Jul 12, 2011 20:45:59 GMT
V8 torque is the "best bang for your buck" I think. There is also the added benefit of not having to re-invent the wheel so to speak. LS2 ect is a documented and "bolt-in" approach. The only niggle is logistics for us UK guys. I should think its the solution that would tick most boxes and require the least downtime too?
I would like to trumpet the humble 924 iron block. Its proven to reliably handle over 300 WITHOUT the benefit of modern fuel and ignition systems (Lemans 1980 in 924 GTR spec). I know stand alone adds to the cost but the motors themselves are bullet proof and cheap to build. Simply weld in two 924 engine mounts and get busy on the exhaust/inlet fab.
A more travellerish solution would be to buy a good S2 for say 2k, pray to the gods that the motor is still strong then transplant the engine, cooling system and transmission...plonk the remainder of the car on the bay and wait 8 months to claw back the lion's share of the 2k outlay. Been there, done that but left with the feeeling that the M44/41 (S2) lump needs....hmmm, boost lol!
BUMP
Mercedes 2.3 Kompressor engine.
Stupid cheap RWD Compact (smaller than the 2.5) 4 cylinder similar power to early turbo but no lag cheaper than a replacement 2.5 engine
DISCUSS!
stwat
Apr 23, 2013 13:36:10 GMT
it's a shame the timings a bit out. Well quite a bit out actually !! I sold this some time back for £800 retrorides.proboards.com/index.cgi?board=FSW&action=display&thread=60411 Had all kinds of trick bits which included a bigger turbo among others (as I later found out from the chap who bought it for the engine) Kind of explains why it was so stupidly quick and spat flames on the over run God I miss that car.
1992 190E 1.8 manual
1989 300SE Low mileage LuxoBarge
1988 190e 2.6. 1988 190 2.3-16 Cosworth
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Apr 23, 2013 15:19:53 GMT
Audi 4.2. The natural evolution of the badge. Check out Twobrutal for a build thread.
Apr 23, 2013 17:03:44 GMT
An Audi V8 sounds good. The strut towers are quite limiting on width mind you. If it can fit, seeing a 928 engine in one would be interesting .
rxv8
Apr 23, 2013 18:34:25 GMT
the 1jz is a snug fit but looks factory when fitted the 1uz fits,as ive done it and sold it last month sr20 would fit well
Apr 24, 2013 11:41:27 GMT
Interesting thread. The 944 is a great basis for conversion, but the torque tube thing complicates.
ToolsnTrack
Homebrew Raconteur
Apr 24, 2013 11:51:44 GMT
sumpcracker
Yes, I’m still here.
Apr 24, 2013 13:48:21 GMT
Ha, i posted this almost 2 years ago! I ended up spending about £900 and Turboing the n/a engine. Its now in 330-340hp spec.
If i was to do a conversion it would be a S4 B5 engine/ audi V8/ or s2 20v. There is a detailed thread on fitting the I5 and an audi/porsche 924 parts bin will sort it.
Apr 24, 2013 17:14:14 GMT
where is the detailed thread?
Apr 24, 2013 17:42:12 GMT
click the link in his signature
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
sumpcracker
Apr 24, 2013 18:17:42 GMT
I think he means the I5 thread. here- www.944-20v.nl/That was an N/a but similar job to do this-
Apr 25, 2013 19:50:14 GMT
Put a 928 v8 in it!!
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
rxv8
Apr 25, 2013 21:57:47 GMT
as sumpcracker says a audi 20v 5 cylinder turbo...would be a cracking swop... or ive always like the audi 2.7 bi turbo engine...
