Jul 20, 2011 15:27:08 GMT
1994 Mazda 323f 1.6i 16v GLX
Jul 20, 2011 15:40:27 GMT
I've run mush different tyre sizes than that between front and rear. "affect how the car handles" is an interesting one, the car will handle differently with a full tank of fuel to an empty one...
Whether it noticeably adversely affects is another Q.
I would have thought you would increase the tendency to understeer a little doing that, in theory, but there's more to that one than just size. Tread pattern, compound, etc. etc.
If it seems to drive OK, then it drives OK. I'd have said the difference either way will be minimal?
Copey
Jul 20, 2011 15:44:55 GMT
they will be perfectly fine mate i wouldnt even slightly worry about it, 70% of 155 is 108.5 and 65% of 165 is 107.25 so it really is a very minute difference
tyre pressure would probably dictate handling more than that tyre size difference! lol
Jul 20, 2011 15:45:27 GMT
I've got 215/55 fronts and 265/75 rears on the camaro. I'm pretty sure 10mm difference in diameter won't be noticeable in any way. If you notice a difference it's beacuse the new tyres are of another brand, with different sidewall strenght, compound und so weiter.
bl1300
Jul 20, 2011 15:48:38 GMT
I wouldn't worry about that.
It looks like the size has been picked quite well as Copey says the rolling radius is nigh on the same. Also fitting the wider tyres to the rear of the vehicle is the correct way around to do it. In all honesty that minor size difference is going to still be a major improvement over worn out tyres.
Current fleet.
RobinJI
Jul 20, 2011 16:05:41 GMT
...Also fitting the wider tyres to the rear of the vehicle is the correct way around to do it... I don't see how you can say that without knowing what car they're being fitted to. If I had to guess I'd be expecting it to be a FWD hatch, in which case I'd personally rather run the wider tyres on the front, as the weight distribution is likely front bias, and the brakes are likely overly front biased too, to prevent the rear locking in the dry. Although that said, in this particular instance, it's such as small difference that like others have said, you'll notice more difference from the brand than the size, so I really wouldn't worry about it. What would be worth bearing in mind is that if she gets a puncture on one of the now different sized tyres, then putting on her spare will give her miss-matching tyres sizes on that axle, which is illegal.
Copey
Jul 20, 2011 16:10:57 GMT
What would be worth bearing in mind is that if she gets a puncture on one of the now different sized tyres, then putting on her spare will give her miss-matching tyres sizes on that axle, which is illegal. my mums space saver is smaller rolling radius than her wheels
RobinJI
Jul 20, 2011 16:14:20 GMT
True, but I bet it's also got some sort of sticker on it with a maximum speed and distance on it. If you've just got miss-matched full sized wheels on there then they might not be so friendly about it.
To be honest you'd likely be fine using it like you would a space saver, but I was more thinking that with full sized spares a lot of people seem to slap the spare on then just leave it on there, making the wheel they took off the new spare.
westy180
Project Jetta is go.
Jul 20, 2011 19:11:30 GMT
Legally you have to have the wider tyres on the rear of the vehicle.
Who said VW`s don't rust?
Jul 20, 2011 20:00:56 GMT
My 106 van has 145/70/13s front 165/70/13s rear guessing they didnt have the right size in stock, not the fact that 145s were cheaper than the 165s.
Mind the MR2 runs 205/50/16s front 225/50/16s rear and its much better for it
Jul 20, 2011 20:07:29 GMT
Legally you have to have the wider tyres on the rear of the vehicle. Are you sure? Never seen anything about that.
westy180
Jul 20, 2011 20:08:14 GMT
oh yes.
Jul 20, 2011 20:13:24 GMT
There's nothing about it in the MOT manual, just that tyres can't be different sizes across an axle.
westy180
Jul 20, 2011 20:14:51 GMT
IIRC its in The Road Vehicles (Construction and Use) Regulations 1986
Jul 20, 2011 21:02:23 GMT
Jul 20, 2011 21:11:26 GMT
I'm sure I've heard of production cars with wider front than rear tyres. Some mad FWD performance thing. Not necessarily one sold in the UK though not that this helps LOL.
I wonder if westy180 is thinking of the business about crossply on the front, radial on the rear and not the other way around. There was a story you could put the crossply on the back if they were over a certain size (with many old rods back in the day running big bias belt Grabbers on the back and 135 radials on the front) but I think this was also an urban myth.
Jul 20, 2011 21:17:18 GMT
All in that link above, Akku, but it's getting to the time of evening where figuring out what odd and obscure combinations you could run legally from the Legislative English is making my head hurt. There is no specific mention of size differences though, only load and speed ratings as far as I can tell
Jul 20, 2011 21:29:36 GMT
Thanks for the replies guys, just wanted to reassure that my little sis was safe on the road! You know how it is.
Her spare happens to be a 155/70/13 which is weird as all the tyres on the car were 165/65/13 before we changed the front two. I'l get her a can of tyre weld in case one of the rears gets a puncture.
VIP
Jul 20, 2011 21:34:40 GMT
Legally you have to have the wider tyres on the rear of the vehicle. Are you sure? Never seen anything about that. IIRC its in The Road Vehicles (Construction and Use) Regulations 1986 So you're not actaully sure at all, because you only 'recall' it's in the RV[C&U]Regs 1986, and I'm afraid you are wrong. I can catagorically confirm there is nothing in this regulation, nor any subsequent amendments, regarding tyre widths.
Last Edit: Jul 20, 2011 21:41:07 GMT by VIP
VIP
Jul 20, 2011 22:00:30 GMT
Also fitting the wider tyres to the rear of the vehicle is the correct way around to do it. Please stop giving advise where you do not have the authority or knowledge to do so correctly. At best, it makes you look silly. At worst, you may potentially give dangerous or damaging advice to someone who doesn't know better, before those here more versed in such matters have the chance to correct you.
Last Edit: Jul 20, 2011 22:01:56 GMT by VIP
