeed.drive.com.au/cms/A_0059/article.htmlIve got a kill switch that is pretty good as unless you know its there, its difficult to connect. If you know its then then its also a piece of pee to connect I may do the one above as it seems jolly good J hi can any of you tell me where to bye the following items. 12 volt Double Pole Double Throw (DPDT) relay; 12 volt flashing LED; reed switch that closes when a magnet is nearby; pushbutton that opens when pushed; jon try here... www.vehicle-wiring-products.co.uk/
Jul 24, 2006 20:33:56 GMT
Jul 26, 2006 20:17:28 GMT
thanks
jon
ford driver
Jul 26, 2006 22:41:45 GMT
flashing led and some stickers!
