MOT questiongoaferboy
@GUEST
Jun 25, 2006 20:07:12 GMT
only one of my side lights works so i was thinking about just removing the one that doesnt work. do i need 2 side lights to pass or will i get by with one?
also my high beam doesnt stay on. is that a fail? the normal beam is fine though.
also i don't have a registration plate light. whats the script with that? most buggies seem to get away with it.
Last Edit: Jun 25, 2006 20:08:52 GMT by goaferboy
MOT questionarthurbrown
@GUEST
Jun 25, 2006 20:10:09 GMT
I reckon you'll need your lights (side & main beam) working, but may get away with the reg plate light.
Jun 25, 2006 20:10:27 GMT
Errr - I think you need to fix all of those if you want an MOT!
Jun 25, 2006 20:10:49 GMT
it's illegal to have unlit reg plates. Just bosch some lamp thing point at them, job done
Jun 25, 2006 20:11:29 GMT
Would have thought that you would need beam. Could be a problem with the switch. Can you flash the lights?
BS Nymph Singer Chamois Coupe Series 3 Landy
@GUEST
Jun 25, 2006 20:13:15 GMT
i can flash the high beam. just not leave it on
Jun 25, 2006 20:14:25 GMT
Is it a Beetle switch?
@GUEST
Jun 25, 2006 20:16:47 GMT
just read this about reg lights: "The MOT is only concerned with whether the Lights work - NOT whether they light up the number plate."
now maybe I'm a bit biased but this is silly. you may as well not have them (ie. me)
@GUEST
Jun 25, 2006 20:17:23 GMT
nope. its that retarded nissan one. the whole steering culumn is some unknown nissan jobbie
Jun 25, 2006 20:18:21 GMT
You'll need all of that to work to get an MOT pass mate. Main beam needs to stay on when switched on, but the blue dash warning lamp doesn't have to work.
@GUEST
Jun 25, 2006 20:18:28 GMT
My COToW doesn't have numberplate illumination. See:
Last Edit: Jun 25, 2006 20:21:33 GMT by goaferboy
Jun 25, 2006 20:21:21 GMT
COToW?
@GUEST
Jun 25, 2006 20:22:19 GMT
You'll need all of that to work to get an MOT pass mate. Main beam needs to stay on when switched on, but the blue dash warning lamp doesn't have to work. good job too. hasnt got one. fan-cocking-tastic. if the "high beam" was actually brighter than the normal one id understand i spose its a bad time to mention the hazard lights don't work either?
@GUEST
Jun 25, 2006 20:22:52 GMT
Crusty Old Truck of War!
Jun 25, 2006 20:23:16 GMT
theres a date for cars that don't need a reg light.not sure what that is though.late sixties early seventies. pog, your landy is an old one on 70s plates, so wont need one. goaf, your gonna.
Jun 25, 2006 20:23:37 GMT
What year is it again?
Last Edit: Jun 25, 2006 20:24:53 GMT by ImpJimbo
@GUEST
Jun 25, 2006 20:27:16 GMT
<---1971 ;D
edit: <---its closer to here
Last Edit: Jun 25, 2006 20:27:50 GMT by goaferboy
Jun 25, 2006 20:32:00 GMT
Oh yeah ;D ;D
Jun 25, 2006 20:32:01 GMT
^^^pmsl my bus was a 71 and had a light from the factory. may be worth a try without. if its not there, and doesnt look like its meant to be there, they cant test it.
Jun 25, 2006 20:33:35 GMT
My 72 Imp did not have hazard lights. Nymph only has them because its had a complete rewire.
